My rum wash
Anything to do with rum
texasred45
My rum wash
Post by texasred45 »
[gvid][/gvid] I’ve always been a rum guy, especially Jamaican rums like Appleton estates 12 year rare blend. I did this entire recipe as a process and am really happy with my results. I was inspired by the Classic Buccaneer Bob recipe but didn’t follow it to a tee. I found ways to put my own twist on it, and this was my outcome. The steps are kinda loose because I didn’t record the recipe while making it, rookie mistake I know. If anybody has any extra insight, feel more than welcome to drop it in the replies.
Defund the ATF
texasred45
Re: My rum wash
Also for a white rum I just did 30 minutes in the ultrasonic and then ran it through a charcoal filter again, came out clear. I heard that’s how Bacardi does it so I thought I’d try it and it worked pretty well.
Defund the ATF
texasred45
Re: My rum wash
And on the non white rums i charcoal filtered straight out the still and then did the whole aging process. I then put them in the freezer after straining then after a day in the freezer I ran them through a coffee filter and it cleared the particles.
Defund the ATF
Re: My rum wash
When you say charcoal , do you mean charcoal or Activated carbon ?
texasred45
Re: My rum wash
Saltbush Bill wrote: Tue Jul 18, 2023 1:33 am When you say charcoal , do you mean charcoal or Activated carbon ?
Activated charcoal, the real fine powder
Defund the ATF
Re: My rum wash
texasred45 wrote: Tue Jul 18, 2023 12:09 am And on the non white rums i charcoal filtered straight out the still and then did the whole aging process.
What is the theory behind filtering Rum that your going to age on oak and drink brown through activated carbon?
Re: My rum wash
Saltbush Bill wrote: Tue Jul 18, 2023 4:23 pm
Shirley (surely) it wasn’t from George Duncan by chance, was it? His “show & tell” videos have created volumes of “what not to do”.
texasred45
Re: My rum wash
still_stirrin wrote: Tue Jul 18, 2023 7:37 pm
Actually it was something on here that I saw saying bacardi white is aged just a little bit then filtered but idk I’m asking yalls advice for a reason lol
Defund the ATF
Re: My rum wash
Activated Carbon removes flavour, if your looking for a white very mild flavoured white Rum it might be usefull.
I wouldnt be using it to make a Brown aged oaked Rum though, your just removing flavour.
You are right about Baccardi, the white stuff has been filtered, mostly to remove the colour after it is oaked from what I've read.
MonkeyRumKing
Re: My rum wash
Post by MonkeyRumKing »
+1 to SBB on removing flavor.
That said, it won't remove all the flavor and if you want a white rum, you probably have to filter it. Not sure how else you'd remove any of the harsh flavors. If you're after the dark rum, filtering it is just removing some of the awesomeness you've created during all your hard work of fermenting and distilling. Age it on charred white oak. Whether that's in a barrel or using sticks in a glass jar, that will mellow out your spirit. Just know that you cannot cheat the clock. Getting one of those small barrels that allegedly age your spirit 10X is a fairytale. You'll lose way too much to the angel's share and it doesn't fully remove the harsh flavors in a short time. It does help, but not enough to make the amount lost worthwhile.
You do one of two things every day, you get better or you get worse. There's no in between.
When you teach you learn.
