How to run a still
jpparts
How to run a still
If I had an 8 gallon still but say 12 gallons of mash to run, how would I do that? Do I put 6 gallons in the boiler and when I am done, dump out what is left? Can I leave that liquid in and when it cools some, add the other other 6 gals and keep running? Thanks
Sporacle
Re: How to run a still
Depends on a number of factors.
Firstly what is the minimum charge that will keep your elements covered?
What is your intended product?
What type of Still?
Generally people strip to collect low wines and then spirit run, or do a 1.5 run.
What type of Still?
- elbono
If your mash is 10% abv there will be about 4 1/2 gallons left after running 6 gallons. You won't fit the next 6 gallons in.
If you're running electric you may need to dilute the low wines to keep the element covered on the spirit run.
Dee Envy
First off, I am a noob with a few runs under my belt.
From what I have read here, run it in two batches of 6 gal each. You can save the backset for later use. There will not be enough room in the boiler after the first run to be able to add the second fill.
Mix the low wines together for a spirit run later.
jpparts
Firstly what is the minimum charge that will keep your elements covered? - I use propane
What is your intended product? - AG whiskey
What type of Still? Pot
Maybe, dump out what is in the boiler from the first run. Pour in the second bucket of mash and the strippings from the first and run that?
That's what folks around here call a 1.5 run.
- NZChris
- Deplorable
If I only had 12 gallons of wash to run, I'd probably do a 1.5 run. You'll get a good product and a fair amount of it. While you're enjoying that, make another 2 ferments. 20 gallons of cleared wash should get you around 5 to 6 gallons of 30% for the spirit run + a gallon of fresh wash. From there you'll get around 1 to 1.5 gallons of aging keep after cuts.
Dee Envy
- Demy
Two ways to get the same product, it's up to you... it's personal preference.... the backset will be useful to improve the flavor and to dilute low wines (if necessary).
Fishy
That is why I love this site!
So much to learn.
i just joined and im loving it
So much to learn.
