The good news first. I just started a new job and got a smallish pay check and oddly enough a xmas bonus. And I've only been working there two weeks! Wow!
So this morning after I get off work and begin my "weekend" I decided to go and get a few more parts for my still. Had some really good luck today, but I'll mention that later in the post.
Just when I thought I understood how to set up the breakers and the wiring for my two elements, when I went to the electrical contractors supply store to get some of those parts, I ran into a few snaggs.
As I understood from my first post, I should use two 20amp breakers and make sure they were NOT on the same buss, or "in phase". It was also recommended NOT to use a dual pole aircon style breaker.
This is directly opposite of what I was told today. Mind you while asking for parts I had explained I was building an electric fermentator for beer making. NOT a still.
As we all know, breaker boxes have two hot leads and a neutral. For the sake of this example, I'm going called them hot left and hot right. My sub panel has 32 breakers slots. 1-16 on the left and 17-32 on the right.
What this electrcial supply person told me is this. Breaker 1 will draw it's power from hot left and breaker 2 draw it's power from hot right. If I understood what was said in the first thread is correct, this is exactilly what we want, no? In this case a dual pole breaker is what I'd be looking for, instead of two seperate breakers.
Folks, I know we've gone over this all before, but I really want to be carefull with working the power end of things. Besides, I have all the parts now except the my column pipe and the parts to connect up the elements.
Beyond wiring the breakers, I also need to know what style of outlet to get, what grade cord as well as plug.
Now, about controlling the primary element, my 1500watt one. I was actually looking for this at the electrical supply store, and according to this guy, there is no such thing. He did mention fan regulators, but they only have a 1amp ablity. Guess he never heard of that unit Knuklehead uses. Anyone know of something simlar here in the states?
tia,
Jaxx
Heating my converted keg part 2.... more confused then ever!
Jaxom
