Stripping on the shoulders of giants
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
tommysb
Post by tommysb »
Stripping stills have been interesting to me for some time. I did my first experiments with them 2 summers ago, and have been reading and scheming since then.
Over the last couple of days I have been putting together my first attempts at a serious stripping still, and learned a bit, which I'd like to share here. I don't have good photos at the moment as I was running it outside in the evening after work, with low light.
I'd ordered some modular parts from OakStills for most of this. At the moment, I am just testing the capabilities of everything, and am not consuming anything from this still.
The basic idea is somewhat like the continuous still that the Russian Dr. Gradus shows in his youtube videos. If you look at Yummy's thread - there is a lot in common, except that there is a dephlegmator above the wash infeed. I thought about whether this was necessary - as we are not looking for high abvs, and so sending vapors back down the column was not really necessary.
In the end, I decided it didn't make too much difference, since incoming wash would do the same job of sending vapors back, and decided to put the defleg in.
This was my first mock-up of how the still would go together. It's based on a 4" column, and I have about 3800w to drive it. I took this a couple of evenings ago.
Rather than having a boiler, the element sits directly at the bottom of the column. This design is seen on the stilldragon forum a few times I think.
There's about 75cm of packed section, and I have packed the column with expanded clay balls as they are abundant and cheap. I have a couple more 12" (30cm) long 4" sections and I could add these to the column if I feel I need more height.
I was using a Kamoer speed controllable peristaltic pump to feed the column. I bought this from Aliexpress, it does up to 1.6L/Minute apparently. Unfortunately, the display on the pump never worked. I am in contact with them to get a replacement/refund, but it means I can't really measure/track the rate I feed wash into the column :(.
First attempts at running this configuration:
Yesterday, I was running an all grain wash, (Barley, Wheat and a bit of oat), and it was foaming like a M********. I could drive the column with about 70v, I think that the element is about 16ohm resistance, so that's about 300w. If I did more than that, the foam would just overwhelm the column. I just gave up, after having no luck.
Today, I picked up some anti-foam, and added it to my barrel of wash (about 150L), and stirred (by hand). This helped a lot.
I added a 12" unpacked section of 6" spool underneath the packed section of the column. The idea being that any foam up would not rise up as much or as readily in this wider, unpacked section.
I had to play around a lot with the airlock/u-bend section where the wash exits. If there was too much power, for some reason, fluid was surging out of this.
The modifications I made were to make it deeper - therefore adding more fluid to it, and having a heat exchanger on each side of the 'U'. I recall the improvements that YummyRum saw in his setup with adding more heat exchange to the fluid outlet.
Whilst we're on the topic of heat exchangers - the route of the wash is currently -
Product condensor ->Ubend closest to column,->Ubend furthest from column (exit side) -> defleg in column above feed point ->column.
My thinking here is that the vapour temp should be less than the overflow temp - vapor having higher abv, and overflow hopefully having very little alcohol, so be close to boiling point of water.
When running the column - vapor temp was about 95c, - indicating 45%abv I think. Tomorrow, I will try running the wash first through the column outflow, and next through the product condensor. I have an additional condensor running from mains water, so it is not essential to use wash to knock-down vapors.
To overcome the surging exit from the overflow- I added a section of 4" tee, so that there was a lot of fluid in there. Aside from foaming, this surging out through the ubend was a major headache and one of the challenges to overcome in getting this to run properly.
This was the setup that I got working.
Here is the detail of the bottom section - with the 6" spool,
and here is the U-Bend (again, really sorry about the **** photos - I will take some better ones tomorrow in the light!).
To run the column - i used the following technique -
1) Pump wash into the column until it flows out of the overflow - and then stop pumping.
2) Switch on heat. Heat up slowly, so that foam doesn't rise up the column.
3) Use the vapor to heat everything in the column. This needed patience. I kept switching on the wash too early, and it never worked. In the end, I realised that I needed close to boiling point in ever spot for heat exchange, to help heat the incoming wash.
4). When vapor is exiting the column, switch on water to the auxilary condensor (without wash in it). Let the wash in the product condensor heat up.
5). when I was happy that everything in the column was hot, i slowly switched on the wash feed. Very slow.
6). Slowly increase the power in the column. - I had been to cautious about this. In the end the column ran better the more power I pumped into it. It seemed that the antifoam was working now, or the 6" spool section - and I could run the column with more power. Additionally, I think that the falling product and recondensed vapors helped to manage foam up; whereas during heat up, it seemed that all vapors, liquid, and everything was only moving 'up' the column, and the foam went that way.
7)slowly increase the feed rate. In the end, I was getting about 1L of output every 14 minutes - so about 4.3L of low wines per hour. I was running very cautiously and am pretty sure that I could up this a bit. I did play around with wash feed speed a bit, and got a bit of foaming at the feed point if I increased it too much, so backed it off again.
