Hello. Any input on this would be very appreciated. I just started to get into distilling and have done all my cleaning runs and also a TPW run for my sacrificial run. On to what was going to be my first real run which I decided to do a sweet feed mash (link below).
Recipe:
https://www.howtomoonshine.co/blogs/rec ... ine-recipe
Sweet Feed:
https://www.mrpets.ca/online/hi-pro-cob ... attle-20kg
My OG was very low I though at 1.052. As it listed one packet of yeast I thought it wouldn't hurt to add a little more so I did add 2 tbsp's in total of distiller's yeast. Fermentation took off well (68 degree environment) and I left it for two weeks. Action on the air lock stopped after about four days. When I checked SG yesterday I got a reading of 1.020. Gave it a big stir and popped the lid back on, bubbled a tiny amount for a bit then nothing. Last night I moved it to a warmer area (72 degrees) and checked this morning..no action. I am not sure now if I should add a little yeast nutrient to try to kick start it or something else went wrong. I did not cook the mash. Any thoughts?
Sweet Feed Ferment
- 8Ball
Re: Sweet Feed Ferment
Try looking here for your answer:
viewtopic.php?t=14586
- Salt Must Flow
If you use the SG Calculator on this page, enter your measurements. I assume you used 5 lbs sugar and 5 gallons water. Based on the calculator, it says you would have a starting gravity of 1.046 which should yield potentially 7% alcohol. I know this is not 100% accurate, but it's close enough.
Now if you enter the starting gravity (1.052) and the current gravity (1.020) in this calculator, it says you currently have 4.128% alcohol. This leads me to believe it has not finished fermentation.
My first thought would be to check the ph.
Last edited by Salt Must Flow on Sun Jul 16, 2023 5:53 pm, edited 1 time in total.
Thank you for the direction guys. I will look at my Ph level when I get home. I couldn't get to the link for the SG but I'll try to find another one.
I had searched other sweet feed links but I did not find that particular link. I will be trying their method.
Thank you
Thank you
- Coyote
There is a great sweet feed recipe on here somewhere look at Tried & True
Make sure your sweet feed has NO pellets in it.
Here is how I do mine:
8 gallon fermenter
4 " or so sweet feed in the bottom.
mix 8 pounds sugar with 3 gallons of boiling water
pour in with SF. Let stand with a cover for 30 minutes or so
Add cold water to the 7 gallon mark.
I generally then place in my fermenter room ( 77 degrees)
The next morning I add exactly 1/2 oz by weight of red star bread yeast
Cap it and wait 2 weeks
Single run and enjoy or age
Coyote
8 gallon fermenter
Coyote
- Coyote
Scoop out a half gallon of grain and replace with new, Start Generation 2 with the same
sugar & water. NO yeast. I have gone to 7 generations
Coyote
Coyote
Sure enough my ph was 2.9. I added a tsp of calcium carbonate but it never even budged. Think I'll dump this one and try again with one of the recipes suggested.
- jonnys_spirit
Don't dump it. Try some calcium hydroxide (slaked lime) to bump the pH up (and oyster shells) and run it if it's stuck beyond saving...stillchillin wrote: ↑Mon Jul 17, 2023 1:08 pm Sure enough my ph was 2.9. I added a tsp of calcium carbonate but it never even budged. Think I'll dump this one and try again with one of the recipes suggested.
jonny
