Thanks, Berserk
Appreciate the comments. I guess running the water through one line won’t provide the best cooling, good point, was probably just trying to keep it tidy there, but that is easily resolved and I’ll do a switcheroo on the waterflow direction.
The reason I chose 1/8” for the copper was one, getting a decent coil to fit in the 2” tube, but maybe 1/4” will be fine. Also, I don’t think I’ve seen a short spool that has ports that can take much bigger, it could be real tight, so the ccst was to take up the difference between the spool fitting and the 1/8” copper. Does that make sense?
If I can find a short spool with ports that fits 1/4” nice n snug, then the ccst can do one.
And yeah, I was brought up on imperial and metric. Imperial does my head in now but the standards are all over the shop with fittings, it’s a proper ball ache
Can we all just go metric, please. You know it makes sense.
