WildonionAB wrote: ↑Mon Feb 07, 2022 6:25 am Howdy everyone. Doing my best to absorb as much information as possible but it's a lot.
I going to build a 3" ccvm SS column with copper packing to a 2" shotgun condenser with 3/8 tubes( I think 7 tubes).
A SS 50L keg will be my boiler and I will heat it with a Propane burner.
Mostly going to run it as a pot still but like the modular idea so I can run it as a Reflux column if I want.
Hi
I'm back again.
Still trying to shake your confidence in your original plan.
Have you given any thought to anything else?
Is the farm the only place available for your hobby?
Is there 120v at the farm?
Is anyone living on the farm?
Do you just make day-trips to the farm or stay for a while?
Exactly what do you consider similar to SPP?
Have you priced out SPP to fill your column?
"So why does the 3" not help with a pot still"
My theory on this is you run a pot still by collection rate. If you can knock it down, you can collect it. Power management and condenser abilities would seem to be the main pot stilling tools, along with all that smelling, tasting and cutting stuff. (I just strip )
Back to my free advice:
Tri-clamp a 2" riser to the top of your keg. Attach a condenser of your choice to the riser and do all the pot stilling you want, with whatever power management you like.
For snowflake vodka: Tri-clamp a 2" x 48" (50mm x 1200mm) column to the top of your keg. Fill with 2.5L SPP. (I recommend manu's tiny stuff, however many are scared shitless by his tiny nozzles) Attach LM head of your choice. Adjust RR(ideally 3-1 or greater) and take-off rate. Try to keep vapor speed below flooding speed. Around 20 ips (give or take) is safe. Since most LM heads maintain a continuous take-off rate, if your RR is high enough at the beginning no further adjustments are needed till shut down.