When the column was running - it was actually pretty stable, and just kind of ticked along.
Overall - really pleased to have got it running.
Need to do some more testing, and get some better photos (maybe video!) of it all working in daylight.
Bolverk
Re: Stripping on the shoulders of giants
Post by Bolverk »
That's awesome, 4lph is a respectable rate.
This is my observation and opinion after researching the shit out of these, then eventually abandoning the concept for a live steam injection that ill get to eventually.
I feel these reboiler designs are inherently flawed due to the column pressure fighting the overflow pressure. You'll never be able to run it wide open because of the foaming you see in these designs. You should be able to run your element at full whack and regulate the column just by varying the beer feed rate. But that's not the case with these reboilers. You're going to constantly dicking with it and it will be really hard to reach equilibrium, and if you do it'll be at a reduced rate.
There is a really great thread on SD where a fella went through the whole gambit and a few other joined in with their experiences and they all learned a lot.
tommysb
Post by tommysb »
I managed to have another play with this during my lunch break and take some better photos. Here's the whole setup.
The whole setup:
One interesting thing I noticed - upping the feed rate didn't up the output rate, but did seem to up the output ABV. The vapor temp at the top of the column dropped accordingly.
I tried running the wash through both the bottoms HX first, followed by the product HX and vice-versa but I couldn't really tell much difference in behaviour between the two configs.
I am going to try a config with more 6" section - hoping that for a particular production rate, and so, quantity of vapor in the still - the pressure will be lower due to the vapor existing in a larger volume.... let's see...
Have you had any problems with sediment in the bottoms building up around the element?
Tōtōchtin
Member
Post by Tōtōchtin »
Have you ran a still with different packing to compare with the clay. I bought some Hydroton for my column because I like how porous it is and how light weight. Compared to lava or marbles.
Tōtō
Si vis pacem, para bellum
jonnys_spirit
Post by jonnys_spirit »
I keep coming back to this as a potential stripping solution too but then think a pre-heater might perform better (ie; faster) for a semi-continuous stripping production... I'd love to be able to get through stripping a large batch in a saturday and spirit run the next day to wrap it up in a weekend. A few of those in a year would keep the barrels full with diverse product in my shed :)
j
tommysb
Post by tommysb »
shadylane wrote: ↑Wed Feb 21, 2024 6:36 am Have you had any problems with sediment in the bottoms building up around the element?
Not had time to check for problems yet :ebiggrin: . I did notice a bit of sediment in the bottom of the U - but not a problematic amount. I am waiting for the column to cool down so I can pack it down this evening and I will have to take the element out for that. I'll have a look. It will have to wait a few days before I can play with it again - weather looks rough and I have a lot going on at work.
Tōtōchtin wrote: ↑Wed Feb 21, 2024 6:56 am Have you ran a still with different packing to compare with the clay. I bought some Hydroton for my column because I like how porous it is and how light weight. Compared to lava or marbles.
Tōtō
I've run both plates, and packed scrubbies/copper wool. But i don't have enough experience to say I noticed much difference. This packing choice was mostly about budget and availability. It's going to be good enough for the job at hand for now. I.e. I am pretty sure that the hassles and tweaks I need to do to this still to get it working are not to do with the packing.
There's probably better packing available. Better value packings? I doubt it. This clay is available for something like 5-6euro for 50L.
jonnys_spirit wrote: ↑Wed Feb 21, 2024 7:36 am I keep coming back to this as a potential stripping solution too but then think a pre-heater might perform better (ie; faster) for a semi-continuous stripping production... I'd love to be able to get through stripping a large batch in a saturday and spirit run the next day to wrap it up in a weekend. A few of those in a year would keep the barrels full with diverse product in my shed :)
j
I think you might be right. So far, this hasn't produced the output rate I would hope for. I am aiming to be able to process the ballpark of a figure I've seen in Yummy's thread - of around 1gal/h per 400W. I am guessing this is a US gal, which google tells me is approx. 3.8L - and on 3600W, - let's say I would hope to be able to process about 30L/Hour. I do need to double check my element resistance to calculate how many W I am actually putting into the column.
Thinking about why a continuous still should be efficient - I think that the ability to reclaim the 'waste' heat from product and tails is key.
Along those lines then, the defleg I have just above the wash feed is not adding anything in that regard. Maybe it helps to stabilise things or make it more consistent....But I believe if I have a certain amount of heat exchange capacity, I am better off using that defleg somewhere else than in the column - e.g. to try and pull more thermal energy out of the tails overflow u-bend.
I tried varying a few things in the column in the last run - mainly -
larger diameter column - I swapped out the 75cm of packed 4" for about 60cm of packed 6".
Adding a bigger section on the outflow - hoping that there would be more back pressure in the column.
Picture of the setup:
Neither of these modifications was very successful.
