Vm/LM head
Re: Vm/LM head
When talking about azeo, start with a Proof and Tralles hydrometer like the one on the left
Re: Vm/LM head
Good idea.
Having a LM takeoff would only occupy space that packing could use.
Ya don't have to wait for a valve, run it as a ccvm or even stuff some mesh in the vm takeoff.
OtisT
Re: Vm/LM head
Yes that was a VM head. I don’t think the head type matters. VM, CM, LM should all give you the same ABV when used over the same packed column.
Takeoff speed certainly does matter, in addition to power level and reflux ratio. There is an orchestrated dance between the three variables that you need to manage. The few posts above this one talk about takeoff rates.
Your column needs to maintain a certain reflux ratio in order to properly separate alcohol from water. If you open the valve too much (collecting too fast) the reflux ratio goes down too far, resulting in less separation.
It is also possible to run your column with too much power. That will mess with separation and smear your run.
Re: Vm/LM head
OtisT wrote: ↑Wed Feb 21, 2024 4:21 pmTakeoff speed certainly does matter, in addition to power level and reflux ratio. There is an orchestrated dance between the three variables that you need to manage. The few posts above this one talk about takeoff rates.
A CM is different and a little harder to get 95% (I have at best reached 93%) as it doesn't have a shut off valve but controls the reflux by the amount of water you throw at it.
OtisT
Re: Vm/LM head
Thanks Bushy. Good to know. I only ran a CM a few times before going back to my VM, and never in an attempt to hit azeo. To be honest, I don’t even try to hit azeo anymore on my VM. I’m happy enough with 93% at a faster rate.Bushman wrote: ↑Wed Feb 21, 2024 4:35 pmOtisT wrote: ↑Wed Feb 21, 2024 4:21 pmTakeoff speed certainly does matter, in addition to power level and reflux ratio. There is an orchestrated dance between the three variables that you need to manage. The few posts above this one talk about takeoff rates.
Karstr
Re: Vm/LM head
How much power should I run with my 1m 1.5" SPP?OtisT wrote: ↑Wed Feb 21, 2024 4:21 pmYes that was a VM head. I don’t think the head type matters. VM, CM, LM should all give you the same ABV when used over the same packed column.
Karstr
Re: Vm/LM head
Another question for my new build.. Insulation. Should I add it around the reflux condenser pipe too?
- Salt Must Flow
Re: Vm/LM head
No insulation there at all. Just the packed column and the boiler needs insulation.
Karstr
Re: Vm/LM head
ThanksSalt Must Flow wrote: ↑Thu Feb 22, 2024 2:32 pm No insulation there at all. Just the packed column and the boiler needs insulation.
OtisT
Re: Vm/LM head
Agreed. And of course, the key to getting away with a lower ABV product is to make a good clean neutral ferment. Make a good ferment and you don’t need azeo, activated carbon filtering, and all that. Of course my go to neutral ferment is Shady’s Sugar Shine.
OtisT
Re: Vm/LM head
Great question. I’ve never run SPP so I can’t say for sure what the max would be on your rig. I see someone suggested about 1500-1800w. That sounds about right. I can tell you how I determine the max power for a column in my shed.Karstr wrote: ↑Wed Feb 21, 2024 5:06 pmHow much power should I run with my 1m 1.5" SPP?OtisT wrote: ↑Wed Feb 21, 2024 4:21 pmYes that was a VM head. I don’t think the head type matters. VM, CM, LM should all give you the same ABV when used over the same packed column.
You need a thermometer in your still head for this process.
1) Put a charge in the boiler at your typical run ABV. Bring your still to a boil at 1800w under full reflux. I’m using the suggested high end power value of 1800W as a starting point.
2) While waiting for your column to reach equilibrium, detune your RC for minimal flow. To detune, turn down the flow until the output water temp is hot, but not hot enough to burn you if an accident happens. I find that temp around 140F. This will help ensure you are not overcooling your liquid reflux, which can negatively impact your column performance. Once you have turned down cooling flow, wait until the vapor temp in your head is stable for 10 minutes. Record that temp and power setting.
3) Lower your power by a small increment, maybe 100W, and wait 10 minutes. Has your head vapor temperature changed? If the temp went down, your column is now doing a better job separating and you know that the previous power level was too high for your best separation. Record your new power setting and temp. (Note. If you repeat this step enough, doublecheck your RC water output temp for another detuning adjustment.)
4) Repeat step 3 until the power change no longer results in a temp drop after 10 minutes. When you reach that point, go back to the previous power setting and you now know your highest power setting for max separation.
Re: Vm/LM head
I don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
Start lowering the bar and soon you will have folk claiming that 88% or 90% is "good enough".
- Garouda
Re: Vm/LM head
Sorry but don't do that!
First and foremost, shadylane should have told you what a CCVM still is...
CCVM stands for Condenser Controlled Vapour Management, in other words, you have to change by hand the height of your condenser inside the column to adjust your reflux ratio. In the case of my still, this is an exercise that should take place at a height of 3m20...
