How do you store your botanicals for gin
All things to do with making of gin
artooks
Post by artooks »
Hi Everyone,
Back to distilling after a year later cleaning my still and arranging my botanicals, the problem is when I opened the cupboard where I store my botanicals, the smell has permeated all over, then I realized that it was mainly cassia bark which created this, I store my juniper in the freezer but the rest in cubbord such as: Cassia Bark, Grains of Paradise, Cubeb Berries, Coriander seeds, Cardamom, Angelica Root and Licorice root, this time I will put them in a sealed Jar would it be ok to do so what do you think ? I only keep Juniper berries in the freezer and the rest in the cubbord is that ok ?
How do you store your botanicals ?
MooseMan
Re: How do you store your botanicals for gin
Post by MooseMan »
Welcome back, it will be good to have your input again.
I store all mine in screw top jars out in the garage, usually also still in the bags they came in.
NormandieStill
Post by NormandieStill »
Mine all came in heavy lined Kraft paper Ziploc bags. Which all live in a plastic Ikea box in my office.
But I think that the correct answer is "in alcohol"! :wink:
Renhoekk
Post by Renhoekk »
I use airtight containers of different sizes - the type with the rubber seal and locking clips in the lid. The containers live in the pantry. I try to use the juniper within a few months rather than storing it for long periods, but if I have leftovers I’ll put them in the fridge.
Demy
Post by Demy »
Airtight screw jars
The Booze Pipe
Post by The Booze Pipe »
MooseMan wrote: Sun Jan 07, 2024 1:19 pm Welcome back, it will be good to have your input again.
I also store this way! But I’m wondering how long is too long to store these botanicals before they’re no longer fresh enough? My juniper, coriander, and cardamom are about four years old ( as I’ve been a hiatus) stored as stated. It still seems fairly good but what do you think?
13.5g/50L keg
12,000watts of fury
MooseMan
Post by MooseMan »
The Booze Pipe wrote: Tue Apr 16, 2024 9:22 am
If you could get fresh bots to compare with that's the ideal, then if the older ones are a little more dull, you can increase the additions to the gin to compensate.
I'd personally try a small test batch and see how it comes out.
Worst case you either blend it into another, stronger gin, or re run it.
The Booze Pipe
MooseMan wrote: Tue Apr 16, 2024 10:25 am
Good ideas. Thank you
13.5g/50L keg
12,000watts of fury
Warthaug
Post by Warthaug »
Frozen in ziplocks. Freezing will do far more to protect from oxidation and volatile loss than pretty much anything else you can do.
Brewer for decades, dabbler in distilling trying to get better at the craft.
Screw top jars an a dark apothecary, juniper in the freezer.
Some improve with age, some I replace when they are in season rather than when their jar is empty.
