Placement of thermometer on a pot still
stillanoob
HI All,
Work on my first still is proceeding. The pot is done and the cap/lyne arm should be done this week.
My question is about locating a thermometer. I want one in the vapor column. Should that be in the cap, the Lyne arm, at the end of the Lyne arm or?
Thanks!
Thanks!
Re: Placement of thermometer on a pot still
A quote from one of our old time classic members “Dnderhead”
viewtopic.php?f=65&t=13294&p=7586700&hi ... l#p7586700
Here is some great comments on the subject by members here:I whould think in the head of the of the thumper, but no matter where you put a thermometer in a pot still
its going to be as handy as a pockit in your underwear. learn to make cuts by taste and smell.
cayars
If it's a pot still you can stick it on the lid. You could also put it at the top of the column. It's going to be a point of reference for you to use so where in the vapor path really isn't that important.
Having a temp probe down in the boiler itself can be quite useful as well especially when doing mashes and you need to hit certain temps.
About as usefull as an ashtray on a motorbike.
StillerBoy
Temp in the column or at the top of the column per say in a pot setup, can be useful but not really needed there.. where a temp probe is very useful is in the vapour path just below the base of the column or somewhere around that location.. what the temp at that location will indicate, is what's happening as the boiler load is running and nearing the depleting during the run.. also if you want to stop stripping at say 50% overall average, after a few runs, you will know went to stop be at the mark, and similarly, if you want to stop at 30% overall average..
Mars
Mars
– Albert Einstein
– Albert Einstein
The Booze Pipe
The highest point in the vapor path; it should correlate vapor temp to %ABV on your distillate output (use it for reference in note taking). But don't run a still by temp, rather smell, feel, and taste (I usually go in that order). I always thought a thermo in the boiler would be helpful too.
13.5g/50L keg
12,000watts of fury
12,000watts of fury
To quote from another post
Is it really so hard to take a sample and use an alcometer to find the same thing ? Are people getting to lazy to get out of their chairs to do something that difficult?theholymackerel wrote: ↑Mon Dec 07, 2009 1:20 pm What makes ya think a tool designed to measure temp will give a more accurate measure of ABV% than a tool specifically designed to measure abv%?
Potstills really are quite boring and plain . Adding a Thermometer adds a bit of bling to an otherwise utilitarian looking still .
Mind you Wrapping some tinsel around it may be about as useful as a thermometer and prettier to look at.
I agree with Salty that if you want to know AVB , use your Alcometer . ..... Hey theres an idea .... build a Parrot
- jonnys_spirit
You can measure ABV by temp of the vapor. I keep a therm in the vapor path and keep notes on each jar in a spirit run so I can compare runs of the same recipe. I also keep a ttherm in the boiler for liquid temp - ie; if I need a particular temp for a mash and I'm heating water/backset..
Do your cuts by nose / taste / feel. I started keeping spirit run notes of vapor temp, amps, mL, and time duration for each jar so I can compare data points for same/different recipes and it does help in learning. Especially for example when I age a batch that I cut wider than I thought I should and am making it again.
-jonny
-jonny
StillerBoy
Why go through the steps to take a sample when a temp probe, position at the right location, will give you the very same data.. it has nothing to so do with being lazy.. just a different way of doing the same task..Saltbush Bill wrote: ↑Mon Jan 06, 2020 12:36 pm Is it really so hard to take a sample and use an alcometer to find the same thing ? Are people getting to lazy to get out of their chairs to do something that difficult?
Mars
– Albert Einstein
– Albert Einstein
OtisT
+1. An added benefit is that after you reach the cutoff point by temp, you don’t need to wash the damn tails oil off of the hydrometer and out of the measuring tube. If that makes me lazy, then call me lazy. I really don’t need either for most cutoffs, as I often go by smell and production rate, but if I’m targeting a specific cutoff point then I will use temp.StillerBoy wrote: ↑Mon Jan 06, 2020 1:02 pmWhy go through the steps to take a sample when a temp probe, position at the right location, will give you the very same data.. it has nothing to so do with being lazy.. just a different way of doing the same task..Saltbush Bill wrote: ↑Mon Jan 06, 2020 12:36 pm Is it really so hard to take a sample and use an alcometer to find the same thing ? Are people getting to lazy to get out of their chairs to do something that difficult?
