Storing freshly drained 5gal Gibbs Barrel
BrewinBrian44
Hey guys,
Did some research and found conflicting results on here.
I recently emptied my 5gal Gibbs barrel of Honey Bear Bourbon “delicious” and don’t have any new make to replenish it with to prevent the staves drying out.
I have some barrel storage tablets “sulfites” I can mix with water to prevent mold and Bactria from forming inside, but I’m a little concerned I’ll hurt the flavor of the barrel down the road by using it. This is my plan A, but I’m looking for more insight.
Plan B, get to filling it again, but in batch-to-batch increments with a new bourbon til it’s full to try and preserve the flavor inside and not let it dry out. Might make the “total barrel timing” of everything a little more difficult since I’ll be mixing new make with partially oaked spirit. Any of you guys fill this way? Since it’s a second use, I planned for a 1.5 year total aging time.
Re: Storing freshly drained 5gal Gibbs Barrel
Here, for your files. This way you have the answer from a barrel supplier, OK?
- Deplorable
How fast can you make enough product to refill it?
It should be fine for a few months if you keep it cool and out if the sun.
I bought my first once used barrel a few months before I had enough whiskey to fill it and I just filled it with boiled and cooled water and let it sit overnight. It barely weeped at all and was sealed tight the next morning. Do not use super-hot water to wet it. You'll melt the bees wax around the head.
If I were in your shoes, I'd have left the HBB in there until I had enough new make to refill it.
I'm in the same boat here, I have a barrel of single malt that needs to come out, and nothing to put back in it. On top of it all, Im in the middle of making HBB to fill a new barrel.
Posted at the same time as SS.
BrewinBrian44
Thanks for the PDF. After reading through it, it seems the article is geared towards wine. If I have a barrel still wet with spirit in there, do you find it necessary to do the rinsing? After I was done emptying it, I popped the wood bung back in place til I figure out my next step.still_stirrin wrote: ↑Sun Mar 20, 2022 12:30 pm barrel_care_sheet.pdf
It’ll probably take a few months to fill it up, give or take. I thought about leaving the HBB in there, but was worried about over oaking it. It was a brand new barrel with that batch.Deplorable wrote: ↑Sun Mar 20, 2022 12:37 pm How fast can you make enough product to refill it?
It should be fine for a few months if you keep it cool and out if the sun. B
I doubt you would have over oaked it.....best thing for a barrel is to not ever completely empty it.
- jonnys_spirit
Might try emptying 1/2 to 1/3 to bottle and drink then top it up for next round.
-j
-j
C’mon man … it’s talking about how to care for a barrel, not what you put into it!BrewinBrian44 wrote: ↑Sun Mar 20, 2022 1:36 pm… After reading through it, it seems the article is geared towards wine. If I have a barrel still wet with spirit in there, do you find it necessary to do the rinsing?
Both Saltbush Bill and Jonny gave you excellent advice Brian. If you’re not ready to recharge it, don’t empty it. Alcohol will keep mold from growing inside and it’ll keep the staves swollen. About the WORST thing you could do is to drain it, rinse it with water, and plug it up. You’re going to have mold inside it in less than a week.
So, refill it partially with some of the spirits you bottled out. Or go buy some cheap vodka at the package store and put a couple of gallons inside it. And don’t wait … do it tomorrow!
Couldnt agree more SS, I shudder every time I hear of a barrel stored empty or with water in it.
Plenty will try to argue the point though, What I do know for sure is that I now have 9 barrels ranging from 96L,90L, 50L, 25L the rest smallish........none have ever been empty since Ive owned them and none have ever leaked.
On the other hand there seems to be a regular flow of folk around the different forums who have left barrels dry after buying or after draining them, those people always seem to be the ones with complaints afterward. " My barrel stinks of Sulfur" being one.
Different Coopers seem to give different advice, mine told me more than once to not leave a barrel for any period of time with less than 1/3 to1/4 of its full capacity in it.
bluc
Water in a barrel is bad. In a pinch port/wine works but imparts flavour
Once water goes bad in a barrel you never get the stink out of your spirits..
BrewinBrian44
Alright dudes, this is why I made this thread. Thanks for the responses.
Time to dump the spirit back in the barrel til I’m ready to refill with new make. Lesson learned.
Or, go to the package store and buy a couple of gallons of cheap vodka! Heck, you may even like it when you do finally get to empty the “temporary fill” in time to refill with your new spirit. Sure, you’ll spend $50 but you’ll save your barrel.BrewinBrian44 wrote: ↑Mon Mar 21, 2022 5:55 am… Time to dump the spirit back in the barrel til I’m ready to refill with new make. Lesson learned.
