Rate my Liebig
Steelers_Stiller
Rate my Liebig
Post by Steelers_Stiller »
This is my first attempt and building anything distilling related.
Its not soldered together yet so, it can be easily modified.
Take a look and let me know if there is anything that should be done differently from your perspective.
1" copper over 3/4" copper
The 1" part is approximately 4' long
the 3/4" part is about 4'-10" long
2x gate valves to control water flow in/out. They will accept standard garden hose fittings.
2x copper unions. One will allow you to spin the condenser so the water valves can point up/down, one to adjust the angle.
This will also allow removal of one of the 90 degree fittings and be more modular to connect to the column in different ways.
OtisT
Re: Rate my Liebig
Post by OtisT »
Congrats on starting your first build.
You only need one valve, likely on the output side (near the elbows/unions).
It is going to be heavy. You will likely need a stand or sky hook to hold it securely.
EricTheRed
Re: Rate my Liebig
Post by EricTheRed »
OtisT wrote: ↑Tue Jan 23, 2024 6:42 am Congrats on starting your first build.
What he said
Life has gotten interesting!
Re: Rate my Liebig
Steelers_Stiller wrote: ↑Tue Jan 23, 2024 6:29 amThis is my first attempt and building anything distilling related.
2x gate valves to control water flow in/out. They will accept standard garden hose fittings.<— They’re not “gate valves”, they’re “boiler drains”, like you’d have at the washer/dryer hookup. Gate valves have a rising gate that “rises” when the stem is twisted.
Gate valves are almost always “inline”, meaning they are installed in a straight pipe line.
2x copper unions. One will allow you to spin the condenser so the water valves can point up/down, one to adjust the angle.<— Well, the 2nd union is a “wasted cost”, because if you build the condenser so the inlet and outlet naturally orient below the condenser’s centerline when connected to the riser, then your inline union isn’t needed.
The other union, however, in the swing joint is good, very good. It allows for the inclination angle of the Liebig to be adjusted according to the elevation (height adjustment) of your collection jars with respect to the riser outlet height.
Your choice of 1” over 3/4” will allow for a relatively good production rate. However, a 3/4” over 1/2” would handle boiler power up to 2kW (approximately). But your 48” long water jacket (1” over 3/4”) will give you good performance up to 2.8-3kW without problem.
Hint, if you put a spiral of 12 gauge copper wire around the vapor tube before inserting inside the water jacket pipe, it will help “swirl” the coolant through the jacket and that will improve performance. It will also help with the “thermal gradient” for heat transfer from inlet to outlet. Of course, it isn’t needed, but it will improve performance. 12 gauge wire can be stripped from 12-2 Romex, FYI, and it can be soldered to the outside of the vapor tube with a couple of spot solder points.
What is key for HEX design is the vapor flow area (pi/4 x ID x ID) to conduction surface area (pi x ID x L) ratio. But, the larger vapor tube ID does allow for a greater mass flow before critical flow velocity diminishes heat transfer efficiency (sorry, engineering terms).
Overall, good job. It is an investment that will work for you for a long time.
Re: Rate my Liebig
I agree with all said so far .
I have different thoughts on that union on the top of the Liebig . Yes it could be considered redundant but I have over the years repurposed stuff and it will be far more useful if it is there . It also means you have physical access straight through the centre pipe iff’n you need to run a long brush through it at some stage .
It is normally advisable to arrange Liebig so hoses hang straight down , but because you have used those right angle valves , you need to have the coolant stubs come out on the horizontal plane so the hoses will hang down .
I think that is not a big deal but you may later decide to replace the two right-angle valves with straight valves , in which case , being able to adjust the coolant stub plane to vertical will be desirable .
I think having the two valves could be useful especially if you use shutoff hose fittings as it means you don’t have water pouring everywhere when you disconnect hoses and move liiebig .
But …… never leave it full of water if it is likely to have it stored in the cold .
You don’t want to be the next guy posting pics of a condenser that had frozen water in it’s jacket . Tends to rip pipe open .
