Does it matter if column not 100% vertical?
EricTheRed
Post by EricTheRed »
Hi
Been wondering this for a while
My 30 L boiler has a 2" bulkhead adaptor, then immediately goes from 2" to 3" via an adaptor. A 700mm packed column then sits on that, followed by another 3" to 2" adaptor, before going to the 2" shotgun.
similar to pic
Now, both of those adaptors (thermowells) are not 100% - the 2" ferrel is not welded on perfectly
as a result, the column does not sit perfectly vertical.
Is that a problem?
From what i can see, there doesn't seem to be, but what does the forum think?
Life has gotten interesting!
This topic has 15 more replies
Register Login
