Questions with stripping run
Tabucowboy
Post by Tabucowboy »
My still is setup in pot still mode with 3/4"(19mm) over 1/2"(12.7mm) condenser 44"(1.1m)
1. I can pull off a qt every 10 min but it is only 55 proof. Is there anything wrong running that fast or should I go for a higher proof?
2. Is it ok to have copper scraps in the kettle? I have read it somewhere about if you can or not but can not find it. tried searching for "copper in kettle" "copper scraps".
3. if using Sodium carbonate in stripped liquor to remove esters how much to use in qt or L?
CM Reflux Still -- Copper mesh 16" ,column 31" tall, dia. 2",temp at boiler,top of column, power - PAC w5500w Element
Pot Still -- Copper mesh 16",column, 23" tall dia. 2", temp at boiler, power - PAC w5500w Element
This topic has 5 more replies
Register Login
