Airing out distillate
Hybrid pot still
Post by Hybrid pot still »
I put 2 gallons out I made a couple days ago to air out, I've heard about and been reading about it. Tried it my first time. I'm really impressed by results, i was scared to do it for multiple reasons but is really worth it. This is a big gain, my cider brandy's I made dont have near the bite now. I feel like doing more, as before I didn't like it, it was too damn cidery almost hot, that feature is gone now. Anyone that hasn't done this should practice it, im doing it for now on. Thanks HD for the lesson.
Ben
Re: Airing out distillate
Post by Ben »
Good on ya. Are you airing your jars before cuts?
Hybrid pot still
Ben wrote: Fri Dec 31, 2021 7:14 am Good on ya. Are you airing your jars before cuts?
Oops, no I blended then aired out the gallon, so I should collect, air out, then blend to be correct on this method? I aired out for about 48hours
Ben
Post by Ben »
It helps, air it out, then water down samples from every jar for nosing/tasting. It will give you a good idea of what you want in your final blend. Some people are good enough to cut right off the still. Unless I have run a recipe multiple times and have an idea what to expect I will set things aside to air out a while before blending.
Keep playing and trying new things, eventually you will get a system down that works for you. Even when you have your system down you will still make little tweaks on just about every run. Very dynamic hobby!
Ben
Post by Ben »
There are two guides on cutting here: viewforum.php?f=15 Both are worth reading.
SmokyMtn
Post by SmokyMtn »
Angel share is negligible with just a coffee filter and rubber band. I have left glass open to breathe for over a year. I haven't had any regrets so far. Opinions vary but I enjoy it
My 9" Shotgun Condenser
This hobby really is not so much about making alcohol. But bottling opportunities to make memories with Friends and Family.
Truckinbutch
Post by Truckinbutch »
I collect in half pints . Cover and air for 24 hours and then make cuts .
Hybrid pot still wrote: Thu Dec 30, 2021 8:35 pm I feel like doing more, as before I didn't like it, it was too damn cidery almost hot, that feature is gone now. Anyone that hasn't done this should practice it, im doing it for now on. Thanks HD for the lesson.
Ethyl acetate is one of the flavor compounds in apples and is very volatile, airing will help get rid of some if you have too much. Did you remove a foreshot from the stripping run? How did you choose your heart cut?
Hybrid pot still
NZChris wrote: Sat Jan 01, 2022 10:10 pm
Yes, I removed about a half pint of fores and roughly 2 pints of heads when hearts started, I do it by smell, feel and taste with half and half water, smell it and taste
Hybrid pot still
A jar of it, sample rapid aging
Demy
Post by Demy »
In a corn distillate I tried to heat slightly and then mix vigorously with the open container, then put a cotton gauze with elastic instead of the cap to limit evaporation and left a few days .. I repeated a couple of times, it looks like Soften the taste slightly.
Hybrid pot still
Demy wrote: Mon Jan 03, 2022 9:41 am In a corn distillate I tried to heat slightly and then mix vigorously with the open container, then put a cotton gauze with elastic instead of the cap to limit evaporation and left a few days .. I repeated a couple of times, it looks like Soften the taste slightly.
I'm going to try that too
Hybrid pot still
Truckinbutch wrote: Sat Jan 01, 2022 9:32 pm I collect in half pints . Cover and air for 24 hours and then make cuts .
I'm going to do this too now
Hybrid pot still
Ben wrote: Sat Jan 01, 2022 7:32 am It helps, air it out, then water down samples from every jar for nosing/tasting. It will give you a good idea of what you want in your final blend. Some people are good enough to cut right off the still. Unless I have run a recipe multiple times and have an idea what to expect I will set things aside to air out a while before blending.
Yes it is. I enjoy this hobby very much and any potential to learn anything new about it
Hybrid pot still
Thank you for everyone's help and info, I really enjoy the information that I can potentially learn from all you. You guys are very educated. Hopefully I get there and better in my craft in time, you guys are truly the best I can learn from