Salt Must Flow
Re: Rate my Liebig
Post by Salt Must Flow »
I totally understand what Yummy was saying about having your water lines hanging straight down so that they don't kink. I do it like how your valve is configured. I run the cold water line over to my keg, up the riser and along the condenser. I use Velcro straps to secure the water lines so they are out of my way so they aren't dangling in my collection area, it keeps the hoses tidy and just out of my way. My riser is well insulated so the water lines don't actually contact the hot metal. I use the same segments of riser for my reflux column so I just leave the insulation on.
I always put a valve on the water inlet side of all my condensers. I've never found the need to have on on the water outlet side of any condenser.
Re: Rate my Liebig
Steelers_Stiller wrote: ↑Tue Jan 23, 2024 6:29 am This is my first attempt and building anything distilling related.
Bang for the buck is 1" over 3/4 and if you need more knock down, make it longer. :lol:
Just guessing, the 48" long liebig will condense 6kw or more before it becomes a water hog.
Make sure the hot outlet hose hangs straight down.
Only one valve is needed to control the cooling water flow.
If the valve is on the hot end, it will burn fingers when adjusting it.
Re: Rate my Liebig
Unless your water is at a low pressure, it pays to control it with a valve before the hose rather than at the condenser. There is never a convenient time for a hose to blow off during a run.
Re: Rate my Liebig
NZChris wrote: ↑Tue Jan 23, 2024 7:12 pm Unless your water is at a low pressure, it pays to control it with a valve before the hose rather than at the condenser. There is never a convenient time for a hose to blow off during a run.
I guess one at each end doesn’t hurt but before I fitted one to mine , I was constantly back and forth to the tap some 10-15 metres away while getting flow dialled in .
Re: Rate my Liebig
Yummyrum wrote: ↑Tue Jan 23, 2024 7:14 pm
I took a couple of baths in the shed early on, so I put up with a 10 meter trek to the tap for years, then ran the water to the shed and installed pressure regulators and automation.
OtisT
Re: Rate my Liebig
Post by OtisT »
Hi Steelers. I’m glad the folks above caught my mistake on valve placement. It should be on the input side. Good luck with the build.
NormandieStill
Re: Rate my Liebig
Post by NormandieStill »
As someone who has lived the experience of both the frozen liebig (mine crushed the inner tube without splitting anything so nothing leaked but it was a potential puke trap!) and a blowout on the input hose due to a closed valve on the output I wholeheartedly endorse he above comments!
I'm also jealous of those of you who can get copper unions. They don't exist here which means connection points need to be in stainless triclamps if you don't fancy brass in the vapour path.
MooseMan
Re: Rate my Liebig
Post by MooseMan »
Rate your Liebig?
Yes I do as a matter of fact.
It's a good length and a good sized pipe combo, so it will certainly be able to handle a hobby sized setup with no issues at all and still be pretty efficient water wise.
Should serve you well, and for a long time.
I'd go valve on water input only, and think carefully about the path you want your water lines to go, as already pointed out.
As Norm says, envious of you guys who can get copper threaded parts, we have to cobble together copper and stainless bits to get a join to the still head.
Steelers_Stiller
Re: Rate my Liebig
Appreciate all the responses, thanks!
I read elsewhere on here about wrapping the inner pipe with a wire. I had some 10 gauge lying around. I soldered it up and tried to slide the 1" over top but it would not fit.
I had the 10 ga wrapped tight to the pipe.
I see Still Stirrin mentions using 12 gauge. Maybe that will fit?
Re: Rate my Liebig
I've run a spiral in a clear water jacket and in a jacket painted with thermochromic paint. Unless the spiral is a tight fit or the flow rate is very high, the spiral does little to interfere with the convection that occurs in the jacket. The more undersized the Liebig, the more help it would be.
viewtopic.php?f=87&t=57690
Re: Rate my Liebig
I actually stand it vertical with a vise grips clamping wire top and bottom . Then I apply liquid flux , it spirals all the way to the bottom like a big Helter Skelter .Then I apply solder and as I move the torch down the pipe , solder flows down the wire following the flux . wire is then solidly attached to pipe .
