Hi Friends, I am building a 2.5 inch 63.5mm bocakob. I have a 94cm+94cm:188cm filler column.
Boiler outlet has a reducer 102mm 64mm 17cm long, sight glass, total column height is 222 cm.
Where should I get the column temperature measurement, I didn't drill a hole for the thermometer
2.5inch 63.5mm bocakob construction
Hakanbakokob
