I have a 1/4 stainless needle valve. I’m not sure if it should be upstream or downstream of the condenser?Getsmokin wrote: ↑Sat Nov 28, 2020 12:39 pm On the same lines as your build.
You will need a very fine adjustment water valve.
https://r.tapatalk.com/shareLink/topic? ... source=app
Dephlegmator Comparision
30xs
Re: Dephlegmator Comparision
- zed255
You may also benefit from a pressure reducing valve / regulator on your water supply. A cheap valve with little range of adjustment at full line pressure becomes much easier to use at 10 - 15 psi. Just a thought.
Zed
Zed
Looks great 30xs
I notice you are making two units with different copper ferules . One has a gasket groove , one doesn’t . Did you make or buy these ?
30xs
One view is the top with no ferrule, the other is the bottom with ferrule setting in place. Both will have a gasket groove once completed. It’s all one unit in the pictures, just from different angles. The top view is probably what you were referring to and is just the 2” side of the reducer. I was trying to show the top side of the coil through the opening. Went back and labeled the first two images.
Getsmokin
A valve works better after the condenser (no air bubbles in the condenser), but 150f hard water will leave a scale at the outlet that will mess with a needle valve eventually.30xs wrote:I have a 1/4 stainless needle valve. I’m not sure if it should be upstream or downstream of the condenser?Getsmokin wrote: ↑Sat Nov 28, 2020 12:39 pm On the same lines as your build.
A dephleg's is less likely to leak if the valve is on the inlet side of it.
- acfixer69
I like all condensers including deflagmaters to be regulated on the output because that is the only cooling temperature that matters. It should not leak regardless.
30xs
I’ve been running my needle valves on the output side of both the RC and the condenser. I’ve only done one run since swapping over to separate feed lines. I this was the first time I’ve been able to achieve a gradient to my shotgun and adjust the dephleg separately. I did have a couple times where out of the blue my shotgun would get hotter than I wanted. A sniff near the output seemed to have some vapors slipping out. A quick crack open on the needle and return and it would return to the gradient for an hour or so and then start climbing again. Maybe it’s time for a scale check, it ran a few previous runs on a recycled water barrel. Something seemed to be interrupting flow ever so slightly and causing the issues.Getsmokin wrote: ↑Sat Nov 28, 2020 5:08 pmA valve works better after the condenser (no air bubbles in the condenser), but 150f hard water will leave a scale at the outlet that will mess with a needle valve eventually.30xs wrote:I have a 1/4 stainless needle valve. I’m not sure if it should be upstream or downstream of the condenser?Getsmokin wrote: ↑Sat Nov 28, 2020 12:39 pm On the same lines as your build.
30xs
The finished product. May be a little bit before I can test it, but here it is.
That is copper porn
- SassyFrass
- Location: Sittin' on the side of the Mountain sippin' and smilin'
This is just plain interesting information/experiments. I've never built or run a reflux. I've always run a pot for what I drink. But now yall done got me wanting to experiment with this. Reckon I'll be doing alot of reading....thanks [emoji849]
Real good info for New Folks:
Ain't nothing wrong with a potstill
99% of the fancy plated or packed columns, are setting on top of one.
- SassyFrass
Ain't that the truth,shadylane wrote:Ain't nothing wrong with a potstill
99% of the fancy plated or packed columns, are setting on top of one. [emoji38]
but learning new things and ways is why I'm here. I made likker the way I learned as a kid. Never learned or knew the science behind it. Hell, going from wood to propane was a big step for me. Now I'm looking at reflux and electricity...just taking baby steps.
Maybe this old dog can learn a few new tricks.
SF
30xs
Running off the dedicated lines from the well last night says that scale is going to be an issue. I had to keep tweaking the dephleg needle and could hear it popping crap through it occasionally. I’m going to try moving the valve to the input side. My outlet has a 90* fitting pointing up and then a 180* bend down. That should help keep air out of the system, I hope.Getsmokin wrote: ↑Sat Nov 28, 2020 5:08 pmA valve works better after the condenser (no air bubbles in the condenser), but 150f hard water will leave a scale at the outlet that will mess with a needle valve eventually.30xs wrote:I have a 1/4 stainless needle valve. I’m not sure if it should be upstream or downstream of the condenser?Getsmokin wrote: ↑Sat Nov 28, 2020 12:39 pm On the same lines as your build.
