Pressure cooker still
SGB
Post by SGB »
Hello, I live on an island and with limited materials. I have a pressure cooker and some copper pipe from an old air conditioner . The copper pipe is just big enough to fit over the spout on the pressure cooker and about 3 meter long. As a test I ran water through it today to see if it would work . It did drip out some of the water but it also looked as though the pot was building up pressure to do so although even though not as much as when cooking food it still was worrisome . Because of my location it is not at all possible to mail order anything beyond using mud and bamboo so using the pressure cooker seemed an easy still build to do. As a total newbie in searching through the forums here I have seen some that say pressure cookers are dangerous, that the boiler should not have or at least very little pressure as well as the rubber lid gasket.
Has anyone successfully used a pressure cooker here?
Corsaire
Re: Pressure cooker still
Post by Corsaire »
Any pictures?
Is that spout a valve? Perhaps you can take the valve stem out.
What's the cooker made of, stainless or aluminium?
Ditch the gasket, see if you can use flour paste as an alternative
A stainless steel cooking pot sounds like a better solution.
SGB
Post by SGB »
Thank you. It is a stainless steel pressure cooker. The spout is the same part that the pressure weight would rest upon. Trying to find a large Stainless Steel pot may not be so easy. Most pots are aluminium here.
Research on the forum using a pressure cooker as a boiler. There are a lot of suggestions for safety and modifications you should be aware of. Good luck!
SGB
Post by SGB »
OK I ditched the pressure cooker because I need it for cooking
and will try this. I hope it doesn't end up in the what not to build category
SGB,
The stock pot looks fine.
But the tubing looks too small (diameter). Vapor velocity will choke the flow much like blowing through a long, small ID hose...you can only pass the vapor (mass flow) a limited flow rate. And with the worm causing the collapse of vapor (condensation), you’ll have severe problems with “huffing and puffing”. It will be difficult to adjust the vapor production for smooth flow at the spout.
I suggest using tubing with 10mm to 12mm ID (1/2”) instead.
Also, make sure that the worm spiral coils consistently “downhill”. You certainly don’t want liquid pooling inside the worm/vapor tube, as it can cause a “plug” in the flow. That can create a pressure build up in the boiler.
:esurprised: Classic :ebiggrin:
stillanoob
Post by stillanoob »
SJB, the world needs more people like you. I would be honored to share a drink with you. Great job doing what ya had to do to make a drop.
Make sure to tell us about what yer cooking and how it comes out.
SGB
Post by SGB »
still_stirrin wrote: Fri Apr 10, 2020 5:23 am SGB,
Thank you, I will look for that size, I'm not sure though if I will be able to find it. Most copper pipe size I have seen is either brake line size or refrigerant (small) . The size of the worm tube is 3/8 or about 8 or 9 mm ID and the whole length of the pipe from pot to cup is about 3 meter /10ft. ....I can get more
Should I position the cooker/ boiler higher than the condensation cooler to get a down hill flow. ?
Because you are in the tropics you shouldn't have problems in the rising section of the pipe, but if you do you will hear gurgling. Wrapping that section should fix that.
The biggest problem with small pipe and a small still is the potential for blockage. Don't put anything in the still that is large enough to block the pipe, especially in a still made out of a pressure cooker. If you have a blockage, the pressure needs to pop the lid off easily at low pressure to keep you safe.
SGB
Post by SGB »
NZChris wrote: Fri Apr 10, 2020 11:26 pm Because you are in the tropics you shouldn't have problems in the rising section of the pipe, but if you do you will hear gurgling. Wrapping that section should fix that.
Thank you , I ditched the pressure cooker and will use an old stainless pot and lid I had for cooking rice. (I actually need the pressure cooker for cooking, AND when I did a test run with water it just looked way too dangerous in that if the pressure increased too much the whole thing would blow up.
I have some rice that's been fermenting for about a week and some bananas too.
Bananas I have in abundance for free that is why I want to use them. They usually sit around, turn black and end up in the compost. I took the over ripe black bananas peels and all and mushed them by hand in a pot on the stove to warm them before adding the yeast. The bananas have been fermenting with some local yeast balls for a couple days and they were black and already smelling alcoholic before mixing. I guess I'll let everything go a little longer and later give it a try( not sure how long at all but today the mixture has separated with the clear bubbling liquid below )
And I will definitely make sure to strain everything as clean as possible before putting it in the pot boiler.
Thank you everybody and homedistiller for all your help
Be safe SGB
( btw, what do you mean by wrapping that section?)
This is the reason why you should seriously try to upsize that copper . If you were just running a pure sugar wash, I’d not be so worried .
But I know you want to do the Shochu with sweet potato .
viewtopic.php?f=27&t=47369#p7199017
SGB
Post by SGB »
Yummyrum wrote: Sat Apr 11, 2020 3:19 pm This is the reason why you should seriously try to upsize that copper . If you were just running a pure sugar wash, I’d not be so worried .
Yes, it's true. The rice wine I'm making now, it's possible to save in the fridge until I have enough to distill or do I need to marathon rice cooking several kilos at once as I have read others doing?
As for the bananas, I looked at them today and the top had started molding, so I guess I did something wrong.
The yeast I have is rice yeast, maybe should use bread yeast.
What I'm doing with the rice is basic local style, cook a kilo, spread it out to cool, crush 3-4 yeast balls ,put it into Tupperware containers after about 10 days strain the liquid and save for later and repeat.
The bananas, about kilo black bananas with peals to liter warm water ratio and 3-4 yeast balls and put into Tupperware container for 4-5 days I guess.
I don't touch or stir the bananas or rice but do keep the corner of the lid cracked to let out any pressure build up.
My plan was to save the liquid from each until I have enough to distillation in the pot boiler
I hope I'm on the right track.
I got a ton of bananas so I will try again, they started off smelling so good but then smelled like palm tree wine
Bread yeast and rice 'yeast' are very different, so don't get confused.
There is also this starter that may be helpful, but not many here have tried it yet.
viewtopic.php?f=3&t=76531
SGB
Post by SGB »
NZChris wrote: Mon Apr 13, 2020 12:04 am Bread yeast and rice 'yeast' are very different, so don't get confused.
Yes, lot of Angel yeast products at the central city. I actually have been using Angel yeast for baking bread for years, just never looked for the wine pack before but I'm sure it must be there because there are all sorts of Angel brand yeasts and enhancers . Next time I go down there I will look for the wine pack. The local yeast balls is what everyone uses here, for fermented rice packets, the yeast balls are made from rice and some other plant elements . ( being, rice, garlic, chili pepper, white pepper, and some herbs)
thank you very much for your time and interest in regards to helpful information and links. It is greatly appreciated, thank you again, SGB
cob
Post by cob »
please be aware of your local laws on your dry island, there are some countries
that make a practice of removing body parts for distilling in a dry country
Dyre
Post by Dyre »
Bananas seams to have some uniqueness when fermented. I haven't tried this yet, but it on my list and I thought SGB may find it useful.
https://moonshiners.club/banana-moonshine-recipe/
Royco
Post by Royco »
Hi SGB I stumbled upon this rather late, but can say I had a very similar startup with limited access to materials due to lockdown. My pressure cooker setup is very similar to your pot rig and it works fine, just a bit small (11 liters, ie max 8 liter wash).
Could only get 3/8"tubing and used the full length, 6m. It is actually much longer than needed as the tube is cold within the first meter.
Almost ready now with a 50L tea urn conversion with Liebig condenser using 1/2" vapour tube. To compare what you are doing here is a pic
