shadylane wrote:Just wait until you ferment in the mashimizer.
Yeast LOVES the constant temp that a water jacketed fermenter supplies.
Mash, ferment and strip![]()
And be able to do it twiced a week
That's impressive.Fart Vader wrote:I dropped in a piece of 1" square tubing to demonstrate just how thick the sludge was (it did thicken up considerably during the strip).
When I scorch my element during a run, I use some giddle and fryer cleaner by the name Aumor Chef.. that was the best fryer cleaner when I was in the french fry business.. really cleans up an element in no time using the cleaner at full strength and a 3M scrub pad, clean with water after, done..Fart Vader wrote:Next was the cleaning operation. Wow, lot's of scrubbing to do.
Am I still using it?Asparknz wrote:Hey Fart Vader how is this rig working out for you? Are you still using it?
I have a question. Was there a conscious decision not to run the boiler under pressure? It seems to me a few extra pounds of pressure would make heat up a lot quicker
Just a couple of mis statements here. First when you pre heat stainless you do not want to use a carborizing flame. The last thing you want in your stainless is carbon from the preheat. Do not clean with sandpaper it will leave trace amounts of adhesives to contaminate the weld puddle. I use a stainless brush or metal burrs for final cleaning. Argon is the go to shielding gas. Helium mixes work well with stainless MIG set ups but SS TIG works well with Argon, plus Helium is very expensive . A bit over $200 a bottle last time I priced it. The Argon Co2 mix is for ferrous steels. Aluminum also requires pure Argon as a shielding gas. The proper setting for TIG welding Stainless is DC electrode negative. Never use pure tungsten for Stainless. use 2% ceriated or 1.5% lanthanated. I have found those to be very universal .Fruit Squeezer wrote:When tiging thick stock to thin, pre-heat the thicker piece with a gas/air torch, or a map-gas torch. Gas and air is better because you can use a rich flame to carbonize the thicker piece until the heat burns the carbon off, indicating it's hot enough to work.
Both surfaces should be sanded with a clean sheet of sand paper before hand.
For stainless, you MUST use pure argon or helium!
A lot of weld shops and suppliers are selling an argon/co2 mix because it's cheaper.... It works ok on aluminum, but stainless requires pure gas, not a blend.
You need to back-purge the under-side of your weld with stainless... It needs pure gas on both sides, or it will oxidize/"sugar". (I've seen videos of guys using stainless flux on the underside to shield the stainless, but haven't tried it).
If you're burning your tungsten, verify it is compatable with stainless, MAKE SURE YOU ARE ON DC NOT AC, check your ground, you should be electrode positive, shorten your tungsten length, purge more gas, don't weld in wind it will blow your gas away, and have a CLEAN tungsten sharpened by grinding down the length to a point, not ground sideways. if the tip touches the stainless, it MUST BE ground to a clean point again, EVERY TIME...IT MUST BE CLEAN GROUND!
One or more of these is your problem.
Thank buddy, good luck with your adventure.Allmyexsliveinhell wrote:so the steam from the double boiler is injected into the mash? genius.
I don't have any specs, but it was a swagelok type check valve. 1psi cracking pressure. Several available on fleabay.Gerben wrote:Fart Vader I really like the way you worked you're valve's in this project, do you still have the specs of the check valve, I found loads ranging from 1-160$
Fart Vader wrote:Thank buddy, good luck with your adventure.Allmyexsliveinhell wrote:so the steam from the double boiler is injected into the mash? genius.
Oh yea, and try not to get run over while you're at it
