Dockem81 wrote: ↑Tue Oct 27, 2020 3:28 am
I would be eager to read up on power controllers vs PID controllers, if I have the time.
Yes, I have watched some of his videos and he peaked my interest in a few recipes, etc. But his rambling on started to drive me nuts. I've caught some of Still It and "Beard" videos also. Take everything with a grain of salt.
if you are just using the digi as a boiler, there is a very simple mod, which would connect the live from the on/off switch to the element switches.
this would also keep the screen, temp sensor and overload sections working.
then you could get a voltage controller and plug the digi into that.
i used mine today for the first time on a strip run, both elements on full to reach boil, turn voltage down to about 90v for slow fores take-off, then full blast after that.
the volt controller will be particularly useful on spirit runs (reflex & pot) when the boil has to be controlled to keep the vapour speed at a consistent rate, which can only be achieved by controlling the voltage.
i joined about the same time as you and it took me a while for the penny to drop lol
you do not ,and cannot control the boil temp, and the temperature gauges are just for additional casual reference during the run.
ie if the mash you are heating ( a mixture of water/ethanol/etc) has a boiling point of 83.65c, that's what it will boil at. no more, no less.
as the vapour leaves the mash, the remaining liquid will have a different ratio of water/ethanol/etc and the boiling point will change slowly.
think of heating pure water with whatever size element you can get, it will always boil at 100C (altitude dependant obv), whether you have a 500w or 5000w element, the only difference will be the amount of vapour.
then you have to marry up the vapour speed with whatever method of cooling management/takeoff arrangement your still has.
so i think the only way to control the rate of vapour, and therefore obtain reflux and/or consistent separation, is by altering the voltage.
that is my theory anyway
PS dockem, please don't mess with the electrical wiring if you don't know what you're doing, get a sparky mate
