ceramic rings meant for using in an aquarium
I'm going to give these a try for column packing
zed255
Re: ceramic rings meant for using in an aquarium
Post by zed255 »
I have enough of a product called Siporax to fill my column, it is a sintered glass material made for aquarium biological filters. It is shaped like rasching rings but the material itself is open pore, so liquid / vapour can also move through it and not solely around it. I just need to do a new sugar wash to see how it performs against my copper mesh and marbles. Was pricey though, but we will see if it is a bust or not.
https://www.amazon.ca/gp/product/B000A2 ... UTF8&psc=1
Oh, I can't see your linked product Shady.
Zed
zed255 wrote: ↑Sat Feb 29, 2020 9:43 am I can't see your linked product Shady.
cob
Post by cob »
the photomicrography in the siporax link reminded of the sintered glass grill bricks
I posted back in 2012 the link is now dead but grill brick is readily available.
Is there any estimate for the volume of eg. #5 box?
looking forward to your opinion. Shadylane
edit; web search did not find sintered glass grill brick, only pimice.
Here's the SS packing I removed, the new ceramic rings and the best dephlegmator I've built so far :wink:
cob wrote: ↑Sat Feb 29, 2020 7:10 pm Is there any estimate for the volume of eg. #5 box?
Some were around 215 cubic inches or 3.5L
acfixer69
Post by acfixer69 »
Got a link to them shady. I am looking for a packing in my 4" I now run lava rock. I'm happy but always looking to improve.
Try searching amazon for
Aquacity Premier Bulk Bio Ceramic Rings Filter Media for Aquarium Koi Fish Pond Reef Filter.
I don't know how good their going to be, but they are about 3 times cheaper than Riesling rings
acfixer69
Post by acfixer69 »
Got it Thanks . Going to look them over. Be watching your results.
There was some white dust on the rings that was rinsed off.
Not much but some. There was maybe a big spoon full in the bottom of each 5 pound plastic bag
To do the required sacrificial run. the boiler was charged with around 6% clear water/ethanol
The CM rig was left in 100% reflux for a couple hours.
When the boiler was drained it had a slight white tint to it.
I'll know more about how these porous ceramic rings work after I've done a couple runs.
cob
Post by cob »
shadylane wrote: ↑Wed Mar 04, 2020 5:16 pm
thanks shadylane, that won't break the bank loading a column.
regarding my edit; I have a palm print on my forehead because
pumice is a form of sintered glass, similar to scoria but much
more porous, and considerably lighter.
netmastr32
Post by netmastr32 »
Here this looks like similar item a lot cheaper
https://www.amazon.com/Fluval-PreFilter ... 22&sr=8-16
If my math is right
The round rings I used cost $3.60 a pound and the polygon shaped rings are $4.50
acfixer69 wrote: ↑Wed Mar 04, 2020 5:41 pm I am looking for a packing in my 4" I now run lava rock. I'm happy but always looking to improve.
This would be a good option from what I've seen so far :thumbup:
Lava rock is good but this is better.
One things for certain, the rings out perform SS scrubbers or marbles by a bunch.
acfixer69
Post by acfixer69 »
shadylane wrote: ↑Thu Mar 05, 2020 3:37 pm
Will be looking into these are all one size fits all. :lol: I'll look I got a 48" 316 SS tube to fill.
acfixer69 wrote: ↑Thu Mar 05, 2020 4:38 pm Will be looking into these are all one size fits all. :lol: I'll look I got a 48" 316 SS tube to fill.
20 pounds of the 1/2" rings filled my 4" column 71"ish deep
I also saw some that were 5/8 dia X 11/16 inches long
But I ordered the smaller 1/2" x 1/2" because I thought they would probably work better.
acfixer69
Post by acfixer69 »
I think you are right with the 1/2 by1/2 that is bout the size of most of my lava rock.
StillerBoy
Post by StillerBoy »
acfixer69 wrote: ↑Thu Mar 05, 2020 5:31 pm I think you are right with the 1/2 by1/2 that is bout the size of most of my lava rock.
With lava rocks size wise, which I have been experimenting on and off for the past few years, indicate that size is very important, especially going down in size..
I don't have a 4" column, but on the 3" am down to about 5/16 - 3/8" in size from about 1/2", and each time I reduced the size, I got an improvement in take off rate..
