Copper vs. CSST dimroth build
Dr Griz
Location: Stowed away aboard the flagship of a pirate zeppelin armada
Post by Dr Griz »
So as I transition from my handy little CM column to a modular design, I’ve decided to build a CCVM head for my new 2”column. I’ve read around the site, and it seems like there have been two materials of choice for the coil:
  • 1/4” copper tubing — it’s always nice to have a bit more copper in my stainless rig, but my missus the artist tells me that copper is surprisingly unforgiving. She says “it’s all soft and pliable. And then it isn't.” :lol: I’ve seen some interesting things about avoiding kinks by filling with salt, but…
  • 3/8” CSST - I gather that the corrugation adds some surface area, bit I wonder about the sizing — is 3/8 gonna wind to fit in a 2” tube? It also seems that the only tubing I can find in that size is coated. Is it as easy to skin it as the videos suggest?
So what’s the collective wisdom these days? I reckon they can both be outfitted with pressure fittings adapted to my standard coolant plumbing, so that’s good — I’m a miserable solderer (and a worse welder).
qui bene bibit est beatus
Re: Copper vs. CSST dimroth build
Dr Griz wrote: Thu Jul 01, 2021 5:11 pm - 3/8” CSST - I gather that the corrugation adds some surface area, bit I wonder about the sizing — is 3/8 gonna wind to fit in a 2” tube?<— It will. In fact, it’ll be easier to fit than the 1/4” soft copper.
It also seems that the only tubing I can find in that size is coated. Is it as easy to skin it as the videos suggest?<— Probably not. Some have tried peeling it off and some have even tried to burn it off. I suggest keep looking around for corrugated stainless steel tubing that isn’t covered with a coating.
So what’s the collective wisdom these days? I reckon they can both be outfitted with pressure fittings adapted to my standard coolant plumbing. <— The copper tubing will have brass compression fittings and some copper sweat/solder fittings. The CSST should have special brass compression fittings.
cob
Post by cob »
Are you actually building a dimroth condenser? Or is this the sliding condenser inside a CCVM?
Dr Griz
Post by Dr Griz »
Apologies for my sloppy terminology: I mean the sliding condenser inside the CCVM.
Dr Griz
Post by Dr Griz »
still_stirrin wrote: Thu Jul 01, 2021 5:49 pm
Thanks for the good info, even if it’s bad news: uncoated CSST is superior to copper but harder to find. I guess I’ll have to keep looking. Anyone have thoughts about where to source it?
OtisT
Post by OtisT »
I don’t think you are gonna find any consensus that one is superior to the other. Both will work fine and there are some pros and cons to each.
IMHO, if you have the build skills make a copper coil. If you just want it done w/o another project, use the CSST. Otis
Dr Griz wrote: Fri Jul 02, 2021 5:40 am… Anyone have thoughts about where to source it?
Here’s one: https://www.partstown.com/giles/gil4108 ... lsrc=aw.ds
Try searching on Amazon, I’ve found several sources there:
S-Cackalacky
Post by S-Cackalacky »
My CSST came from a flea market, so I don't know its actual source. It had the yellow coating that stripped off fairly easily. Here's a pic:
I would suggest looking around for it at hardware or big box building supply stores. I think I remember seeing it at Lowes. If it's sold by the foot, buy a foot and take it home and see how difficult it is to remove the coating.
About hose connections - I use clear silicone hoses and attach them to the CSST using hose clamps. Buy hoses that have an ID that matches the OD of the CSST. You may have to heat the hoses a bit to make them pliable enough to slide onto the CSST. The concentric corrugated ridges make for a good seal.
Good luck with it.
S-Cackalacky
BTW, I used the CSST for my 2" dimroth PC and a 3" sliding RC.
Dr Griz
Post by Dr Griz »
OtisT wrote: Fri Jul 02, 2021 6:00 am IMHO, if you have the build skills make a copper coil. If you just want it done w/o another project, use the CSST. Otis
I’m sorely tempted to go with copper, not because I have the build skills, but because I’d like to build my skills. :D
That being said, I reckon I’ll try CSST to start, so that I can get to playing with CCVM goodness while I play with copper on the side…
Dr Griz
Post by Dr Griz »
Thanks for the advice, gents!
In a fit of inspiration, I popped into a venerable plumbing supply business — turns out that they had a big roll of the gas tite csst, just gathering dust in the basement. Seems that 3/8” isn’t all that in demand and the old easy-to-strip coating isn’t as good for its intended purpose of insulating gas lines. They were pretty happy to get rid of it.
My daddy always said it’s better to be lucky than good…
cob
Post by cob »
Did you end up with a lifetime supply? :clap:
Dr Griz
Post by Dr Griz »
cob wrote: Fri Jul 02, 2021 8:30 pm Did you end up with a lifetime supply? :clap:
He gave me more than I figured I’d need, so I reckon so. But I didn’t want to clear him out, in the off chance that one of you fellas might get the same idea…
tiramisu
Post by tiramisu »
CSST is dead easy...
But if you look at the thermal efficiency of copper over steel there is a compelling reason to use copper as a heat exchanger.
Dr Griz
Post by Dr Griz »
I’m all in favor of dead easy! But those numbers make me think I’ll know where to go if my RC has trouble knocking everything down.
And I do feel I’m missing out on being able to post copper porn…
S-Cackalacky
Here's a pic I took while making the coils for my RC. A big screwdriver through the end loop made turning the coils very easy.
Dr Griz
Post by Dr Griz »
Thanks again to everyone for their advice -- the bit about running a screw driver through the loop at the end was particularly useful. It's all leak-tested and cleaned, and I'm looking forward to my first CCVM run!
But now I have a problem -- I reckon I got a hang of the technique just with the last few twists. I may have to make another just for the sake of craftsmanship!
Demy
Post by Demy »
Good job! I reply late but both copper and CTSS will give excellent results, they are very different in malleability, CTSS generally folds more easily (if small diameter) the copper has the advantage that if you have a stainless steel column add copper will do well to your product. A greeting!
Dr Griz
Post by Dr Griz »
I think I may have to play around with making a copper coil, too, now that I have something that ought to be serviceable for getting my new build running. I’m really curious to see how the difference in conductivity between SS and copper that Tiramisu pointed out play out in this context.
