Bubble plate question
uncle_jack
Post by uncle_jack »
Hi all,
i just finished building my 3" bubble plates with 3 bubble caps and 1 downcomer on each plate.
When putting some water on the plates, i saw that they are not holding water for an infinite amount of time, a tiny amount is leaking through point where the risers and the plates meet.
To give you some numbers: It takes like 5 minutes for 1/2 oz of water to drain from the plate.
Now my question: Do you think that this tiny leak will cause any noticeable problems when running the plates?
Cheers, Jack
This topic has 3 more replies
Register Login
