CM the benefits and the downsides
- Stonecutter
Running my CM reflux still tuned down to a mere trickle while maintaining a decent takeoff rate (about 3-4 drops per second) results in a fairly flavorful whiskey with high abv 80%. To me that’s beneficial. The down side is that it’s a one and done run using reflux so you don’t have as much product in the end of your final run and you lose a bit of flavor. Anyone else out there experimenting with this setup?
-Thomas Paine
-Thomas Paine
