Chinese still worth it?
RevA
Post by RevA »
Hi,
I'm looking at getting a small still just to play around with different washes and flavors. It gets a bit expensive to make 10-20 gal washes that are not something I'd like a lot of. Does anyone know if the Chinese stills that are basically a stainless pot with a copper worm attached can make decent moonshine?
Reason: removed unwanted advertisment
Re: Chinese still worth it?
Do you have a link to the still you are referring too so members can evaluate it.
RevA
Post by RevA »
Bushman wrote: Sun Oct 25, 2020 9:16 am Do you have a link to the still you are referring too so members can evaluate it.
https://www.banggood.com/2GAL-or-3GAL-o ... rehouse=CN
It is one of these basically
CopperFiend
Post by CopperFiend »
Yeah I've got one of those. Was my first. It is really really slow, very easy to puke and a bugger to clean. The worm is never in a fully downward position no matter what you do with it, so there are always pockets of liquid that pool. Useable, but I'd recommend building a still any day.
You get what you pay for.....cheap usually means exactly that.
Deplorable
Post by Deplorable »
If you want a small still, you're better off getting a 8 gallon milk can boiler and building a pot still and a liebig or a shotgun condensor. I wouldnt dink around with a worm condesner personally.
Edit: I'll just add that after you make yur first good batch of booze, you'll be upgrading anyway. Plan accordingly...
Deplorable wrote: Sun Oct 25, 2020 9:13 pm I wouldnt dink around with a worm condesner personally.
I've recently bought a European copper alembic that came with a worm condenser. I automated the worm and I'm very impressed with how well it works. Cool product out and very hot waste water to the drain.
Deplorable
NZChris wrote: Sun Oct 25, 2020 9:25 pm
You, my good sir, are the master of automation. You seem to have all the cool widgits and whizbangs. I wish you were into pictures Chris, I'd love to see your collection of solenoids, valves, and other tricks. :wink:
This one is too easy.
Drop the thermocouple into the flake stand to the height of the condensate outlet.
Use any cheap fleabay/whatever solenoid valve and controller to gravity feed water into the bottom of the flake stand. I use 12V DC because sometimes I run off-grid. Overflow into a bucket and use the hot water to clean up after the run.
Alkyholik
Post by Alkyholik »
I just did my 1st wash with a similar still from china and worked great. Mines is a 3 pot version. I posted about it asking if they were any good, before I did my 1st wash.
From 18l I got 2.7l of fair neutral alcohol
