Still implosion
Still implosion
Hello I recently acquired a 20 gallon copper pot still built by Steven stillz if anyone is familiar. This was my first time distilling and I believe I bit off more than I could chew.
During my first run the vapor came to a stop at the thumper even though the temp was more than enough to get alcohol running. I probably overfilled the thumper if that matters. I also had a fine mist vapor leak from union connecting pot to thumper.
Later on the pressurized vapor blew a hole thru the paste on the cap so I cut the heat and loosened the leaky union to relieve the buildup and my still imploded. I checked for any blockages and found none. Can anyone give me causes to my problems and the appropriate action?
Re: Still implosion
You can start by doing some reading, which will provide info as to why and what, which seems to have not been part of the learning..
app.php/googlesearch?cx=012980085383122 ... itesearch=
Mars
Mars
– Albert Einstein
– Albert Einstein
Re: Still implosion
When you kill the heat on the primary kettle the vapor will collapse. This collapsing will cause a vacuum and will suck liquid in the thumper back into the primary kettle. If the suction overpowers the structural integrity of the thumper walls it will collapse the walls.
I'm assuming there was no vacuum break included with your purchase?
Re: Still implosion
No I’ll be sure to get a vacuum breaker next time but I still have numerous problems I need help with
1. I had the pot >190 degrees and I wasn’t seeing a drop of alcohol. The pipe leading to thumper was very hot but the pipe leaving to condenser was cool
2. It was actually the pot that imploded. Did I trigger this by opening the union? If I hadn’t I fear the pot would of exploded from the buildup.
3. In the future after I cut the heat what are the appropriate actions?
- Salt Must Flow
Re: Still implosion
Once the boiler comes up to temp, vapor starts to rise up. Once the thumper comes up to temp vapor will start to exit the thumper and enter the condenser.
The cause of the implosion was explained previously. Opening the boiler to atmosphere after shutting down stops vacuum which causes implosion.
Re: Still implosion
1. Vapor starts to form at around 190 in the primary with a 10% charge. Gotta throw some more heat at the primary is all. Needs more power because of the thumper.
2. Just get a vacuum break on both kettles.
3. See #2
3. See #2
Re: Still implosion
I assuming based on the statement not mentioning the thumper banging and thumping that the primary (pot) haven't generated enough vapors yet to even start heating up the thumper.. you'll know when the thumper starts to be heated..JoeFlipperhead wrote: ↑Fri Aug 12, 2022 1:21 pm 1. I had the pot >190 degrees and I wasn’t seeing a drop of alcohol. The pipe leading to thumper was very hot but the pipe leaving to condenser was cool
Mars
– Albert Einstein
– Albert Einstein
Re: Still implosion
So if you’re running a thumper here’s what happens; the alcohol turns to a vapor and enters the cold thumper. The vapor cools and drops its alcohol in the thumper. The liquid in the thumper takes some time to heat up and soon reaches the point where alcohol in the thumper vaporizes, moving on to the cooling coils in the flake stand. At that point you have distilled the wash twice and hopefully produced some potable drink.
During this process you have created an overpressure in both the boiler and thumper. When you cut the power the over pressure dissipated and creates a vacuum. Since the piping from the boiler to the thumper is “underwater” the boiler can’t clear the vacuum created and it collapses.
Next time open the union after shutting off the power.
Re: Still implosion
Can we get some pics of the setup? Details on the contents too. Alot of thick mash and grain in the still? Volumes?
Re: Still implosion
Don't feel special , newbies seem to manage this fairly regularly........for some its part of the learning curve.
While this is a fun hobby things can and will go very wrong very quickly if your not paying attention.
That is why one of the number one rules is to never leave a still unattended.
An Implosion is a way better ending than an explosion.
This is the bit that worry's me.....why did that happen ?JoeFlipperhead wrote: ↑Fri Aug 12, 2022 12:29 pm Later on the pressurized vapor blew a hole thru the paste on the cap
Re: Still implosion
This might be one of those rare occasion when not watching the still might have had a better outcome than watching it. Because an action was taken without allowing for the consequences, a still was destroyed. I recall doing an experiment that demonstrated this effect when in school, long before I built a still.
A leak in a still is the result of pressure. You should not have any more pressure in a still than is required to get the thumper working. A leak is a sign that you have a problem and that you need to shut down and find the restriction, but you must avoid imploding the still when you turn the heat off. A couple of seconds worth of lost vapor while you disconnect a thumper shouldn't be a problem unless you haven't put your fag out.
Re: Still implosion
You state "Later on the pressurized vapor blew a hole thru the paste on the cap so I cut the heat and loosened the leaky union to relieve the buildup and my still imploded."
Did you checked upstream of the loosend union for a blockage?
My first flute
My press
My twins
My controller
My press
My twins
My controller
Re: Still implosion
Sounds like there's a blockage somewhere. You should be able to blow through all the pieces of your system assembled, cold, without back-pressure, and when assembled. And an overfilled thumper will take a long time to heat, comparatively. It doesn't take a huge amount, and it will pick up some liquid from condensation as it heats as well.
Re: Still implosion
I was pretty surprised at how much my thumper filled up during a run. From 3/4 to near puking levels! Start low, like 50%, and you'll be safer.
I don't think you mentioned the size of your thumper?
FWIW, though I've tried a dozen different configurations in only about 20 runs, I would advise running in pot still for a couple runs first, then start adding components like plates, packing, and thumpers once you have a feeling for what is going on in the boiler.
Stay safe!
TwoSheds
Stay safe!