It then allows you to be more rough when inserting it into shell as the wire can't move . I had to give a light file in places to get it to fit . Use a Water based Lube and it just slides in nice and tight if you got it right .
This is a pic I took one night on my first Liebig . The condensation marks clearly show something is happening .
MooseMan
Re: Rate my Liebig
Post by MooseMan »
Steelers_Stiller wrote: ↑Wed Jan 24, 2024 3:32 pm Appreciate all the responses, thanks!
At the length and pipe size you are using, the flow of water will be so slow I can't see the wire making any noticeable difference.
The water just won't follow it unless it's tight to both the inside and outside pipes.
At low flow, the water will just slide on through any and every gap.
My own Liebig is very similarly sized to yours and it's mega efficient, needs just a tiny trickle of water even stripping at 12L/HR on full power.
No wire spiral in the jacket, but I do have a thin copper blade around 8"long that I twisted into an open spiral and pushed into the riser end to disturb the vapour as it comes in.
Does it help?
No idea but it's so efficient a condenser I don't need to worry about it and neither will you.
Since you already soldered the wire on, you may as well file it all down until the jacket slides over though I suppose, it won't do any harm.
Re: Rate my Liebig
MooseMan wrote: ↑Thu Jan 25, 2024 12:11 am
That has been my experience. The Specific Gravities of hot and cold water are very different, and they really don't want to mix.
Steelers_Stiller
Re: Rate my Liebig
MooseMan wrote: ↑Thu Jan 25, 2024 12:11 am My own Liebig is very similarly sized to yours and it's mega efficient, needs just a tiny trickle of water even stripping at 12L/HR on full power.
Wow, that's a lot of stripping! Are you running electric heat? If so, any idea how much power your putting into the element?
I removed the wire from the pipe shortly after finding out it didn't fit. Not sure if I want to bother trying to fit some 12ga in there or not. Haven't had much time to mess with it. I did drop off a bunch of stainless steel ferrules with my neighbor last night. He's got a nice lathe setup in his basement and will try turning them down to fit inside my 2" Type L column so I can finally move on with the still build.
MooseMan
Re: Rate my Liebig
Post by MooseMan »
Yeah that's with 2 elements of 2+KW (I can't actually remember how much over 2kw!) running full power, and a very well insulated boiler.
Steelers_Stiller
Re: Rate my Liebig
Had some time to play today. Didn't solder it yet. Still looking for some advice. I can set this up a few different ways. I'm considering going with option 1 (first photo) and eliminating the unions.
Let me know what you think is the best setup. Photo 1, 2, or 3.
Re: Rate my Liebig
All three options would work.
#1, #3 and #2 is the order that I'd pick.
On a side note, spiral wires inside the jacket don't make a difference.
Wires or anything else inside the vapor path decreases knock down power..
Sometimes differences in plumbing and liebig angle can have an effect on a CCVM still head.
This is just a guess, but I'd use option 1 and remove the horizontal extension.
That would let the liebig suck harder on the column outlet.
MooseMan
Re: Rate my Liebig
Post by MooseMan »
shadylane wrote: ↑Fri Jan 26, 2024 4:48 pm All three options would work.
Option 1 for me too.
When I read "horizontal extension" I wondered what the heck you were talking about shady!
I had to go back and look at the pictures.
I did NOT see that little short section coming off the tee in the pics, or in the pics in the other thread, my brain just told my eyes that it was part of the Tee...
Yes I'd leave that out too. In fact I'd add it to the column for extra height if you can.
OtisT
Re: Rate my Liebig
Post by OtisT »
If you want the extra packing height, that short horizontal section looks like it could be moved to add more vertical packing height if you turned this into a VM. Replace the horizontal section you remove with a valve. With a VM, you would no longer need the free space above the column for adjusting RC height.
