Yeast Nutrient - Alternative To Boiled Yeast
- Salt Must Flow
In my area Fleischmann's yeast has nearly tripled in price. Does anyone know of a decent alternative to boiled yeast?
Currently doing Shady's Shine. For yeast nutrient it uses Boiled Yeast, B Vitamin, DAP and Epsom Salt. Something never sat right with me while boiling a bunch of good yeast, but since it used to be so darn cheap, it didn't bother me that much. Now my local source stopped carrying it, I had to resort to buying it online at a higher cost. Now the price online nearly doubled so I'm seeking an equally effective alternative.
In all my searches I find a 'Commercial Yeast Nutrient' to be recommended which is basically a mix of essential nutrients, including nitrogen, vitamins, and minerals. Sounds like I already have that covered in the Shady Shine recipe.
Other recommendations are 'Fermaid' which I've read provides Nitrogen, Vitamins, Minerals, Trace Elements and Amino Acids. It would seem most of that is already covered in the Shady Shine recipe.
Is boiled yeast all that important? If it is, what kind of alternatives are readily available?
Re: Yeast Nutrient - Alternative To Boiled Yeast
Fermaid K works good, but it works better with some boiled fresh yeast.
Fermaid K - Technical Data Sheet
https://scottlaboratories.sharepoint.co ... =true&ga=1
- NZChris
I use Vegemite, but if it wasn't available, I'd save and use my trub.
- Salt Must Flow
Saving trub sounds like a perfectly logical idea. Use free reproduced yeast.
That just made me think of starting a yeast bomb/yeast starter. Boil half and use use the other half for pitching. I've never had to make a yeast starter before, but perhaps that could get me started at least. I can provide a temp controlled environment (if ideal) and I have a homemade stir plate.
Yeast has always been so darn cheap, I've never considered the trub I've always dumped outside. I've never had to economize or even consider the cost. Things certainly have changed over the past few years.
- jonnys_spirit
I tested out autoclaving some used trub by canning it in small mason jars - I compared that to Fermaid K or O (don't remember which) but the fermaid worked better as a nutrient.. I might do that test again because that used trub had been sitting around in an airlocked jug for about two years before I autoclaved it in a pressure cooker so I'm not sure how much I trust it...
Worth testing in any case!
jonny
jonny
- Salt Must Flow
I remember reading an article posted here in the forum where pressure cooking (autoclaving) yeast makes dead yeast significantly better as a yeast nutrient in comparison to just boiled yeast. Pressure cooking is also probably the best way to preserve it long term.jonnys_spirit wrote: ↑Thu Dec 21, 2023 3:27 pm I tested out autoclaving some used trub by canning it in small mason jars - I compared that to Fermaid K or O (don't remember which) but the fermaid worked better as a nutrient.. I might do that test again because that used trub had been sitting around in an airlocked jug for about two years before I autoclaved it in a pressure cooker so I'm not sure how much I trust it...
jonny
I imagine the easiest way to store trub is by freezing it, but I do like the sound of Pressure Cooking it for all of the other added benefits.
- jonnys_spirit
I must have read the same article but I also did a little independent research and that was my conclusion too. Something about cooking at above 212*F breaks up the molecules and releases the amino's or some such thing...
One thing I know how to do is turn a little yeast into more yeast (you can call me yeesus) so if that does work with yeast/trub that's not 2+yrs old then it's a very economical and easy way to diy some more bioavailable nutes for the yeasties so we can make sure they stay fat and happy pissing out our favorite byproduct
jonny
jonny
Fresh boiled yeast works better than trub.
Trub is wornout dead yeast that has a low pH, but it's better than nothing.
- Salt Must Flow
I didn't know that was a fact, but coincidentally I'm reading up on making large yeast starters. If I can start out with a relatively small amount of yeast and allow it to multiply MANY times over ... that just seems like a win.
I typically do two 45 gal sugar washes using your Shady Shine. That uses a significant amount of yeast. Maybe if I can start with 25% of the amount of yeast, that will allow me to use half for boiling and the other half for pitching. I imagine I could start with less yeast, but I'm not really familiar with yeast starters.
I've thought about growing a bigger batch of yeast and murdering it.
But then I'd have to feed them, if I didn't they would be weak and less nutritious.
You would need to be careful about sanitation.
- jonnys_spirit
A stir plate, low sg, nutes and a few days is a little bit of another rabbit hole if you want to increase the size of the colony before pitching. Maybe autoclaving fresh yeast before it dies is a thing? Veal is definitely “a thing”…
-j
-j
I'm lazier than I'm cheap. $15
- Salt Must Flow
I hear ya and I agree. It's $15 now, but it used to be $5 and some change though damn it. Just rolling around some options.
I have a week off work after tomorrow. I have 2lbs of yeast on order, but I only have 1lb on hand which is not enough. I'm curious by nature and can't help but wonder if I can save some money by letting some yeast reproduce like sheckles.
Here's a way to save 25% on yeast.
Start the two batches a day apart, scoop a bucket full of the first to pitch in the 2nd.
MooseMan
I do this very often shady, with wines and beers too, you are pitching a very active and vigorous yeast that way.
I usually wait until Krausen has fallen then crop some. The craft beer boys are well into this.
Also Salt, if you're really tight like me, slowly heating "Clean" trub on top of the still during a run, is definitely a good thing. Better than boiling it. (If you are really bored, get a long drink and hit Google with "Yeast hydrolysis" and "yeast autolysis")
You get a pot of free nutrient, warm and ready to add to the next ferment you've been setting up during the run, to go with the backset!
- NZChris
That might depend on how you treat it after the ferment goes dead. Initially it's yeast that has run out of food, chuck a handful of sugar in it and it leaps back into action. If you rack off the wash in a timely manner, the trub should be fine for starter for the next sugar wash, or for pressure cooking and freezing to use as nutrients later.
tommysb
If you top-crop the yeast, during the right phase of fermentation, you can run multiple (infinite?) successive ferments with it. if you repitch the trub from the bottom at the end, eventually it won't be great for ferments - but you can repitch maybe 3-6 generations in this style - but thing like the number of dead cells increase and the yeast also autolyses degrading the quality and sometimes bringing in a soapy flavour.
I know you are talking about using it for yeast nutrient, so the trub at the bottom of a fermenter is probably a good enough source.
In terms of top-cropping, this is what's done on the Burton Union beer brewing system - look it up if you are interested. It indefinitely provides a continuous source of yeast for subsequent brews.
SGB
Napa cabbage works for me , hundreds of sugar fermentation and not one failed using it. I do a ratio of 10 x the weight of yeast ie 10 grams yeast , 100 grams napa cabbage blended with water and poured directly into the hot sugar water mix
Bolverk
My understanding is boiling and reusing the trub is basically creating a weak fermaid O and yeast hull nutrient.
Hell worst case, start and keep a yeast culture in a conical bottom fermentor so you can pulled the trub off the bottom boil and use it in your next fermentation.