Mars
If you heat water for mashing in your boiler, then also a +1 to also having a thermometer in your boiler below the liquid line.
Otis
- pope
My thermometer has four ports so I know the boiler, head, and parrot temps. And the air in the room just for the hell of it! Overkill? Yes. I don't need any of it but it's helpful and after a few runs the numbers start to mean something to me, but I don't make cuts or even switch jars based on anything other than smell and taste (on a pot still config). If I had to choose between the thermometer and the ammeter in my control box, I'd pick the ammeter. But even my amps is just shorthand for what I figured out by timing my flow rate.
OtisT
By feel?
is this dipping fingers in and going by viscosity, feeling the oils? Otis
cayars
Perhaps he meant taste and smell are usually enough?
Yes that is what I meant Otis. Viscosity and oilyness are both good indicators of abv. Spend some time feeling whats leaving your still......rub it hard between thumb and forefinger....or palms.....rub till it evaporates.......you will pick it up after a while. Smell what is evaporating as you rub.
Perhaps you should learn not to need gadgets to tell you everything cayars.
Last edited by Saltbush Bill on Mon Jan 06, 2020 3:20 pm, edited 3 times in total.
He means Feel . Salty showed me this method .
- NZChris
If it's in the charge, at least you can calculate the abv remaining in the charge. In the vapor path, the temperature isn't reliably related to the abv in the charge, or at the spout, because those relationships are affected by heat input, vapor speed, passive reflux, ambient temperature, air speed, etc.. Opening a door or fiddling with the power or the flame will change it.
The temperature from my top thermowell hasn't been read for decades. I could use it to tell me when distilling is about to start, but I feel the riser with my hand instead.
The Booze Pipe
A parrot is not a bad idea to spruce things up. I wouldn't try to change someone's mind, thermometer or no thermometer. It's just what I use. Like I said, it gives me something to watch and record.
I also feel the distillate - I rub it between my fingers and smell at the same time. When it's good high ABV it'll feel dry, lower ABV will feel slick.
13.5g/50L keg
12,000watts of fury
12,000watts of fury
The Booze Pipe
I use a sight glass to watch for boil, and I have it all timed (from notes) to know when to expect vapor in the column, and beyond.
13.5g/50L keg
12,000watts of fury
12,000watts of fury
- LWTCS
Didn't read through the link. But if Blanick Dog is in there, he would've surely recommended the sledgehammer...Bushman wrote: ↑Mon Jan 06, 2020 9:14 am A quote from one of our old time classic members “Dnderhead”Here is some great comments on the subject by members here:I whould think in the head of the of the thumper, but no matter where you put a thermometer in a pot still
The temps will never remain stable as alcohol is rendered out of the apparatus. Visual indicators like stream thickness and abv measurements are far more comprehensive.
StillerBoy
Chris.. you're talking about a different position of the temp probe that what I have stated.. you're stated that the temperature in the vapour path, and I'm a assuming that the vapour path means within the column isn't reliably..
I disagree with that statement.. yes there is difference of temperature between the vapours inside the boiler and just below the intake to the column of a few degrees.. but what I have been stating is that the vapour temp, and not the load/charge temp itself, at inside the boiler at the intake to the column, does indicate what abv is the load/charge and what will be the abv at the take off tube end..
Over the many years of acquiring data at that varies locations, that it tell me exactly what the abv of the load/charge at the start of the run, what the abv is during the run, what left in the boiler yet to be extracted, and where I want to stop the run based on the abv of the low wine I want..
I have no need to know what abv of the finish mash is, all that is required to be know is the mash/wash in size/gal, because the temp probe will tell me the abv level the minute it reaches the temp of equalization mark, both on the strip run and spirit..
Mars
– Albert Einstein
– Albert Einstein
I personaly dont give a rats if people use a thermometer or not. What I do mind is newbies being made to think that a pot still must have a thermometer and that having one will somehow make it easier to learn to run that still, make it easier to learn to make cuts and that it will result in better booze.
