Liquid Management Different Designs
Re: Liquid Management Different Designs
I kinda like having a sight glass showing the RC reflux and take off on a LM.
It gives you a visual comparison of the reflux ratio. :ewink:
And give you more ideas about how to build the takeoff different next time.
shadylane wrote: ↑Mon Jul 25, 2022 10:50 pm I kinda like having a sight glass showing the RC reflux and take off on a LM.
Totally agree Shady , is exact reason I built mine like that .
I also found it interesting watching different temp of reflux hitting the cap as it flashed off again verses wet it .
viewtopic.php?f=17&t=67194#p7481508
spiritdistiller123
Post by spiritdistiller123 »
Yummyrum wrote: ↑Tue Jul 26, 2022 1:23 am
In your design there is a cap above the vapor path.
I want to build something similar to the pictures below.
As you can see, there is no cap above the pipes to prevent the RC reflux from going directly to the column.
Is this a flaw in this design? Do you think it matters?
It will only really matter if you intend to use that head as a stripper where ideally everything is pulled off .It would be concidered inefficient to have some of the strip falling through the holes .
If you will only be using it as a Nuetral rig , it won’t really matter because most if the reflux will be heading south anyway .
StillerBoy
Post by StillerBoy »
spiritdistiller123 wrote: ↑Tue Jul 26, 2022 12:57 pm I want to build something similar to the pictures below.
The design has one major flaw with it, also not to discount the degree of difficult of building it..
The design flaw will create a vapor path barrier, restricting probably half of the vapors that could be available for a 2"..
Mars
– Albert Einstein
spiritdistiller123
Yummyrum wrote: ↑Tue Jul 26, 2022 1:26 pm It will only really matter if you intend to use that head as a stripper where ideally everything is pulled off .It would be concidered inefficient to have some of the strip falling through the holes .
Thank you :thumbup:
Dancing4dan
Post by Dancing4dan »
StillerBoy wrote: ↑Tue Jul 26, 2022 1:57 pm
Mars
I lean in this direction as well. I used a small section of 2” SS with a perforated plate to hold up my rushing rings. Had a lot of holes. But not enough apparently. Lots of flooding. Was impossible to run and had to be removed.
Marcus Aurelius
Pretty cool build yummy.
I don't ever remember seeing that head before?
Also calling you out onto the rug because you used the word Flash. Lol.
I must ask, notwithstanding complete newbies, is anyone reading the least bit confused by what is meant by "flashed" within the context of this discussion?
Dancing4dan
LWTCS wrote: ↑Tue Jul 26, 2022 4:05 pm
It’s pretty cool. I’m a visual learner so I dig it!
Marcus Aurelius
greggn
Post by greggn »
I like watching how slight variations in input power cause the falling reflux to either drop in a gentle stream versus being blown around and apart by the rising vapor.
________________
Dancing4dan
greggn wrote: ↑Tue Jul 26, 2022 4:17 pm
Small variations in temperature / power input that ,are observable changes in vapour behaviour. Interesting.
Marcus Aurelius
Dancing4dan wrote: ↑Tue Jul 26, 2022 4:26 pm
I have never seen any behavior out of the above still, but with others you can tell after a few runs when the still is in happy mode.
StillerBoy
greggn wrote: ↑Tue Jul 26, 2022 4:17 pm I like watching how slight variations in input power cause the falling reflux to either drop in a gentle stream versus being blown around and apart by the rising vapor.
Dancing4dan wrote: ↑Tue Jul 26, 2022 4:26 pm Small variations in temperature / power input that ,are observable changes in vapour behaviour. Interesting.
LWTCS wrote: ↑Tue Jul 26, 2022 4:38 pm but with others you can tell after a few runs when the still is in happy mode.
Why are some members so against a temp probe and sight glass in a reflux column, though they are used on flutes without condoning them ? ?
Ah yes.. "when the still is in happy mode" or dialed in.. any tools that assist in making that happen, run after run, is beneficial to the enjoyment of stillin..
Mars
– Albert Einstein
