Chinese stainless steel needle valves
Kindafrench
Post by Kindafrench » Fri May 03, 2019 1:41 am
Hey guys,
painfully, I had to figure out that the cheap chinese stuff I bought is just cheap chinese sh*t.
I bought these https://www.ebay.fr/itm/273559623184. One of them hat a little rusty spot, so I cleaned them all in 15 % phosphoric acid and gave them a bath in citric acid later, to cure the ss surface. They all looked pretty clean, indeed the bolt was made from a different material I guessed. Bit darker in color.
Today, they look like this :wtf: :
Part 1
Part 1
Part 2
Part 2
How stupid I am.
The body looks ok, but the bolt seems to be the problem.
Any advice what stainless steel needle valve to buy?
Thanks in advance.
Kindafrench
Re: Chinese stainless steel needle valves
Post by Kindafrench » Fri May 03, 2019 3:20 am
Oh boy, bought a Parker New Stainless Steel V Series Needle Valve 1/4 in FNPT 4F-V6LR-SS for 45 €.
Hope that one will last a while :D
Post by Yummyrum » Fri May 03, 2019 4:07 pm
That should work . :D
Shame you have to mortgage the house to buy a needle valve that doesn’t rust .
Chucker
Post by Chucker » Thu Aug 15, 2019 4:54 am
You know what they call that cheap, Chinese $h1t in China?
Export!!
Kindafrench
Post by Kindafrench » Thu Aug 15, 2019 4:56 am
Ja, lesson learned.
Chucker
Post by Chucker » Mon Aug 19, 2019 5:53 am
Swagelok, Yor-lok, Parker, Nupro, whitey. None of em are cheap but all should do what you need reliably.
Kindafrench
Post by Kindafrench » Mon Aug 19, 2019 9:16 pm
I‘m very happy with the Parker one, I bought. Can truely recommend that.
richard1
Post by richard1 » Tue Aug 20, 2019 10:07 pm
Whichever you buy ensure that the correct needle valve is purchased. Because it says needle valve doesn't mean it's of the right type. Of course they will work, but some better than others.
If you can and putting it in simple terms, get the one with the sharpest and longest point on the needle. With this, you will get the best results.
Master Distiller
Post by NZChris » Wed Aug 21, 2019 1:45 am
I use a similar valve to the one in the OP for the deflag water for my Bokakob. It works well enough for that purpose even though it has the same problems.
For the product valve for my Bokakob, I use a gate valve that I found in my handy junk collection. I filed a V into the bottom of the gate to give me better flow control and that works quite well.
manu de hanoi
Post by manu de hanoi » Mon Sep 02, 2019 7:42 pm
so far I'm satisfied with my dirt cheap chinese needle valves :
https://item.taobao.com/item.htm?spm=a2 ... t=8#detail
