Grape Brandy - Cabernet & Blackbery
Dougmatt
Post by Dougmatt »
Hi all,
I have been searching for information on Brandy runs for several days and haven’t seen too much information. I just finished my first run of some wine I made about 3 years ago which was a bit of an experiment and hoping that people find this information useful as I personally couldn’t find the detail I was looking for. Thanks to @nzchris and others who have consistently posted responses to other threads from which I learned a lot. Here’s what I made:
Using a cheap Cabernet (ordered on amazon) wine kit I fermented as follows:
Kit instructions were for a 6 gallon kit, Which I made to 5.5 gallons as I find that these cheaper kits are too thin at 6 gallons
This also boosted the SG and final alcohol % to 13% (12.7% to be exact)
During fermentation I added some sautéed fresh blackberries to add the aroma to the wine (in primary it comes through on the nose mostly)
I had 13 remaining bottles from this fermentation completing about 3.25 years ago.
I added tannins to primary (didn’t plan to make brandy :oops: ) and some oak chips during aging (6 months in carboy, rest in bottle)
For the stripping run:
I collected in 8oz / 236ml jars - sanitized with star San (wine making habit?)
I estimated this first run 8L x .127 => 1.016 L potential (no idea if this is correct, but it was close)
I use a stainless steel still, with a slobber box on an induction plate where I control power as watts (10 = 1800, 4= 800).
Temp is in C, measured at dome, and was tracked as a guide for me to try to learn my still.
6/14/21 - First run: collected as small cuts as I wasn’t sure if I would do a second run or not yet and better safe than sorry
4:35pm - temp 20* power 10 #start run
4:50pm - 25* power 10
4:55 - 32* power 10 ## sweet apple aroma detected at outlet, started condenser
5:00 - 45* power 10
5:01 - 50* power 10 #start to drip reduced power to 4
5;04 - 64* power 4 # stream very dry with strong alcohol aroma
5:05 - 72* power 4 # continued broken stream about 100ml collected, smell acetone and sweet
5:10 - 76* power 4 # collected 1/2 jar and swapped (jar 1)
5:15 - 78* power 4 #still broken stream collected second half jar and swapped aroma is softer (jar 2)
5:20 - 80*, power 4 ~half jar and swapped (jar 3)
5:28 - 81* power 4 - half jar swap (jar 4)
5:30 - 81* power 4 #broken stream, 4.25 half jars collected
8:36 - 81* power 4 # jar swap (jar 5)
5:43 - 81* power 4 #jar swap (jar 6)
5:45 - 81* power 4 #broken stream 6.25 half jars collected
5:50 - 81* power 4 # jar swap (jar 7)
6:00 - 82* power 4 # jar swap (slightly more than half) # liquor feels slightly oily (jar 8)
6:08 - 85* power 4 # jar swap - smell is in that wet dog area maybe, feels oily - (jar 9)
6:15 - 85*, power 4 # half jar, shut down, flow stopped immediately. (Jar 10)
~10 half jars collected. Estimate around 1.25L collected.
- emptied slobber box of about 100ml of cloudy sweet smelling stuff ( smelled good. Almost kept it. Wondering what I could have done with it)
6/15/21
Aromas of hearts (4-7) in first run pretty good, hot taste, wasn’t able to measure abv by sample due to small volumes…..decided to do a second run with remaining wine as charge approximating a 1.5 run.
Second run 1.5 (or so) using 5 bottles to which I added full previous run.
- again Collect in 8oz / 236ml jars but filled middle jars more full to get abv of samples.
10:30am- 20* / p 10 # start run
10:45 - 30* p10 #starting to smell apple notes and hearing rumbling noises. Head is hot. Started condenser
10:49 - 42* p10 / p4 #first drips, reduced power to 4, began collecting serious acetone smell, very dry liquor
10:50 - 52* p4 #steady drips
10:53 - 65* p4 # intermittent stream;
10:55 -70* p4 #half jar -fores : Jar 1 (treat as fores even though about 125ml which is probably too much)
10:59 - 72* p4 # half jar harsh smell : Jar 2
11:03 - 73* p4 # half jar, lighter smell: jar 3
11:10 - 74* p4 # 3/4 jar, much lighter smell:Jar 4
11:17 - 75* p4 # 3/4 jar, light sweet smell’ grape and blackberry: Jar 5
11:23 - 76* p4 # 3/4 jar, light sweet smell: Jar 6
11:30 - 76* p4 # 3/4 jar, still sweet smell: Jar 7
11:38 - 78* p4 # 3/4 jar, sweet smell: Jar 8
11:46 - 82* p4 # 3/4 jar, sweet smell:Jar 9
11:58 - 82* p4 # 3/4 jar, changing smell but still seems sweet : Jar 10
12:09 - 83* p4 # 3/4 jar, stream more intermittent, sweet bit maybe wet cardboard in there, feels oily on skin: Jar 11
12:17 - 85* p4 # 3/4 jar, definitely wet cardboard and oily : Jar 12
12:17 shut down.
Put all jars under coffee filters to sample and blend hopefully tomorrow. Early aromas: sweet blackberry and grape notes seem to be coming through.
Estimate average 150-175 ml per jar - so about 2L collected.
Slobber box again full of cloudy sweet smelling stuff.
Blending tomorrow but here’s some abv notes from testing.
Jar 1 - dispose
Jar 2: > 77% (not enough to measure)
Jar 3: > 77% (not enough to measure)
Jar 4: 77%
Jar 5: 75%
Jar 6:
Jar 7:
jar 8: 66%
Jar 9:
Jar 10: 54%
Jar 11:
Jar 12: 36% (strong tails)
I’m not sure if this is helpful, but I had trouble finding anything like this and wanted some ideas of what a run looked like so I thought I would share mine. Also not sure if this is the right place so please feel free to move if it isn’t.
Final question: what oak do any of you who make Brandy use? I have American (light and medium spirals and chips) and French (medium chips) and Hungarian barrels (don't have enough for this though….).
That’s it. No more reading!
This topic has 10 more replies
Register Login
