Found Source of White Oak Board
WithOrWithoutU2
Post by WithOrWithoutU2 »
I've tracked down a source for rough cut white oak boards from a small custom sawmill. The boards are about 10 ft long, 9 inches wide, and 1 1/2 inch thick. The mill reports the stack has been air drying for 1 1/2 years. No chemicals or kiln dried. It has about 14% moisture left. My only concern is they have been drying under a leanto. So while it has been weathered from changes in temp and humidity outside in the midwest, it has not been exposed to rain or snow. If I read things correctly on this, it is the repeated process of being washed by rain, air dried, wash by rain, air dried, over and over that rids the board of tannins. IF I AM WRONG please advise.
I've picked up two boards. I plan to cut them down about 3ft in length, 4 1/2 inch width and then just stack in a grid and leave outside to get washed by rain. Given they've already dried out, will my process still work? Or should I give them a good soaking in a 55 gallon drum of water first?
acfixer69
Re: Found Source of White Oak Board
Post by acfixer69 »
I'm no arberist so take this with a grain but you need to be sure it's the heart wood oak. I buy used barrels and chop them up to make my own sticks.
OtisT
Post by OtisT »
Just my personal experience, I’m not a pro.
1.5” thick is nice. :D 1.5 years of air drying is about the bare minimum it takes to dry green QS oak that thick. Most go a bit longer, so I’m told. Once they get below 15% moisture for the first time, they should not warp (much) because most of the cell walls have hardened, even if their moisture goes way up again. You should get them down below 5 before trying any toasting, or they can split more easily during toasting as the moisture try’s to escape.
If you plan to cut those down shorter they 3’ eventually, maybe do that now. Assuming your boards are QS, the end grain of those boards are where the wood channels are that “breath”, so shorter sticks means your wood will season quicker.
The outdoor wet/dry cycle you stated is my understanding of the process of seasoning as well. You should not need to soak them if they will be getting naturally wet soon anyway. If your not getting any rain soon, you could let them dry a bit more to make sure they harden, then soak or hose them down repeatedly until they are wet again.
I have a couple hundred board feet of QS Am Wh Oak and QS Oregon Oak merins stacked outside now. I rotate the stacks every few months. During summer months when it’s dry I soak and/or hose them down when they get dry, ~7% or lower. The way I see it, I can get an extra season or two on them doing extra wet/dry cycles during the summer.
An added benefit of soaking the wood is that it makes identifying heart wood from sap wood very easy. The sap wood soaks up a lot more water than heart wood and it swells more, making it super easily to see the sap wood.
Good luck. Otis
WithOrWithoutU2
OtisT wrote:Just my personal experience, I’m not a pro.
Good luck. Otis
Otis, thanks for the advice. I do plan to cut sticks to infuse in quarts, and 1/2 gallon jars. So maybe 6 inch sticks. But for seasoning, shouldn't I have a longer length and width than the actual size of the sticks? What size would you recommend if you think 3' x 4 1/2" is too long?
Also I assume QS = Quarter Sawed. I think they are just flat sawed. Would this change anything from your perspective?
OtisT
Post by OtisT »
WithOrWithoutU2 wrote:. Otis, thanks for the advice. I do plan to cut sticks to infuse in quarts, and 1/2 gallon jars. So maybe 6 inch sticks. But for seasoning, shouldn't I have a longer length and width than the actual size of the sticks? What size would you recommend if you think 3' x 4 1/2" is too long?
I cut as little as possible, so it depends on how clean the wood is. Maybe 1/8” shaved off the ends, unless it looks like you got mud or something else up in the grains, in which case I would cut until it’s clean. A little raccoon pee never hurt anyone. :crazy:
Yes, QS means Quarter Sawn. For sticks, it don’t matter how the wood was cut. The grain only comes into play for barrels.
WithOrWithoutU2
Thanks OtisT. You've been a big help.
WithOrWithoutU2
OtisT wrote: Mon Nov 19, 2018 10:45 am
So I've let these season outside this whole time. Been through 2 winters, 2 springs, 1 Fall and in its second summer now. I've not cut the board but am looking to cut them down and do some toasting.