That's another gimmick that gained popularity, I guess, thanks to, or because of, some YouTube videos by a funny guy with a long beard who tells a lot of rubbish...
With a gate valve, you can adjust your reflux ratio very precisely to collect your foreshots and heads, try to have the same precision with a CCVM still...
You already have some stainless steel sanitary fittings, it's easy to find a gate valve with the right Ø, I guess 1" in your case. If I'm not wrong, you ordered your valve, and you are waiting for it, in that case that's another reason to not consider that CCVM approach...
"In wine there is Wisdom, in beer there is Freedom, in water there are bacteria."
Benjamin Franklin
"In moonshine there is Rebeldom"
Garouda
Benjamin Franklin
Garouda
- Garouda
Re: Vm/LM head
It's not always the case, but I fully agree with Saltbush Bill...Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pmI don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
Start lowering the bar, and soon you will have folk claiming that 88% or 90% is "good enough".
Depending on external T°and atmospheric pressure conditions, I'm always in the area of 95-96%...
In fact, the real value must be close to 95.6% and the T° close to 78.2°C.
Where I live though, T°is closer to 77.1°C because of the altitude, but it can change according to the season/atmospheric pressure.
Benjamin Franklin
Garouda
Benjamin Franklin
Garouda
- Salt Must Flow
Re: Vm/LM head
I totally agree with this. I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy".Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pmI don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
- acfixer69
Re: Vm/LM head
And the P/T chart doesn't have an adjustment chart to calibrate to for attitude / season /and atmospheric pressure so we all calibrate equal right.
Karstr
Re: Vm/LM head
Another question for my new build. I dont have quite enough SPP yet( making them myself). Should I use my raschig-rings, or scrubbers? And, if I use the ceramics, should I mix them with the SPP, or mix it?
- Salt Must Flow
Re: Vm/LM head
I would certainly use rolled Copper Mesh at the base of the column then top it off with SPP. They say it's good to have copper in the vapor path anyway and SPP does it's best work on the upper portion of the column rather than the bottom of the column. In other words, I'd rather keep SPP on top rather than copper mesh on top.
As you continue to make SPP, you can start removing some rolls of copper mesh and replace them with SPP. I always keep 4 rolls of copper mesh in the base of my column because my entire still is stainless. I use Lava Rock to pack the rest of the column. I use copper mesh at the base of my riser during stripping runs, during pot still spirit runs as well as reflux spirit runs. In conclusion, in my opinion, copper mesh is the best way to go and continue using it for every run, especially because your still is nearly all stainless steel.
OtisT
Re: Vm/LM head
There ain’t no power setting or takeoff rate data that is going to help you decide what I or others consider tastes good enough. If my distillate tastes fine to me at 93% vs 95%, then it’s good enough. If my takeoff rate to achieve 95% would cause my run to last longer than I want, then it is too long. These are things you can’t fix or prove wrong, especially if the folks on the other end are telling you there is not a problem. As my ex-wife used to say to me, stop trying to fix everything and just listen.Salt Must Flow wrote: ↑Thu Feb 22, 2024 8:31 pmI totally agree with this. I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy".Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pmI don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
Bradster68
Re: Vm/LM head
Ha ha,"used to say". She's probably still saying it to someone. I would definitely be happy with a 93%.OtisT wrote: ↑Fri Feb 23, 2024 12:06 pmThere ain’t no power setting or takeoff rate data that is going to help you decide what I or others consider tastes good enough. If my distillate tastes fine to me at 93% vs 95%, then it’s good enough. If my takeoff rate to achieve 95% would cause my run to last longer than I want, then it is too long. These are things you can’t fix or prove wrong, especially if the folks on the other end are telling you there is not a problem. As my ex-wife used to say to me, stop trying to fix everything and just listen.Salt Must Flow wrote: ↑Thu Feb 22, 2024 8:31 pmI totally agree with this. I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy".Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pmI don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
- Salt Must Flow
Re: Vm/LM head
Yeah I never commented on other people's subjective taste or feelings. That's precisely why I said, I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy". That's "difference" in time and energy which are not subjective at all.OtisT wrote: ↑Fri Feb 23, 2024 12:06 pmThere ain’t no power setting or takeoff rate data that is going to help you decide what I or others consider tastes good enough. If my distillate tastes fine to me at 93% vs 95%, then it’s good enough. If my takeoff rate to achieve 95% would cause my run to last longer than I want, then it is too long. These are things you can’t fix or prove wrong, especially if the folks on the other end are telling you there is not a problem. As my ex-wife used to say to me, stop trying to fix everything and just listen.Salt Must Flow wrote: ↑Thu Feb 22, 2024 8:31 pmI totally agree with this. I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy".Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pmI don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
That is how I could decide for myself. I know how long it takes for me to do a spirit run. I know what power and take-off rate I currently use. Those are OBJECTIVE variables. Mine always produces 95%+ ABV at my set values. If it isn't (while operating at my set values) then something is in fact objectively wrong. If someone else is operating at the same set values as mine and only producing 93% ABV then there is something that could be done to make it 95%+ if they wanted to.
