I do have a question though. Has anyone ever had their wash fermenting out in 48hrs?
Here is what happened.
I have made 5 generations of 25L batches previously, so my dunderpit is in full swing.
In anticipation of my new 50L still arriving soon, I started a big batch (~160L) in a 220L Barrel.
Previously I just used an airlock on a 25L fermenter and let it sit for a while, sometimes weeks before I had time to make a run. So this is the first time I am actually monitoring the process closely using the hydrometer.
I used ~40kg of molasses and 5kg sugar, unfortunately I had only about 6L of dunder left to add in order to keep the Pit going.
I was aiming for an OG of 1090 and ended up with 1095. I used a couple of Lemons to adjust the PH to 5.3
I hydrated 300g of bakers yeast and pitched at 25degrees.
Before pitching I stirred the sh*** out of the wash to aerate as much as possible. I did so again before going to bed that night and also the next morning.
By that time the wash was already frothing like crazy.
Coming back that evening, the action was actually stronger than pouring a glass of coke. Like a 100mm layer of foam that seemed to disappear quickly but was replenished at the same rate from underneath. This made it impossible to get a hydrometer reading.
In the morning of day 3 however all foam had gone and there was only slight bubbling. The hydrometer read at 1042. By the evening it had settled bang on 1040 and has been there for the last couple of days.
This seems to be very very fast to me in terms of fermentation time. Does anybody else have similar experiences?
A few more comments:
1. Most of my previous molasses washes ended up around 1030 final gravity, and this one had way less sugar in it. So I assume that the rest is just unfermentable "junk" and I am ok with this.
2. The only interesting other think I noticed, was that the wash maintained the 25 degrees temperature all by itself with an ambient temperature of 22 during the day and 15 degrees at night...
Thanks for your comments
