How to clean salvage copper pipe
- LeftyStiller
I just sourced some 2” copper pipe from a local metal recycler. Now I need to clean it. I have a handle on taking care of the outside of the pipe but the interior seems “greasy” in places. I figure the first step will be to degrease them all first, then I am using a rough AO coated 2” wheel welded to a 24” rod and am going to chuck that in a drill. Then citric acid or vinegar bath.
Basically, just reaching out to see if someone has a better way to clean the interior of the pipe.
Thanks,
Lefty
Thanks,
Lefty
Be well,
Lefty
Lefty
- EricTheRed
Re: Best way to clean salvage copper pipe
20 ml citric acid + 20 ml lemon based dish soap and some water.
Soak a scrubby with this and pull it through a few times. Twist while pulling/pushing.
Cleans it up a treat
Life has gotten interesting!
- LeftyStiller
Perfect. Thank you.EricTheRed wrote: ↑Wed Apr 06, 2022 9:20 pm 20 ml citric acid + 20 ml lemon based dish soap and some water.
Be well,
Lefty
Lefty
Duffbrew
Re: How to clean salvage copper pipe
Just like the rest of them said the best cooper cleaner is an acid. Think about it when you solder copper the flux is acid based. I think LeftyStiller had the best suggestion, acid with acidic dish soap should clean it up nicely and degrease it also. I'd sugest doing it 3 or 4 times just to be sure.
If it is worth doing, then it is worth overdoing.
Some stuff I have acquired was quite corroded inside .
One method I used was to stuck the Copper tube in a PVC pipe a little larger in diameter with a end cap glued on it . Filled it with Sulphuric acid diluted about 20:1 . IE , pour 50mls of acid into 1litre of water . ( never the other way … it explodes in your face )
Can use Citric , but Sulphuric is a lot quicker . .
Then I use a 2” flap wheel on an extension drill and run that through it . I guess I was lucky I was a Cabler for a few too many years and have long drill extensions , but not that hard to knock up .
If it ends up pinky Copper inside , its good to go
- LeftyStiller
I think this may be a mix that I will need.Yummyrum wrote: ↑Thu Apr 07, 2022 3:48 am Some stuff I have acquired was quite corroded inside .
If it ends up pinky Copper inside , its good to go![]()
Be well,
Lefty
Lefty
- Corn Cracker
They have round, wire fitting brushes that you could run through it and that would get the dirty top layer off and get you to fresh copper, follow that with an "acid bath" and you'll be good
The cheapest copper cleaner of all is backset or dunder ,,,,,,both work extremely well, just as good as citric acid imo.
Use your imagination to make an implement / tool to scrub the insides of the pipe between soaks in backset or dunder.
It can be as simple as a scrubby stuck on a stick turned by an electric drill.
- Ben
Use a base to degrease: purple power, oxy-clean, lye, dawn dish soap.
Rinse well.
Acid or abrasion to remove oxidization/corrosion.
Rinse well.
- BlueSasquatch
Great info, I've got a good amount of 2" copper pipe from when we re-did our bathroom in this 1910 house, they used 2" copper for the drain lines, including a very bizzare brass or copper Trap for the shower. Looks like a mini barrel. Drum Trap I guess.
- Twisted Brick
I like Yummy's solution, almost as much as...
Here's a recent similar thread with others' input.If it ends up pinky Copper inside , its good to go
- Deplorable
A lot of great I put here. I'm looking forward to following your build Lefty.
Are you going to document it in a new topic here?
- LeftyStiller
Absolutely. I can’t thank you enough for the help.Deplorable wrote: ↑Fri Apr 08, 2022 9:44 am A lot of great I put here. I'm looking forward to following your build Lefty.
Lefty
Be well,
Lefty
Lefty
- LeftyStiller
Well, I actually used a combination of all of the suggestions as the pipes were pretty grungy but I think they turned out nice. Pink and clean inside as well.
Thanks all,
Lefty
Thanks all,
Lefty
Be well,
Lefty
Lefty
- Deplorable
Enjoy it. You'll soon tire of cleaning and polishing and it will develop a patina You'll grow to appreciate. At least that's been my experience
Thats a fine polish job though.
- Twisted Brick
Sure is. Nice enough to show twice!
- LeftyStiller
Deplorable,
I truly appreciate the help with this build. I will start a new thread and document it. I think I will only polish it once as it will be hidden behind pipe wrap.
Lefty
Lefty
Be well,
Lefty
Lefty
I’d call that a win Lefty
- LeftyStiller
- BlueSasquatch
I need to toss my copper in a barrel to clean, Lefty since it's so fresh, do you recall a general ratio of cleaner:water and your duration? I have a 15 gallon barrel that I am thinking of filling up with water, mix in a healthy amount of citric acid and then drop the copper in, for like 24 hrs?
- LeftyStiller
BlueSasquatch,
I used a 5 gallon bucket and probably put in approx. 2/3 cup of citric acid (just shook some in). I put enough hot water in the bucket to get the citric acid dissolves well then topped it off. I left mine in for 24-48 hours and it was both nice and pink on the outside and inside. Hope that helps.
Lefty
Lefty
Be well,
Lefty
Lefty
- BlueSasquatch
Exactly what I needed to know / wanted to hear. Any chance you're gonna tackle an old dirty keg next?LeftyStiller wrote: ↑Thu Apr 21, 2022 1:18 pm BlueSasquatch,
Lefty
- LeftyStiller
BlueSasquatch,
Nope on the keg. For me buying a new one is the way to go. But cleaning stainless should be a whole lot easier. Put in a 6" ferrule in the top and scrub away.
Be well,
Lefty
Lefty
