Yummy’s Pot still
Post your builds here.
Yummy’s Pot still
Just realised , I haven't posted my Pot still build here , so here goes .
This was my second Potty build . The first was a small
3/4” over 1/2” . This one was intended for a friends Hubby but I decided it was too good and kept it for myself and made him a slightly lesser model . :ewink:
As I distill mostly on gas , the thinking was to keep the collection end as far away as possible .
My first Pot still had hoses at each end ….. as most Liebigs do , but the one near the keg git scorched on a few occasions and the one near the product was too close to the collection area and always got in the way .
So I stole an idea from Stubbydrainer in CCSC and brought the coolant lines back to a safe place and added a control valve there . On my original Liebig , I had no local control if flow and had ti run to the tap to adjust flow .
So it was born . 1” over 3/4” . 1.6 metres if jacketed section .
Crimped inner tube and spiral wrapped to encourage efficient coolant flow
I had to braze up some brackets to support the coolant lines to where I wanted . I used liquid paper as a mask to stop the braze running and avoid later cleanup.
I use garden hose fittings so I brazed then up at the same time . Note the big block of Pumas …… thats a trick I learned from my Dad . Its great to hold stuff while you braze it .
So here are all the bits ready for assembly .
I added a ring of cork inside the brackets to insulate the coolant lines from the still ….. its probably a mute point …. but hey . Lucky point was that the copper tube cutter kinda forms a lip on the tube so it holds the cork in place .
Re: Yummy’s Pot still
Vinegar run
A real run . Cranked gas to see what it could do .
Clocked it at about 27litres /h before ai chickened out and wound the gas back down to a sensible point .
subbrew
Post by subbrew »
That is some serious knockdown power. well done.
LordL
Post by LordL »
What a beauty!
20L Boiler
2" Piping
Potstill
squigglefunk
Post by squigglefunk »
love it, "long" live the liebig!
PuckJunkie76
Post by PuckJunkie76 »
Whewwww That's Nice!!
MooseMan
Post by MooseMan »
That's the beast from your video in my thread Yummyrum! Wow!
If I ever build another Liebig I'll be blatantly copying that design feature for the coolant line routing for sure.
I'd really like to have a stripping rig that I can run on fire in the garden, because I'm tight and because it would be cool, and a condenser that kind of length would be perfect for it.
But alas, my neighbours would soon suss what I'm doing, so it will have to stay in my dreams.
If I could do it though, what you've built there is perfection.
Wildcats
Post by Wildcats »
Nice build man. That condenser is a beast. Well done sir
Stonecutter
Post by Stonecutter »
Such a cool picture of that Liebig in the moonlight. One of my favorites so far, thanks for sharing.
-Thomas Paine
Bradster68
Post by Bradster68 »
Wow that's a beaut. Nice work👍
Yummy with all that beautiful copper work you should change the valve handles to your own. I copied Mash Rookies idea.