TwoSheds
Re: Still implosion
https://www.stillzstore.com/stillz.html ... /130699772JoeFlipperhead wrote: ↑Fri Aug 12, 2022 12:29 pm recently acquired a 20 gallon copper pot still built by Steven stillz
He doesn't mention the size of the thumper, but the site only has two sizes of thumpers 2.75 and 2.50 gal which both are way under sized for a 20 gal still.. it unfortunately that sill maker screw people over, but it the old saying, buyer be ware...
Mars
– Albert Einstein
– Albert Einstein
Re: Still implosion
Loosening a union and breaking a union are two entirely different things.
If you can't see the open end it may still have a seal with the nut loose.
Re: Still implosion
A lot of answers have been given, some very good, but alle based on insufficient information from your side.
When you have a boiler with fluid and a thumper (that you did not mention in your intial setup!) filled with fluid, and you cut the heating, there can not occur an implosion of your boiler: it simply would extract all the fluid from the thumper into the boiler.
But your report seems to indicate some kind of blockage, somewhere. Both blocking the vapour from boiler to thumper and fluid from thumper to boiler.
You do not give us sufficient information to help you further.
Re: Still implosion
Each inch of water in a column equals .036 psi. Depending on how high it has to pull the liquid in the thumper up to get it back to the boiler it could be enough of a vaccuum to crush the boiler.
If there was chunky stuff in the thumper that got sucked into the tube and blocked it, then that could definiety do it.
Edit: i looked at the 20 gal still on that site and it says its 38" tall. If it pulled liquid up to the top, that be a vacuum of about 1.5 psi. I think that could be enough to do it.
Re: Still implosion
Implosion was a risk for moonshiners distilling in the open, when sudden rain cooled the vapour in the boiler.
- jonnys_spirit
Re: Still implosion
Are you running electric or flame?
Hot ethanol vapor is very explosive. Install a valve between thumper and boiler that you can open to the atmosphere to prevent the vacuum when shutting down.
Be safe!
-jonny
Re: Still implosion
Sounds like you almost relieved the vacuum in time.JoeFlipperhead wrote: ↑Fri Aug 12, 2022 12:29 pm
Next time turn the heat down to a simmer, loosen the union then cut off the heat.
I'd cut the lyne arm in two and solder in a Tee and valve.
And I'd fix the leaky union.
Re: Still implosion
When I cut the heat, (electric element,) I open my ball valve on the top of the shoulder of the boiler. Direct air to atmosphere. No implosion problem.
Re: Still implosion
Also a I've always had to use a single wrap of Teflon tape on the mating surfaces/threads of the union to keep it from leaking. Just a wrap or two so it would still screw together right.
Re: Still implosion
Yes the still was the one pictured above. I blew through everything afterwards and couldn’t find any blockages. I did let the still sit awhile after cutting heat. The implosion occurred right as I was loosening the union so I didn’t know if I caused it or was just late saving it.
So if I run until there is little to no vapor left the risk of implosion should be zero?
I’m looking into a completely new setup from north Georgia still company. They have option for ferrule connections instead of unions and a pressure relief valve.
Re: Still implosion
Before buying a new one, with the above statement, and what you have experience, you need to go back and research how a pot still is run/operated, and went a thumper is attach, what the process is to operate it..JoeFlipperhead wrote: ↑Tue Aug 16, 2022 4:28 am So if I run until there is little to no vapor left the risk of implosion should be zero?
Speed will kill, but in your case, it will drain you account dry.. slow down and learn what's required to be learn to be in the hobby, otherwise, it wouldn't be wise to be for you to participate in..
A Georgia still will be no better than the Steven one.. it wasn't a still issue you experience, it was a lack of knowledge which did the implosion, nothing to with a still.. and a pressure relief valve will not save the still in operating a thumper..
Mars
– Albert Einstein
– Albert Einstein
Re: Still implosion
I've got one of these ball valves, and a check valve in parallel which will allow flow in with 1/2 psi of vacuum. If the circuit breaker were to open during a run I didn't want to rely on being close enough to open the valve..
Re: Still implosion
Watch the Youtube videos of Pepple collapsing barrels.JoeFlipperhead wrote: ↑Tue Aug 16, 2022 4:28 am
They always give it a tap on the side to start it happening.
The risk of implosion is still there. Turning the heat down to simmer first is a good practice because it allows you to open the boiler vent without a lot of vapor escaping.
Look for a copper pot that is thicker than the one you have.JoeFlipperhead wrote: ↑Tue Aug 16, 2022 4:28 am I’m looking into a completely new setup from north Georgia still company. They have option for ferrule connections instead of unions and a pressure relief valve.
Pots with rings rolled into its side is stronger than a pot with smooth sides.
What you needed was a vacuum relief valve.
The copper pot blowing the caps paste seal is its pressure relief valve.
Elevate the thumper, this will make it easier for the pot to suck liquid out of the thumper.
If it was my dented copper pot.
I'd straiten it back out and use it for a thumper.
- Stonecutter
Re: Still implosion
Shut down when you’re done collecting and use some hot pads to remove the column from the boiler.JoeFlipperhead wrote: ↑Tue Aug 16, 2022 4:28 am Yes the still was the one pictured above. I did let the still sit awhile after cutting heat. The implosion occurred right as I was loosening the union so I didn’t know if I caused it or was just late saving it.
-Thomas Paine
-Thomas Paine
Re: Still implosion
As long as you are boiling some type of liquid in it, it will be filled with vapor.JoeFlipperhead wrote: ↑Tue Aug 16, 2022 4:28 amSo if I run until there is little to no vapor left the risk of implosion should be zero?
When liquid from the thumper gets sucked into the main pot, it is cooler than the vapor in the pot and will create even more vacuum as it speeds up the vapor collapse.
- Stonecutter
Re: Still implosion
I got the still pictures mixed up Joe. I can see why you can’t simply remove head right after running it.
-Thomas Paine
-Thomas Paine