Roll the barrel about from time to time, let the (limited amount of) spirit in it keep all the inside damp.
BrewinBrian44
Not a bad idea. If the stuff is gross I could always re-distill it in my column for some neutral spirit.still_stirrin wrote: ↑Mon Mar 21, 2022 6:15 amOr, go to the package store and buy a couple of gallons of cheap vodka! Heck, you may even like it when you do finally get to empty the “temporary fill” in time to refill with your new spirit. Sure, you’ll spend $50 but you’ll save your barrel.BrewinBrian44 wrote: ↑Mon Mar 21, 2022 5:55 am… Time to dump the spirit back in the barrel til I’m ready to refill with new make. Lesson learned.
BrewinBrian44
- ShineonCrazyDiamond
For the record....I have several, and only use Gibbs 5 gallon barrels. I have left them empty both brand new, and used a couple times for well over a year at a time. They sit in the spare bedroom or attic, and I haven't lost but a shot worth when they were eventually filled with liquor again. Stable temps, average humidity. One night with a soak in water and it never sheds a drop or weep beyond resealing.
I imagine if I left it carelessly sitting outside in the elements I'd have different results. But from nothing but personal experience, those are mine.
Shine on you crazy diamond."
BrewinBrian44
Good to know SCD. The Gibbs barrels are indeed high quality. The staves are so tight you can’t even see gaps on mine. Looks like a solid chunk of oak.ShineonCrazyDiamond wrote: ↑Mon Mar 21, 2022 8:04 am For the record....I have several, and only use Gibbs 5 gallon barrels. I have left them empty both brand new, and used a couple times for well over a year at a time. They sit in the spare bedroom or attic, and I haven't lost but a shot worth when they were eventually filled with liquor again. Stable temps, average humidity. One night with a soak in water and it never sheds a drop or weep beyond resealing.
I'll stick with minimizing the potential for things to go wrong. The chances of a barrel stored with a small amount of spirit in it springing a leak or going moldy inside is about Zero......I'm not sure that can be said for other storage methods.
BrewinBrian44
I just ended up tossing most of the spirit back in there since I got the vote of confidence it likely won’t over oak in the few more months it needs to stay put. I’ll taste periodically to make sure.Saltbush Bill wrote: ↑Thu Mar 24, 2022 3:50 pm I'll stick with minimizing the potential for things to go wrong. The chances of a barrel stored with a small amount of spirit in it springing a leak or going moldy inside is about Zero......I'm not sure that can be said for other storage methods.
I kept about 3 quarts and bottled a few 750ml portions proofed down to 45%. Honey bear bourbon is simply stellar and the flavor from the Gibbs barrel is really amping up the honey/graham cracker after the wood flavors mellowed down. Very sweet and refined. This batch was done with a 4 plate column, so it responded more quickly to aging.
- Twisted Brick
+1Saltbush Bill wrote: ↑Thu Mar 24, 2022 3:50 pm The chances of a barrel stored with a small amount of spirit in it springing a leak or going moldy inside is about Zero......
I bought a once-used Barrel Mill 5gal barrel and didn't fill it for 3 months. It was more than moist (drippy?) inside with the aroma of insanely sweet-smelling bourbon and a good amount of charcoal 'fines'. This barrel came beautifully made, tight as a drum, and although I rinsed it with water, I now understand it didn't need it and wish I hadn't.
- 8Ball
+1Saltbush Bill wrote: ↑Sun Mar 20, 2022 4:24 pm I doubt you would have over oaked it.....best thing for a barrel is to not ever completely empty it.
Keep it full. That is what you got it for.
Not giving any advice , just my story .
A few did a group buy and purchased 10x 95 Litre ex bourbon barrels from USA . They initially were going to cost us around $100 each .
By the time they finally arrived in Australia and went through customs etc was 6 months after they were originally discussed . Originally I was not in the group buy , but when they arrived , the real cost had risen to $400 . One member bailed so I offered to buy his .
Since I was not prepared to have enough Rum on hand to fill it , so I did my best , but it took another 6months before I had enough stored to half fill it .
So my point is that that barrel was emptied , shipped halfway around the world , went through 12 months of seasons and when I finally filled it , it did not leak . In fact it was still moist inside when I pulled the wooden bung out .
