Modifying my homebrew boil kettle
After joining the forum end of last year I think I have finally got round to doing stuff after much reading and waiting for parts etc.
I have an ePTFE seal under the lid rim and then I 3d printed the clamps to seal the lid.
The lockdown here left me with the only option to print something and I had a limited range of bolts.
I will probably use a single wing bolt or nut design later but these seal the lid well.
The lid on this pot is a little thin to support side loads on the column but in my shed the colum can easially be supported taking stress off the tri clamps etc
The boiler has a 4.5KW 240V denord element from aliexpress which has worked well for a few years of homebrew beer.
I took the sight glass off the pot for the sacrificial run after the vinegar run caused the liquid to rise a bit due to very slight back preassure from the column which would push liquid out the top of the sight gauge. That only happened when I really pushed it. The gauge had an unknown to me aluminum part that beer wort had eaten too. I have a better one on the way but hopefully I can plumb the top back to the boiler to equalise preassure.
The pot is 50L which is plenty for me beer brewing but I get the feeling a bit bigger might be useful for distilling one day.
The pot had weldless fittings in it setup for brewing so an in/out and a whirlpool port both with ball valves.
Re: Modifying my homebrew boil kettle
I like those clamps. I'm looking for something like that. I've been waiting on china post but going to write them off. Would like to find some for my new boiler. I have used the ePTFE rope and like it. Works with squeeze clamps but wan something more positive. For the clamps the rope is fine.
I can put the files for those clamps up on thingiverse later if they are useful for anyone else to print and they are easy to change for different pots by a couple of numbers
I drew/coded them in openscad so free software.
I'd like the information on printing those clamps as well. Thanks
How do they handle the heat?
At work they have been printing things in PLA and thermo moulding afterwards in less than boiling water .
Cool idea though .
Cool idea though .
I was wondering the same thing Yummy. The one thing I miss in retirement is not having access to a 3D printer and CNC machine.
Maybe petg could hold up and still be easy to print. I imagine pla would soften pretty quick with the heat.
Sorry about the delay to reply. I've been busy.
I printed them as 100% fill ABS, I did thicken the top bits up a bit and printed new ones but no signs of heat damage.
It's probably close to ABS temperature limits but it is surviving fine so far
I am building a new printer that I have been building to use even higher temperature plastics like polycarbonate but ABS can print on most printers
I use these, a classic, they work very well
Or these, a slightly less powerful spring but they work
Hi, I'm thinking of doing something similar. I also "all grain" brew I've got a 10 gallon aluminum saucepan with 2 elements and a 4 gallon burco, both with lids. In both cases, the elements are above the bottom level of the boilers so I thought perhaps a sight glass might be sensible so I don't run it with the elements above the liquid and cause overheating damage.
I also wondered about the sort of pressure there are in the boiler when it's running and considered some sort of clip/toggle clamp would be necessary to keep the lid on (and support more fully the column), and even some sort of seal so steam didn't escape.
Am I along the right lines? Is the lid seal important?
All seals matter.
________________
Ok thanks, yes I assumed it needed to be vapour proof.
Hey folks,
Writing here as I am struggling to seal my boil kettle properly, or at least that's what it seems based on yields I have been getting... I assume I am losing some sweet stuff.
I used the paperclip above all around the kettle but I do not have a seal. I am thinking of using a high temp food grade silicon tubing that are used in brewing equipment. They are safe up to 500c. I was thinking of cutting one open and wrap around the kettle. For the joint I could do flour paste if necessary.
Has anyone done a seal out of high temp beer tubing?
Cheers
Cheers
It's easy enough to use soft bread dough.
Include some salt and some olive oil.
Roll it out long with a rest here and there.
The beer line tubing is more than likely, “vinyl”. And even if it was silicone, like surgical tubing, it isn’t good for the job.Terrenum wrote: ↑Wed Jan 18, 2023 7:12 am Hey folks,
Cheers
I use PTFE plumbers tape. Get the wide stuff if you can find it. Then, just tape the pot edge and your lid will seal to it. Use as many binder clips as you can around the edge and it hold fine. And I use the small binder clips because they fit on the edge better than the big ones. And with enough of them, they’ll hold plenty of internal pressure.
Has anyone found a clamp that would seal a 20 gallon kettle lid with a 4” column in the center? I’m hoping to upgrade to a larger size from my Mash & Boil with the copper dome. I want to make a few runs to try to fill a 5 gallon barrel with a bourbon, they make a stout to put in the barrel after a couple years aging!
I am a visual person, what is the diameter of your kettle lid and how tall is the 4” column. I am wondering if the lid is strong enough to carry a 4” reflux column.TheoMedic wrote: ↑Sat Feb 03, 2024 8:41 am Has anyone found a clamp that would seal a 20 gallon kettle lid with a 4” column in the center? I’m hoping to upgrade to a larger size from my Mash & Boil with the copper dome. I want to make a few runs to try to fill a 5 gallon barrel with a bourbon, they make a stout to put in the barrel after a couple years aging!
I built this system on the steam jacket. I thought it might serve as an idea...
