Brown vs. White Sugar results
So just want to confirm something.
Firstly I changed from BWTPW to SSSW. The resultant taste from the low wines is markedly different with Shady's being significantly cleaner more neutral and better tasting, can't wait for the spirit run.
So with Shady's the first wash was with brown sugar and was a rapid ferment taking 3.5 days.
The second wash was identical but for the brown sugar making way for white sugar. The white sugar wash is much slower in progress that the brown sugar. The time is not an issue though.
For curiosity, does the brown sugar ferment easier than white?
Re: Brown vs. White Sugar results
brown sugar is less refind. so to me only way to measure the speed is if you have identical og and fg. i think per weight brown sugar will have less fermentables but the speed can have other factors influencing it as well.
My first flute
My press
My twins
My controller
My press
My twins
My controller
Setsumi said it right, brown sugar has some unfermentables that contributes to sg, lots of minerals, etc.
If you take only this to compare, brown is faster due to the presence of nutrients for yeast, but if you provide lots of yeast, it may not make much difference
If you where trying to make a clean neutral wash why would you use brown sugar?
This isn't quite true. If you're referring to common brown sugar, it's actually standard refined white sugar with a small amount of molasses added back to it.
Similar to a molasses ferment, there shouldn't be much in the way of nutrients which needs to get added; a small amount of epsom salts.
+1 to what Saltbush said. If you're goal is neutral, only use white sugar based (or similar) low flavor recipes.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Just guessing
Brown sugar and white would ferment the same.
Brown sugar, is white sugar with a tiny amount of molasses added to it.
The difference in fermentation speed and flavor between the two recipes, is due to the extra nutrients and pH control
- rubberduck71
I think I remember reading somewhere on the site that "brown sugar" title differs depending on which part of the world you live in?Expat wrote: ↑Wed Sep 16, 2020 1:58 pmThis isn't quite true. If you're referring to common brown sugar, it's actually standard refined white sugar with a small amount of molasses added back to it.
In the U.S. brown sugar is indeed the same as white sugar with molasses added back in, as mentioned above. But in other places of the world, it's "unrefined sugar" which still has the molasses naturally left in it.
I could be wrong. Like I said, just a fuzzy memory of reading about the same topic elsewhere on this site...
Its called the learning curve Saltbush Bill, takes a long time to become an overnight success. As we exclusively use brown sugar at home it was my go to sugar for no other reason and for lack of experience. Subsequent reading caused me to move to white sugar when I decided to try Shady's recipe.Saltbush Bill wrote: ↑Wed Sep 16, 2020 1:28 pm If you where trying to make a clean neutral wash why would you use brown sugar?
Tough to be a newb on this forum.
Saltbush Bill wrote: ↑Thu Sep 17, 2020 4:32 amThink things are tough now?.....should have been around a few years ago.
Not sure if this helps , but here in Aussie we have Raw sugar which is from first extraction . It has quite large crystals and is a pale yellow colour . The refined sugar after another extraction is white . This is the normal sugar we buy for general cooking and making neutrals .Caster sugar is refined sugar which is ground down to a finer consistantsy . Brown sugar is caster sugar with molasses mixed through it .
From top to bottom is refined sugar , caster sugar , raw sugar and brown sugar . Refined and Caster sugar . Raw and brown sugar
You are right about differences on brown sugar around the world. Here in Brasil brown sugar is the same as powdered panela sugar. Was quite shocking to me when I discovered that some places put molasses back into refined sugar.rubberduck71 wrote: ↑Wed Sep 16, 2020 4:08 pm
Also we have "melaço" = molasses and "melado" = fancy molasses (panela sugar with some water left in it)
I find that my white table sugar washes ferment significantly faster if you use it to make Simple Syrup first. Supposedly inverting the sugar breaks the sugar chains into parts yeast can more easily convert and it supposedly makes it taste better or have better mouth feel. 10# sugar, 5 cups water and 0.25 tsp Citric Acid. Boil for 20 min and you're done. I add the syrup to the fermenter while it's still hot. After adding water and other ingredients the temp is usually just right for yeast.
Cool the syrup a bit so it is safe to carry.NineInchNails wrote: ↑Thu Sep 17, 2020 4:09 pm I find that my white table sugar washes ferment significantly faster if you use it to make Simple Syrup first. Supposedly inverting the sugar breaks the sugar chains into parts yeast can more easily convert and it supposedly makes it taste better or have better mouth feel. 10# sugar, 5 cups water and 0.25 tsp Citric Acid. Boil for 20 min and you're done. I add the syrup to the fermenter while it's still hot. After adding water and other ingredients the temp is usually just right for yeast.
Put some of the water in the fermenter (if it is not metal) first or you might damage the fermenter with the hot syrup.
