What's this?
Sailman
What's this?
Few months back I finished up two twenty inch sections for a CCVM column. Well today I got around to doing the vinegar run. After I shut down I washed everything in warm water and then run a rag through the column. What could this be on the rag , is it the natural patina? The column was made with new copper. I only noticed this when I cleaned one section it did not come out of both. I won't be too concerned about it unless I get the same color when I clean up after my sacrificial run.
Sporacle
Re: What's this?
Sailman
Re: What's this?
ThanksSporacle wrote: ↑Sat Apr 01, 2023 12:57 pm viewtopic.php?t=54960
The image has disappeared but the thread explains it
- Renhoekk
Re: What's this?
Looks like red copper oxide. That’s the first stage of the patina that forms on copper - as time passes it gets covered by black copper oxide. You said your copper was brand new, so you probably cleaned off some of the young red patina
