I have a 4 ft. 2 inch column. Been getting great results of 94% using marbles and copper scrunched up. Changed to raschig ceramic rings and copper thinking on improvements. Now I am only getting 85%
Why?
Packing
greggn
Re: Packing
Which size rings ... 1/4" or 3/8" ?
________________
juana_b
Re: Packing
as long as everything else is ok, have you looked into the differences in hetp of the media used?
https://homedistiller.org/wiki/htm/calc ... p_calc.htm
― Charles Ives
― Charles Ives
- Salt Must Flow
Re: Packing
If I were in your shoes, I'd try Lava Rock. It worked amazing for my 3" column and worked better than any other packing I've ever tried. Sizing is important. I used a sieve (kitty litter scooper) to separate the rock I purchased to approx 5/16" in size. I kept all of the smaller bits, sieved them again with a finer scooper to obtain a more uniform smaller size and tossed the smallest rubble. I tested the smaller bits I sieved with my 3" column to see if they would work as well or work better. It didn't. The column flooded repeatedly so to me that proved that the size recommendation was accurate.
I've never used raschig rings, but I can't imagine they would work better than Lava Rock does.
Re: Packing
If its proper structured copper mesh like this , https://stilldragon.com.au/products/str ... sh-packing it shouldn't be "scrunched up" it needs to be rolled tightly then slid into the column as roll's stacked one on top of the other.
Shark
Re: Packing
Using copper dish washers. That's not the problem. Same as before just changed from marbles.
Shark
Re: Packing
My rings are 1/4 inch with loose copper on top. Take off about the same as with marbles just lower alcohol
drmiller100
Re: Packing
Have you tried only marbles? 36 inches of.marbles easily get to neutral. But more certainly doesn't hurt.
How much heat are you running?
And to clarify you are running 4 feet of packing?
