I’m thinking about using this as a way to easily connect my still to the worm. Yes or no? It has some type of rubber gaskets.
Vapor line question
Re: Vapor line question
Worse than that , the whole thing is Rubber with a pretty stainless steel braid over it .
Definitely do not use
Excellent for connecting water lines to /from/ beteen condensers though .
Ok, thanks. I discovered that after I posted haha. I should delete before I get blasted.
All good , I’ve just moved it to a more appropriate place .
Yup, the only thing these are really helpful for would be as a diffuser in your thumper, but you'd have to cut the connections off, pull out the rubber tubing inside, and fasten the braid to SS or copper fittings. Otherwise a big no no for hot alcohol vapor
i'm here to kick ass and drink whiskey, and pilgrim, i'm out of whiskey
- Stillin-Hearts
Similar “laugh-at-myself” moment today. I was looking at buying brass fittings and had a minor complex about brass on a still- and then remembered I was working on the condenser water lines. Hehe.
