Transfer pumps
Transfer pumps
Anyone know of a good transfer pump that will use plastic tubing? Going from 14 gal mash tun to 14 gal fermenter
Re: Transfer pumps
I use this one https://www.cleverbrewing.com.au/pump-m ... 5watt.html" onclick="window.open(this.href);return false;" rel="nofollow
Re: Transfer pumps
Bad link Yummy.Yummyrum wrote:I use this one https://www.cleverbrewing.com.au/pump-m ... 5watt.html" onclick="window.open(this.href);return false;" rel="nofollow
- jimmayhugh
Re: Transfer pumps
Apparently we Yanks aren't allowed to access that site...Yummyrum wrote:I use this one https://www.cleverbrewing.com.au/pump-m ... 5watt.html" onclick="window.open(this.href);return false;" rel="nofollow
Code: Select all
Error 1020 Ray ID: 4bc349ae78365f69 • 2019-03-23 20:52:13 UTC
Access denied
What happened?
This website is using a security service to protect itself from online attacks.
Re: Transfer pumps
Try this one at good o’l flebay .... hope nanny lets you look there .
By the way mine is the same as pictured but With the plastic housing . The stainless housing is more .https://www.ebay.com/bhp/brewing-pump" onclick="window.open(this.href);return false;" rel="nofollow
Re: Transfer pumps
I wouldn't recommend one of these if your making beer
But it works good for what I need. Screw a short piece of garden hose to it and drop it in the fermenter
https://www.amazon.com/VIP25-Thermoplas ... 1-fkmrnull" onclick="window.open(this.href);return false;" rel="nofollow
Re: Transfer pumps
Chuggers are the standard for moving hot mash and wort around.
https://www.chuggerpumps.com/" onclick="window.open(this.href);return false;" rel="nofollow
Re: Transfer pumps
Chugger pumps are great and very easy to pull apart to clean. You’re just not supposed to run them dry.
Re: Transfer pumps
Can do that too now. https://www.chuggerpumps.com/product/xcpss-ci-1-115v/" onclick="window.open(this.href);return false;" rel="nofollowSharks_n_danger wrote:Chugger pumps are great and very easy to pull apart to clean. You’re just not supposed to run them dry.
Re: Transfer pumps
That’s good to know. I wonder if you can upgrade the older models with a new run dry head.acfixer69 wrote:Can do that too now. https://www.chuggerpumps.com/product/xcpss-ci-1-115v/" onclick="window.open(this.href);return false;" rel="nofollowSharks_n_danger wrote:Chugger pumps are great and very easy to pull apart to clean. You’re just not supposed to run them dry.
Re: Transfer pumps
Was considering a riptide pump, triclamp would makes it easy maintain.
https://www.blichmannengineering.com/ri ... -pump.html
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
- SaltyStaves
Re: Transfer pumps
I can't support Chugger after that hit job they did on Blichmann.
They created a youtube review of the riptide and told everyone how dangerous it was without disclosing that they were its nearest competitor. Reprehensible.
