My stuff is almost all here
Post your builds here.
Dedant
Post by Dedant »
Nearly everything needed to put it all together and get down to it. Seals supplied are “alcohol safe” but are black. Others I have seen are white, not sure .
Fiddleford
Re: My stuff is almost all here
Post by Fiddleford »
Ant Your going to want to get or make some Teflon seals, just because it says alcohol safe doesn't inherently mean they are alcohol safe.
There are many threads a quick search will bring up on making your own PTFE seals.
PS.
I like the detailing on the drawers.. Makes them go faster
Rye whisky rye whisky oh dont let me down
Gunna have me a drink then gambol around
Here's some fiddle music
Pt1
Pt2
Dedant
Post by Dedant »
Thanks. My 28 yr old son and I did them when he was about 12. Had a matching desk too with chev hub caps ( 1/24 scale? ) inset in the drawer pull knobs . I dabble in a bit of pinstriping for fun .
Fiddleford
Thous are the memory's to keep eh, and stuff
Back to your still, in the rules we live by you should check out #8 and keep that in mind.. check out all of them really but keep an eye on 8
Pt1
Pt2
Swedish Pride
Post by Swedish Pride »
sounds like you don't like your gaskets, I'd give em three laps of ptfe tape and call it good.
saves you waiting for a delivery for em and is cost effective, it's just plain old plumbers tape.
You may have your own booze on the xmas table yet
Don't be a dick
Dedant
Post by Dedant »
Swedish Pride wrote:sounds like you don't like your gaskets, I'd give em three laps of ptfe tape and call it good.
Thanks, I have a decent quantity of oak aged corn/rye spirit. Using an old original still spirits super reflux . Tiny 1" column, runs at max 70% abv , I run cold and slow down around 60% , seems to carry flavour over. Moved into a new house 6 weeks ago and run through a TFFV, some of that is soaking strawberrys right now for New Year celebrations . I was thinking I could run off the first sacrifical product using the HPDE gaskets, in the new one as I'm not drinking the stuff anyway. I am missing a 25mm to 15mm reducer I need to finish the connection between the output and the condensor and as the plumbing supply companies have all closed down for the holidays I can't run it even if I get time to do the final ferrule to copper joins. So all I can do is wait. I have no packing as yet for the column except for some ceramic noodles intended for an aquarium filter, so pot still mode only will be the way foward for me. At least now I will have to learn cuts. :thumbup:
Dedant wrote:Nearly everything needed to put it all together and get down to it.
That looks like it will make a great rig :thumbup:
MoonBreath
Post by MoonBreath »
Boy oh boy, I remember how you feel..Chompn hard at the bit.
Merry Christmas and have fun. :thumbup:
Dedant
Post by Dedant »
Cleaning run underway, not using the reflux configuration yet, still have no packing organised. The big blue bucket is not part of it, just me not putting things away.
hellbilly007
Post by hellbilly007 »
Looking good. Don't forget the sacrificial alky run and don't drink it either :sick:
Dedant
Post by Dedant »
hellbilly007 wrote:Looking good. Don't forget the sacrificial alky run and don't drink it either :sick:
I have a birdwatchers on the go right now for just that.