On the 2", I'm at about 3/16 - 1/4" in size and matching the take off I was getting before downsizing on the 3".. so I'm in the process of making a batch of very small ones in size, maybe average about less than 3/16" in size..
So from my experience with size with lava rocks, I would have to support the smaller size rings..
Mars
– Albert Einstein
acfixer69
Post by acfixer69 »
Size matters for sure and 3" seam to be the funky point as a 2" is a popular column diameter choice, low cost so there is lots of input. With the 4" diameter it is pricey so most build plates, but only a tad more then 3" so there is less quantitative knowledge on 3" packed.
bronctoad
Post by bronctoad »
Shady have you done anymore runs with the ceramic rings?
how do they clean up after a spirit run?
Bronctoad
I'm not sure whether your asking about the rings or the spirit being cleaned up :lol:
After a couple runs, the ceramic rings look identical to new.
They do a good job. I'd recommend using them over anything else I've tried.
A friend normally uses 1/4 Inch Porcelain Berl saddles in a 2" column
He tried the ceramic rings and said they were as good, if not better and cost a lot less.
bronctoad
Post by bronctoad »
Thanks Shady
just needed a little more,( yup that's it! :shock: ) before I pulled the trigger :wave:
bronctoad
Avo
Post by Avo »
zed255 wrote: ↑Sat Feb 29, 2020 9:43 am I have enough of a product called Siporax to fill my column, it is a sintered glass material made for aquarium biological filters. It is shaped like rasching rings but the material itself is open pore, so liquid / vapour can also move through it and not solely around it. I just need to do a new sugar wash to see how it performs against my copper mesh and marbles. Was pricey though, but we will see if it is a bust or not.
Ths Siporax is an interesting product - I just found out that it's available on Ebay. Would the Siporax stand up to the generated heat; with expansion would the porous glass fracture :think: I guess you'll find out. Could be used with other column packing.
Kansas
Post by Kansas »
I ended up giving this a shot after reading this thread and it's been working great so far. Bought 6 pounds of the Aquapapa (lol) brand from Amazon and it perfectly fills my 3" x 36" CCVM column. Replaced marbles and works better. Can easily get azeo vs ~90% with marbles.
Thanks for the suggestion.
Thanks for the report Kansas .
Sounds like a winner
Mozzie
Post by Mozzie »
Took the plunge for my first build. 12lbs of 1/2 for a 4" * 41" section..
How / what are you guys using to hold these rings in place? I don't want to loose my marbles or rings. Oh yeah I don't have any marbles.
OtisT
Post by OtisT »
Mozzie, I use a 3” screen section clamped to the bottom of my 3” packed column. My rings are 1/4” and the holes in the screen are about that size, so I added a small piece of heavy copper screen just to make sure any small or partial ring bits don’t fall through or clog holes.
Ring size: Shady is using 1/2” rings in his 4” column. I am using these 1/4” rings in my 3”. I have not done any detailed experiments, but I’ve often wondered if my ring size should be a bit larger. I was thinking 3/8, not necessarily 1/2”, for my 3”. Right now, I feel like my power input is a bit limited before I reach flooding. I have a long list of things to do once I get my still up and running again, but trying a larger sized packing material is on that list. Once I get a larger size I will do some power comparisons with the different sizes to see where my power limits are.
Otis
pope
Post by pope »
Thanks for bumping this guys, I’m taking y’all’s advice and upgrading my lava rocks to these. Mozzie I tack welded as 60% open area perf plate of stainless into the bottom of a 4” pipe, similar to what OtisT has done. It works well.
seabass
Post by seabass »
Is the consensus that these work better than copper mesh packing? I've only used copper mesh and when I look at the hetp calcs on the main page, it looks like ss scrubbies outperform the ceramic rings by a considerable amount. I'm guessing copper mesh is somewhere between the ceramic rings and ss scrubbies in those calculators.
Are the calculators way off? When I plug in my info it tells me I should get around 10 theoretical plates with scrubbies and 5 with 6mm rings. That's a hell of a difference.
zed255
Post by zed255 »
I think some of the calculator data might be suspect. My last reflux run using marbles outperformed my copper mesh, which in theory shouldn't happen.
Zed