Edited to say it didn’t stay that way. Flow control was much more stabile after the condenser other than the limescale slugs. It may be simpler to tie into the municipal water for my dedicated feed, or at least install a drop I can use for the dephleg supply when needed.
30xs
Built this out of a ferrule that I messed up for a recessed plate. Learned a bit in its maiden voyage. It’s probably about 7’ of 3/8 o.d. soft copper. What I did learn is that overkill knockdown on a dephleg is a bad idea.
On four plates with water 1qt per minute gave me a drip, drip takeoff
Same four plates with cleaning alcohol at 2700 it took two minutes to fill the same quart at the same drip rate.
What I took away was the more knockdown you have the harder it is to make small takeoff rate adjustments, even with a needle valve.
On a packed 4” column running 6,000 watts it may be ok, but still a bit touchy. Anything less and it needs to have less coils. I’m wondering if a pressure reducing valve on the water supply would make adjustments easier for lower wattage?
Overall the coil design is very efficient and much simpler to build than the shell and tube. Maybe this will help some newer builder
Reduce the pressure, a 1/8" needle valve or fewer coils would work.
30xs
Does the above read both a pressure reducing valve, and either an 1/8” needle or coil reduction? Or saying reduce pressure, but that could be done with the 1/8” needle? I’m looking at a couple cheap reducers since I only have to plumb it into a dedicated 1/2” copper line. I can order the needle and required fittings while I’m at it, if needed.
I'd start with removing a couple coils.
When I first built a coiled dephleg, it was too big.
I reduced the # of coils and used a small valve.
Some of the folks here are using adjustable pressure regulators.
30xs , I’m finding it hard to imagine you have 7’ coiled up there . Nice tight turns though
Did you use salt ?
30xs
I used some glass media out of my sandblasting cabinet. Annealed everything as I went. The media stayed loose enough that a little light tapping shook it all back out. Last time I tried salt it was slower to remove waiting for the water to dissolve. Blasting media I highly recommend. I could wrap around a piece of 3/4” copper pipe without kinking, as long as I made sure the sand was shaken down tightly.
I’ll try and run a seamstress tape around it to confirm the length, but i think I started with 8’ and used it all but about a foot.
- LWTCS
+1
House hold plumbing is perfectly capable of holding pressure. If your HX is incapable of holding pressure then it is simply poorly constructed.
Regulating flow from the discharge side allows for prevention of syphoning.
As long as a pressure increase does not affect cooling capacity, regulation of flow is superior on the discharge side of the HX.
30xs
I agree with the regulation after the condenser. I was using a 1/4” needle valve and the smallest bump would go from a drip to a pretty steady stream, maybe 15 minute pint. Hitting anything in between was pretty much impossible.LWTCS wrote: ↑Fri Aug 20, 2021 4:26 pm+1
I’ll try a pressure reducer on my 1/4” valve and be prepared to swap to an 1/8” valve if needed. I’ll cut coils as a last resort, but have a feeling that it’s going to be required.
- acfixer69
The pressure reduction will be amassing with the control in the valve. I've used my ball valve with no problems.
tiramisu
It is fun looking at people's copper creations.
So many ways you can configure a heat exchanger.
I'm guessing an adjustable pressure regulator will make the cooling water flow valve be easier to control.
It would be a shame to emasculate the dephleg because it's too big.
Can you put a “tee” in the coil with a second output ( or input ) ,then you could have a full coil , or a half coil flow ? Could also be helpful when switching from full reflux to controlled output . ….or from using 3kw say on a plater or 6kw on say a packed still..
Sure might make adjustment easier , less hacking and more versatility .
Sounds like a good idea. But I haven't tried it yet.
If I remember right, someone did something like that a while back.
30xs
Picked up a couple 1/8 needle valves. Found a good deal on them and ordered two. I though I’d share the find in case someone else was looking for one.
https://www.ebay.com/itm/Marsh-1900-PMF ... 632-2357-0
OtisT
Here is one example of a 4” column condenser I made with two independently controlled coils.
https://homedistiller.org/forum/viewtop ... 17&t=81513
Otis
30xs
Well I decided to hold off on cutting the original coil to see how it works on my neutral column, I do have a pressure reducer and 1/8” needle valve standing by.
I decided to build a smaller one for my flute. Best I can measure with a seamstress tape the original had six and a half feet of 3/8 copper. I built a new one using four feet of 3/8” copper. I didn’t have any more elbows so bent everything as on unit I need a couple elbows and fittings to tie into my plumbing to test it out.