True. I should have elaborated. I do have approx half the amount of water in the fermenter first. Then add water and test SG incrementally.The Baker wrote: ↑Thu Sep 17, 2020 4:45 pmCool the syrup a bit so it is safe to carry.NineInchNails wrote: ↑Thu Sep 17, 2020 4:09 pm I find that my white table sugar washes ferment significantly faster if you use it to make Simple Syrup first. Supposedly inverting the sugar breaks the sugar chains into parts yeast can more easily convert and it supposedly makes it taste better or have better mouth feel. 10# sugar, 5 cups water and 0.25 tsp Citric Acid. Boil for 20 min and you're done. I add the syrup to the fermenter while it's still hot. After adding water and other ingredients the temp is usually just right for yeast.
Thanks, 10# would that be 10 pounds?NineInchNails wrote: ↑Thu Sep 17, 2020 4:09 pm I find that my white table sugar washes ferment significantly faster if you use it to make Simple Syrup first. Supposedly inverting the sugar breaks the sugar chains into parts yeast can more easily convert and it supposedly makes it taste better or have better mouth feel. 10# sugar, 5 cups water and 0.25 tsp Citric Acid. Boil for 20 min and you're done. I add the syrup to the fermenter while it's still hot. After adding water and other ingredients the temp is usually just right for yeast.
Yes, # in north america can mean lb
EXPAT
___________________
EXPAT
___________________
Yes # means pounds. It never made sense to me why lefty potato heads would put '# Me Too' in their social media. Always made me laugh.
Lol.... pound me too.... Doesn't work quite the same
EXPAT
___________________
EXPAT
___________________
So we add the sugar to boiling water I assume to avoid caramilisation? I also assume the heat is just enough to simmer rather than to boil furiously?
Look up Invert Sugar.
It works fine to add the sugar to cold water and stir from time to time with say a wooden spoon or a flat small wooden slat.
Yes, simmer for I think twenty minutes or so.
Add lemon juice or citric acid to simmer with the sugar...
But look it up. Anyway Nine Inch Nails has told you...
Where I live, it is far cheaper to use white sugar and add some molasses than to use brown sugar, or raw sugar.
Boiling sugar, especially with some added acidity, will invert it and the yeast can convert that into alcohol faster, but whether or not it is worth the energy costs and bother is something for you to think about and research.
If I'm using backset for the next generation of a sugar wash, it always goes onto the sugar hot because the energy to invert the sugar is free.
Ive read a lot of threads and opinions on inverting sugar on different forums.
Its a subject thats been flogged to death many times over.
It seems to me that most folk dont think the benifits are that great..as Chris said ,probably not worth the time or energy.
Personaly ive never done it and dont plan on it any time soon.
Where I live it is very difficult to find real unrefined cane sugar. Once I saw it in the supermarket, it already had a strong aroma even with closed packaging and had a "pasty" consistency in the sense that if you press with your fingers, the mark remains. Do you confirm this?Yummyrum wrote: ↑Thu Sep 17, 2020 6:08 am Not sure if this helps , but here in Aussie we have Raw sugar which is from first extraction . It has quite large crystals and is a pale yellow colour . The refined sugar after another extraction is white . This is the normal sugar we buy for general cooking and making neutrals .Caster sugar is refined sugar which is ground down to a finer consistantsy . Brown sugar is caster sugar with molasses mixed through it .
From top to bottom is refined sugar , caster sugar , raw sugar and brown sugar .2E5F81E6-8D12-4F75-9A91-8B4649149F1D.jpeg
Raw and brown sugar
I am of the same opinion. Perhaps with inverted sugar the yeast makes a slightly less effort but the yeast itself already has all the enzymes necessary to break down the sugar and ferment it. It is like for us having to peel an apple or eat it already peeled.Saltbush Bill wrote: ↑Sat Sep 19, 2020 11:31 pm Ive read a lot of threads and opinions on inverting sugar on different forums.
I've had unrefined sugar that just about needed to be cut with an axe and have one that is soft and gooey and bleeds molasses. I've had light colored that has been evaporated under vacuum and dark colored from being boiled over fire. If it tastes good, it's good for rum.
You don't need to run at a continuous, strong, rolling boil, just simmer it to maintain 'boiling temp'. You don't want to boil over (which it can if you're not paying attention at high flame) and you don't want it to scorch either. I specify 'Simple Syrup' because it requires much less water than most 'invert sugar' recipes. That means Simple Syrup is quicker to make, less volume to bring up to temp. Once brought up to temp, simmer for 20 min and you're not going to get anywhere near the temp required to caramelize the sugar.
That sounds like what we call brown sugar here ... IE. its caster sugar with molasses mixed through it hense the smell and the way it mushes or clumps .
Raw sugar is just crystals like white sugar .
I've tried it several times and didn't see a measurable advantage to inverting sugar.Saltbush Bill wrote: ↑Sat Sep 19, 2020 11:31 pm Ive read a lot of threads and opinions on inverting sugar on different forums.
I even tried using Alpha and Gluco enzymes to convert sucrose into glucose, that didn't seem to make a difference either.
- rubberduck71
Ok, dumb question: if i just maintain high temps (call it 190F or above) for 20 min or so with citric acid & dumped white sugar, does that count as inverted "enough?"
I'm lazy. Usually I have a run going when I'm running an inverted sugar process on the induction plate.