It will do NONE of those things......nor will it enchorage newbies to use ALL of thier senses to run a still and make cuts properly.
StillerBoy
In agreement on the quote..
It is one way of monitoring the abv, but there are also other ways to accomplishing the same task..
Mars
– Albert Einstein
– Albert Einstein
StillerBoy
It does make learning and running a pot still or reflux column easier to comprehend of what all is happening inside the boiler and column.. but all of the other indicators are also very valid and should not be discounted in the learning process..Saltbush Bill wrote: ↑Mon Jan 06, 2020 4:53 pm What I do mind is newbies being made to think that a pot still must have a thermometer and that having one will somehow make it easier to learn to run that still,
At no time, in this thread has it been implied that it will make it easier to make cuts or better booze.. operation of the still is not making cuts..Saltbush Bill wrote: ↑Mon Jan 06, 2020 4:53 pm make it easier to learn to make cuts and that it will result in better booze.
Mars
– Albert Einstein
– Albert Einstein
Garbage...it does not make learning to operate a pot still easier......it only serves to confuse those new to the game.
Open your eyes and read the countless posts on the forum written by newbies who cant get stills to operate properly because some clown told them that such and such would occur at this temprature or that. They then post questions asking why they cant get the still to work.
stillanoob
Wow. Quite a bit of, shall we say, passion on this subject.
I'll locate the thermometer near the top of the cap I guess. Thanks for the help!
As to anyone who would use only a thermometer to try to run their still and make their cuts: If they didn't have a thermometer, they would zero in on something else to obsess on to the exclusion of all other indicators. It is quite clear that there is a variety of indicators that need to be watched for and interpreted. As is often said, I am sure that I will use the thermometer for the first few runs and then less as I learn to operate the still.
- Corsaire
The thermometer on my pot is just below the highest point in the vapor path. I've never used it to make cuts or anything. Just as a rough guide how far I've progressed in the run. There is a correlation between vapor temp and abv, so as the temp approaches 100c you know your abv has come down. It's just eye candy. The resolution on the thermometer is far too low to be of any use, and I'm not even sure it's calibrated well. And I don't care either as I don't rely on it for anything.
The problem is that new distillers can fall into the temperature trap. They believe the best product comes when the temperature they measure is at the boiling point of ethanol. Which is not the best way to run a pot still.
Or they follow someone elses numbers like heads cut at x degrees then tails cut at y. It's far better to drive a pot by output, so roughly by increasing or decreasing smearing, and make cuts by taste and smell. Reading this thread, I might have to start feeling the product as well.
- NZChris
If you start with what product you want to make, then work backwards through the equipment, running protocols and ingredients, it's pretty hard to go wrong.
E.g. What Low Wines abv is desirable for the product you are making?
Find out, then put the alcometer in the collection vessel and run until you get that. No thermometers or parrots are needed for that.
Spirit run. Collect in at least twenty jars and choose your blend tomorrow. No thermometers or parrots are needed for that, just your nose and taste buds.
If you keep temperature records, those records will become your guide in the future as long as long as you have put the thermowell in a place that gives you consistent data, but don't make decisions based on it while you are still a newbie to the game.
I'm guilty of putting my first thermowell in a location better suited for a pencil holder. It wasn't long before I put one in the bottom, measuring the charge temperature. Even then, it is only used as an indicator for when to expect cut points, not for cuts 'on the fly'. Past temperature records let me know when I need to be running into jars around the cut points so that I don't have to use all of the twenty jars I calculated I needed and lets me cheat by running the obvious hearts into demijohns.
Thank you that is exactly one of my pointsCorsaire wrote: ↑Mon Jan 06, 2020 10:15 pm The problem is that new distillers can fall into the temperature trap. They believe the best product comes when the temperature they measure is at the boiling point of ethanol. Which is not the best way to run a pot still.
+1NZChris wrote: ↑Mon Jan 06, 2020 11:07 pm Find out, then put the alcometer in the collection vessel and run until you get that. No thermometers or parrots are needed for that.