Question: These things are completely gray. Should I clean them up any before toasting by taking a wire brush or sand paper to them? They are not dirty. Just wondering is I should sand/scrub off the grayed wood.
dukethebeagle120
Post by dukethebeagle120 »
Barrels are cheaper up here
And pretty well ready to use
OtisT
Post by OtisT »
WithOrWithoutU2 wrote: Thu Jul 23, 2020 4:32 pm
I don’t know what the experts do, but I always clean up the surfaces of what was seasoning before I use it. I personally think you should sand them first. Otis
Hambone
Post by Hambone »
OtisT wrote: Thu Jul 23, 2020 5:05 pm
+1 Otis. Scrape or sand....
SaltyStaves
Post by SaltyStaves »
WithOrWithoutU2 wrote: Thu Jul 23, 2020 4:32 pm So I've let these season outside this whole time. Been through 2 winters, 2 springs, 1 Fall and in its second summer now. I've not cut the board but am looking to cut them down and do some toasting.
Oak is difficult to cut wet. Its difficult to toast wet too. Air dry, or kiln it if you are in a hurry, but for future planning, you'll want at least 12 months for sheltered drying (to add on to the outdoor weathering).
I use my grandfather's No.4 Stanley planer. Never sand it.
cob
Post by cob »
+1 on not sanding use a plane if you really think you have to, but the wood doesn't need to be pretty,
toasting and charring will take care of that unsightly grey. do a small experiment with sticks cleaned
and not cleaned before heat treatment. you should find no difference.
dukethebeagle120
cob wrote: Thu Jul 23, 2020 8:35 pm +1 on not sanding use a plane if you really think you have to, but the wood doesn't need to be pretty,
Why not use a grinder with a wire brush to clean it up
Would speed things up
jonnys_spirit
Post by jonnys_spirit »
I’ve got various barrel heads and staves disassembled and stacked sitting outside in the elements for up to four years now (oldest). When i prep them for use i’ll take a stiff brush to them to mildly clean off any char and debris but not worry too much about it because i’ll filter before I bottle plus toasting and soaking in 125 proof for a year is going to kill anything living. When i cut them i leave them as large as I can fit into the aging vessel. 1 gallon large mouth glass takes a nice sized chunk and gallon jugs get the smaller cuts. Carboys of low wines, feints, and aging backset get the long offcut slivers or end bits because they may sit around for a while.
-jonny
SaltyStaves
jonnys_spirit wrote: Fri Jul 24, 2020 2:55 am I’ve got various barrel heads and staves disassembled and stacked sitting outside in the elements for up to four years now (oldest).
Why? Its already seasoned oak.
jonnys_spirit
Gotta store em somewhere lol.
-jonny
cob
Post by cob »
dukethebeagle120 wrote: Fri Jul 24, 2020 2:26 am
I was only trying to discourage sanding, because of grit, dust, and the possibility of residual adhesive.
Hambone
Post by Hambone »
After sanding, all grit or dust would be burned with charring....
WithOrWithoutU2
Thanks to all for advice.
I am in no rush, so I can shelter dry longer. Most likely just in my garage which is attached to my house.
The boards aren't dirty but I still may plane it down before toasting and charring.
OtisT
Post by OtisT »
It depends on how you are drying the wood, but it does not take a full year to dry out the oak I bring in from seasoning. After seasoning I bring it in and stack it (spacing between each board) near a forced air vent, so there is lots of air movement. Usually a month to two is enough. I use a moisture meter. My boards are typically around 9-15% when I bring them in and I want them at <5% before toasting. The area in and near knots retain water longer and require more time to dry.
At 5% moisture and higher I start to see some cracking in the wood when I toast it. If your wood is too wet when you toast, you can see wet spots appear on the wood where excess water is escaping and those spots are often cracked and swollen when the toasting is done. I guess if you are just toasting sticks that is not a problem. I’m making barrel heads, so this stuff matters to me.
Happy Drying.
Otis
Single Malt Yinzer
Post by Single Malt Yinzer »
3 years in the sun is where some of the pros find ideal for aging. Most can't do that due to the cost. The sun helps break down some of the chemicals into more flavor friendly ones. Heat (toasting & charring) also makes better flavors.
More here:
https://homedistiller.org/wiki/index.php/index.ph ... _for_aging
https://homedistiller.org/wiki/index.php/Wood_aging