- bluefish_dist
Really depends on the environment. In Colorado with the dry air, new barrels have to be soaked before use or they leak. I used Gibbs, barrel mill, both needed rehydrated before use. If left for more than a month or two you could see the gaps between the staves.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Mine never leaked a drop either, but I put some booze in it almost immediately when it arrived.
Scarecrow left his dry for a while and tells a very different story about his......its been a constant problem ever since.
Pretty sure that at least one other that I know of has had problems to.
Spokerider
Guys,
I too have a freshly drained, 6 gallon,
Barrel Mill, used 1 time, Bourbon barrel.
I understand that the best method of ensuring short term, leak and mold free storage, is to fill it up again asap.
I'm working on that....... but will be a few months away from having it half full with rum.
So, for these few months of pre-rum storage, I have a couple of almost free options to run by you for your advice please.
One, I could use 3 gallons of whiskey feints.
Two, I could make a 23l batch of white wine from a wine kit that I have on hand.
Three, I could make a shit-mix of say a gallon of whatever bits of this and that, that I have on hand, white brandy, neutral, whiskey, rum, various flavoured likkers, etc.
Four, go buy a couple of 40oz el-cheapo bottles of?? and use that. The caveat with this option.....ain't nuttin cheap in the liquor store here, thanks to govt taxes.
Ya, water is my last choice, which I would like to avoid if possible.
Thoughts?
Thoughts?
dtrb
I read the following on the Badmotivator site.
"How do I care for my barrel?
To prevent your barrel staves from shrinking, keep it hydrated when not in use. Right after emptying, rinse it thoroughly, sanitize it, and store it filled with either a barrel preservative solution or a neutral spirit.
How do I prepare a barrel preservative solution
Prepare the Solution: Dissolve 2 grams of potassium metabisulfite or 4 crushed Campden tablets in 2 gallons (7.6 liters) of distilled water. Stir until fully dissolved.
Adjust pH: Gradually add citric acid (1 gram at a time) and use a pH meter or test strips to ensure the pH is below 3. I add 8g to my preservation kits.
Add Solution: Pour the prepared solution into the barrel and let it sit until you're ready to use the barrel. The barrel needs to be completely full (no headspace), as sulfur gas can damage the stainless. You can add more distilled water if the level looks low. Rotating the barrel every month or so can help reduce the chances of sulfur gas damaging the topside.
When you're ready to use the barrel, empty it and rinse it at least twice to remove all sulfur residue. The barrel should have a clean, almost sweet odor.
Check SO2 Levels: Use a test kit to monitor the free SO2 level every couple of months to maintain a level above 150 ppm. If using our kit, the solution will last about 6 months before needing a new batch.
Pre-Mixed Option: For convenience, we offer a pre-measured barrel preservative on our website for 2 gallons of water.
Safety: Always wear protective gloves and eyewear, and work in a well-ventilated area."
Cheers
RB
Cheers
RB
Good judgement comes from experience; and experience, well, that quite often comes from poor judgement.
Spokerider
Thank you dtrb, for posting that info.
I have read that before. It is good advice, however, it remains that water is used, and thus it will be my last choice if my other options pan out to be pipe dreams.
- jonnys_spirit
For a cheap storage solution I would use water plus neutral proofed to about 12-14%abv and as dtrb recommended, citric to a ph of about 3.2 - So that it's alcohol and ph wise the same as a white wine...
You could also make a wine kit wine and fill it with that depending on how you want to flavor your next fill with spirits.
I'd avoid KMETA unless it's a wine that you want to keep and protect from oxidation...
jonny
jonny
Spokerider
Thank you Jonny,
But.... what is KMETA when spelled out?
SW_Shiner
potassium metabisulfiteSpokerider wrote: ↑Wed Oct 22, 2025 1:47 pm Thank you Jonny,
K is the atomic symbol for potassium.
- Deplorable
I don't know if this is helpful or not, but I left a Barrel Mill barrel empty for a little over a year, and this is what I did to ready it for its 5th fill.
I pulled all the nails from the rings, removed the 1st and 2nd ring from one end and removed the head. Then I dumped out the lose char. I lightly re-charred the inside. I added some reed grass between a few staves that had been prone to weeping and reinstalled the head and rings, and I brushed some hot beeswax around the edge of the head before installing it.
I hammered the rings on just a bit further than where they had originally sat, then soaked the outside of the barrel under a sprinkler for a few hours in the yard before refilling with SBB Rum. It's actually tighter than it was before I took it apart. The Nails that BM uses are not really needed unless the barrel is just going to sit on a porch as furniture.
