Hi all. Sorry for the wall of text but I got interesting results and I wanted to put as much details as I could so others can try it or comment.
Since it was my first shot at rum, my goal was that if someone doing a blind taste could identify it as rum, I would be happy.
I based my distillation on Arroyo's work but in a way I haven't seen on this site. (Skip to "SPIRIT RUN" if you're too curious)
But first, let's get the recipe out of the way:
I made 2 separate 20L batches of this:
* 2.7 Kg Fancy Molasses (Couldn't find Blackstrap)
* 400g Brown sugar (I had 800g of old brown sugar that was hard as stone. I splitted it between the 2 batches but it probably didn't do much for taste)
* 2 Kg White sugar
* Juice of 1 lemon
* 50g Baker's yeast
* 5g DAP
* 5g Fermaid-K
I did not clarify the molasses. I just mixed all sugars with lemon and maybe 10L of water. Boiled, topped to 20L then chilled to around 35C.
I then pitched the rehydrated yeast along with the DAP. It showed first signs of fermentation maybe 30 minutes later.
The next day, I added the Fermaid-K and mixed.
How I rehydrated the yeast (If you're not rehydrating, you should give it a try, it makes a big difference):
1. Boiled 5 times yeast's weight of tap water (it *must* be tap water, not distilled water) (250ml)
2. Added a big pinch of yeast
3. Boiled for 5 mins then chilled to 35C
4. Added the 50g of yeast, stirred a bit and let rehydrate for 20 mins.
After the fermentation has finished, I've let it sit a few days so that yeast re-absorb some of the bad stuff. Then I transferred to another carboy to help clarify a bit for a few days more.
Finally, I stripped both washes with my reflux column in "pot mode".
SPIRIT RUN:
Now, this is where I did things differently. I found a PDF that talk about how Arroyo produced Light and Heavy Rum simultaneously.
This paper is called "Feedstocks, fermentation and distillation for production of heavy and light rums". I attached it to this post.
And the fractions it talks about is based on: "Arroyo, R. 1948c. Simultaneous production of light and heavy rum. International Sugar Journal 50:289-291". But I couldn't find Arroyo's paper anywhere.
In summary, Arroyo says that you should collect 5 fractions:
1) From 69C to 72C
2) From 72C to 77C
3) 78C
4) From 78.5C to 85C
5) From 85C to 90C
With these fractions, you can make both light and heavy rums by mixing different proportion of the fractions:
Fraction 1 are the fores/heads and should be discarded.
To make light rum, mix together:
25% of fraction 2,
50% of fraction 3,
40% of fraction 4 and
15% of fraction 5
Mix together what's left to make the heavy rum.
Fraction 3 is a bit weird. There is no temperature gap between fractions except for #3. I don't know if it's a typo or if it means you should cut fraction 3 according to smell, taste and experience.
HOW IT WENT:
You're supposed to run this as a "reflux run" but my instincts told me to run it as a "pot run". I decided to do a compromise and run it as a de-tuned reflux.
So I equilibrated for only 30 minutes and never hit the 69C-72C of the first fraction. My run started at 78.4C
I forgot to note how much heads I removed but I collected as heads as long as a few drops mixed with really warm water smelled like heads.
I have since read somewhere that Arroyo calls for 1-2 hours of equilibration. D'oh!
I don't know how fast you're supposed to collect. I collected at "fast drip": It's never a stream but too fast to see the individual drops.
Finally, I did something Arroyo did not say: I collected from 35% abv to 27% in a separate fraction because it's supposed to be where the rum oils are. After aeration, this fraction smelled a bit feinty but otherwise a pleasant smell associated with rum. After a bit of search, I see that Pugidogs is talking about the 40%-20% range as where the rum oils are.
My fractions were messy. Shame on me.
These are my temps (corrected for atmospheric pressure (100.7 kPa) and for my shitty thermometer (which add 0.7C)):
2) 78.4C to 79.8C
3) 79.4C to 80C (The temp dropped at the beginning I suppose due to the column trying to equilibrate)
4) 80C to 84.5C
5) 84.5C to 90.5C
Rum Oils: 35% abv to 27% abv
AGING
I aged both light and heavy rums in Medium Toast Hungarian Oak cubes.
33g for 1 week for the light rum (1.5L of cask strength)
and 66g for 3 weeks for the heavy rum (2.5L of cask strength)
After 1 month, the smell is fantastic. The light rum smell a bit too much for a white rum but will be great as amber/spiced rum.
The heavy rum is still feinty but it has come a long way already. I think it will be really nice this summer.
Having these results with the bad cuts I did, I can only imagine how good the rums can be when you do spot-on cuts.
If someone else tried this method, or has any comment, I'm very interested in hearing it.
Simultaneous Light and Heavy Rum
Mr98398
