Yummyrum wrote: ↑Sat Jan 27, 2024 4:03 am
I like it . Most of my stuff is modular 2” as well .
I personally don’t see the need for the horizontal extension , but , if you could manage to sub it out for a Valve , you would have a VM
Many like CCVM , but I’m a straight VM fan .
But iff’n you were to go VM , you’d be better off with a 3/4” - 1” ball valve as it would be way easier to adjust than a 2” .
I agree that the 12” top module would be a great riser in Pot still setup . Removing and repacking is a pain in the arse if you don’t need to . Having said that , some experiments I did showed that an insulated packed riser had little difference over an unpacked one .
EDIT : some of my comments might be cross purposed with your other topic . “Rate my Liebig”
viewtopic.php?p=7774371#p7774371
I had to step away from this column project for awhile but I'm finally back to it and intend to finish it!
I took your advice about a gate valve to be able to run it as a VM still. Found a 3/4" S.S valve to install just after the Tee.
That brings me back again to questioning the reflux condenser. I have a 20' coil of 1/4" OD copper tube and plan to wind a double helix coil.
Questions are:
1. How long should this reflux coil be? I see super confusing threads with math formulas and it seems like it should be 10" or more but than I read where guys are using 8" coils with a 5kW heating element.
2. How far above the horizontal takeoff should the coil be?
3. How tightly should the reflux condenser fit inside the column? I have a 1.5" OD pipe I can use as a mandrel. I tested some scrap condenser tubing and it is possible to fit it inside the column (VERY TIGHT) but I CANNOT slide it thru the tri clamp ferrule. This is why I am asking how close to the takeoff arm should the coil be. If it can be above the ferrule, I can proceed with what I have.
I decided to pack the column with stainless steel scrubbers. Bought 3M Scotch brite #84 from Amazon. A 12 pack was around $18.
The beer keg boiler is finally done. I'll post some pics in my other thread about that.
The liebig PC was reconfigured a bit to better work with the gate valve.
About the only thing left is finish up this reflux condenser and the spool that will contain it.