I believe the bigger u bend also meant that there was greater height of liquid in the main column - leading to more foaming .
the 6" section the output kept crashing for the same fluid input rate that I could achieve with 4" section. Yes, there was less packing length, so that might be part of it, but probably I will need more power to drive it successfully.
Note: in the photo shown, the lower section of 6" spool is NOT packed. The idea here was to allow some room for 'foam up'. But in the end, I realised that it's not actually too much of a problem if there's a bit of foam in the column - it mostly gets knocked back down by incoming wash. So, I need to probably repeat this with packing in the bottom section.
This set up was also getting a bit silly high - so I want to look at ways to reduce the height - losing the defleg and some other parts would be key to that.
Another thing that helped a lot today was that I added a touch more antifoam to the wash, and then stirred for 5-10 minutes with a paint mixer to degas as much as I could.
Tōtōchtin
Member
Post by Tōtōchtin »
Your price for the clay is 4x cheaper than I paid for the same size. I believe for the weight and ease of cleaning it's a good choice. I use in in hydroponics and use 35% hydrogen peroxide spray then rinse in the morning.
Tōtō
Bolverk
Post by Bolverk »
I think by keeping the dephleg at the top you've mixed two different types of continuous columns a stripping column and a low rec beer column.
I'd take the the dephleg out of the vapor path and put it in you bottoms stream.
See how Cotherman spilts his beer feed in this video?
You beer should be as close to vaporizing as possible when it enters the column.
tommysb
Post by tommysb »
Bolverk wrote: ↑Wed Feb 21, 2024 11:11 am I'd take the the dephleg out of the vapor path and put it in you bottoms stream.
That's definitely next on my list when I rebuild it and carry on next week!
Bolverk wrote: ↑Wed Feb 21, 2024 11:11 am See how Cotherman spilts his beer feed in this video?
Am I understanding correctly that rather than running sequentially through both product HX and bottoms HX one after the other (in either order), he instead splits the feed in 2 and runs in parallel?
I've seen the video before but it's not clear to me quite what he is doing there!
Bolverk
Post by Bolverk »
tommysb wrote: ↑Wed Feb 21, 2024 11:19 am
Correct
tommysb
Post by tommysb »
tommysb wrote: ↑Tue Feb 20, 2024 2:19 pm I was using a Kamoer speed controllable peristaltic pump to feed the column. I bought this from Aliexpress, it does up to 1.6L/Minute apparently. Unfortunately, the display on the pump never worked. I am in contact with them to get a replacement/refund, but it means I can't really measure/track the rate I feed wash into the column :(.
Just to note - the seller on AliExpress provided a refund when I sent a video of the display not working - and I have ordered another one. I am pleased/satisfied by their customer service - no complaints, I think I just got unlucky with this pump.
Nice work Tommy :thumbup:
It’s great when you can play mechanno to try different configurations.
They really are quite finicky to get dialled in .
I think that the 6” section will need way more power than you can give it . Like in a packed reflux column , if there is insufficient power , there is very inefficient column action .
I had similar foaming issues and adding anti-foam works amazingly well at fixing it . Like you , I mixed it into the wash first , but ultimately , I’d like to use a micro dosing parasteltic pump to inject it into the beer feed line .
Which Kamoer Pump did you get ?
I got Kamoer KK2200 .It was meant to do 2litres a min , but then in the fine print if you maintain that speed , it significantly shortens the live of the unit . So although mine can do 2l/h , its recommended to not run much over 1.5 which is fine for my purposes .
Being a scabby bastard , I just bought the pump and motor and have had to build a controller for it . In hindsight, I wish I had done what you did and just buy the lot in a box .
Anyway , good luck and keen to hear how this works for you .
drmiller100
Post by drmiller100 »
My continuous is clearly documented in the fuel section.
4000 watts. 2 gallons per hour from 10 percent beer. 4500 Watts
tommysb
Post by tommysb »
drmiller100 wrote: ↑Sun Feb 25, 2024 9:36 am My continuous is clearly documented in the fuel section.
Thanks for the heads up DrMiller - I will have a look over there.
Yummyrum wrote: ↑Sat Feb 24, 2024 8:15 pm
I got the DIP1500V2 pump. I am trying to prototype something for my commercial venture, so time taken getting stuff up and running literally costs more than just buying off-the-shelf in most cases.
Some reading around the forum on 6" columns (not continuous) seems to suggest they need to be driven with somewhere in the range of 8-10kW. If I want to try that, I should be able to pull it off with a couple of elements and some electrical jiggery-pokery. Makes sense what you are saying about the efficiency dropping without enough power and corresponds to what I saw.
The other thing I will probably try, to improve behaviour will be adding some feints from the spirit run back into the wash prior to stripping to reduce the foam up.
bluc
Post by bluc »
You just solved my last problem. Does away with need for a second dosing pump for antifoam. I know 1.5 runs barely foam from experience with pot and plated columns. Be interesting to nail down a specific ratio to prevent foam up. Nice work.
:clap:
