silica gel/rubber VMQ
Jaktpanda
Post by Jaktpanda »
Hi all,
I ordered a butterfly valve from Ali but didn't check what the gasket was made out of. Asking the seller I learned it was "silica gel VMQ" which I assume is the same as Silica rubber VMQ. As described on this site it's not recommended for use with steam, but other than that I don't see any counterindicators against ethanol use.
I'd rather not have to manufacture my own seal in PTFE, so I'm trying to find out if this is ok to use as-is in my still, or if I have to switch the material out. I'm awaiting respons from the seller for more info, but thought I'd check you y'all as well.
Any thoughts?
Chauncey
Re: silica gel/rubber VMQ
Post by Chauncey »
If it ain't copper, stainless, boro glass, or ptfe we do not approve. Wrap it in ptfe tape if possible or look for a Teflon replacement
NormandieStill
Post by NormandieStill »
Jaktpanda wrote: Thu Sep 28, 2023 12:23 am Hi all,
Any thoughts?
I have one of those. I used it on the bottom of my mash tun. Having had a look at it, I wouldn't trust it against strong alcohol, especially if it were heated. Ferments should be fine, but low wines and above would be a no-no! :-)
Jaktpanda
Post by Jaktpanda »
Alright, thanks for the advice. I'll look at rolling my own since replacement in PTFE aren't available as far as I can see.