OtisT
Re: Vm/LM head
But if I am getting the results I want producing at 93% and can’t tell the difference between that and azeo, why would I want to spend more time and energy to get to azeo? What problem are you trying to solve?Salt Must Flow wrote: ↑Fri Feb 23, 2024 2:50 pmYeah I never commented on other people's subjective taste or feelings. That's precisely why I said, I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy". That's "difference" in time and energy which are not subjective at all.OtisT wrote: ↑Fri Feb 23, 2024 12:06 pmThere ain’t no power setting or takeoff rate data that is going to help you decide what I or others consider tastes good enough. If my distillate tastes fine to me at 93% vs 95%, then it’s good enough. If my takeoff rate to achieve 95% would cause my run to last longer than I want, then it is too long. These are things you can’t fix or prove wrong, especially if the folks on the other end are telling you there is not a problem. As my ex-wife used to say to me, stop trying to fix everything and just listen.Salt Must Flow wrote: ↑Thu Feb 22, 2024 8:31 pmI totally agree with this. I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy".Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pm
- Salt Must Flow
Re: Vm/LM head
Again, I never said you or anyone else would. Notice I said they could, "if they wanted to". I have no idea whether it would take longer or not. Time was never stated which is precisely why I said, "I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a waste of time and energy". Just because someone is getting 93% ABV doesn't mean they're running faster than I do. I myself cannot make determinations without knowing the variables.OtisT wrote: ↑Fri Feb 23, 2024 4:45 pmBut if I am getting the results I want producing at 93% and can’t tell the difference between that and azeo, why would I want to spend more time and energy to get to azeo? What problem are you trying to solve?Salt Must Flow wrote: ↑Fri Feb 23, 2024 2:50 pmYeah I never commented on other people's subjective taste or feelings. That's precisely why I said, I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy". That's "difference" in time and energy which are not subjective at all.OtisT wrote: ↑Fri Feb 23, 2024 12:06 pmThere ain’t no power setting or takeoff rate data that is going to help you decide what I or others consider tastes good enough. If my distillate tastes fine to me at 93% vs 95%, then it’s good enough. If my takeoff rate to achieve 95% would cause my run to last longer than I want, then it is too long. These are things you can’t fix or prove wrong, especially if the folks on the other end are telling you there is not a problem. As my ex-wife used to say to me, stop trying to fix everything and just listen.Salt Must Flow wrote: ↑Thu Feb 22, 2024 8:31 pm
OtisT
Re: Vm/LM head
Hey Salt. Sorry for being so argumentative. I guess I’m just not understanding the logic of the linguistic gymnastics going on. Part of living with a debilitating case of OMS (old man syndrome). At the end of the day, I respect your experience and advice, and appreciate your posts.
drmiller100
Re: Vm/LM head
Continuous. 3 inch lm reflux with 4 inch rectifying base.NormandieStill wrote: ↑Wed Feb 21, 2024 10:02 amI'm sure you've stated this before but I can't find the reference. Was this drinking alcohol or rocket fuel for burning?drmiller100 wrote: ↑Wed Feb 21, 2024 6:41 am2 gallons per hourshadylane wrote: ↑Sun Feb 18, 2024 6:53 pmAt what takeoff rate?drmiller100 wrote: ↑Sun Feb 18, 2024 6:19 pm Ive run 3 inch column with one meter of 12 mm marbles repeatedly and got azeo.
Taller and better packing will let you run azeo at a rate faster than a drip.
I ask because around 1 to 1.2 l/h seems to be the accepted upper limit for a 2" column and you're claiming about 7 times that for a 3" column whereas the extra area should only give you 4 times the production rate.
From 10 percent beer.
drmiller100
Re: Vm/LM head
It is pretty hard to do consistent 93. Much easier to slow down a tiny bit and get 95.OtisT wrote: ↑Fri Feb 23, 2024 4:45 pmBut if I am getting the results I want producing at 93% and can’t tell the difference between that and azeo, why would I want to spend more time and energy to get to azeo? What problem are you trying to solve?Salt Must Flow wrote: ↑Fri Feb 23, 2024 2:50 pmYeah I never commented on other people's subjective taste or feelings. That's precisely why I said, I'd have to hear how many watts they're running at as well as the take-off rate to determine the difference before calling it a "waste of time and energy". That's "difference" in time and energy which are not subjective at all.OtisT wrote: ↑Fri Feb 23, 2024 12:06 pmThere ain’t no power setting or takeoff rate data that is going to help you decide what I or others consider tastes good enough. If my distillate tastes fine to me at 93% vs 95%, then it’s good enough. If my takeoff rate to achieve 95% would cause my run to last longer than I want, then it is too long. These are things you can’t fix or prove wrong, especially if the folks on the other end are telling you there is not a problem. As my ex-wife used to say to me, stop trying to fix everything and just listen.Salt Must Flow wrote: ↑Thu Feb 22, 2024 8:31 pm
Are you measuring using temp or????
NormandieStill
Re: Vm/LM head
And from another thread:drmiller100 wrote: ↑Sun Feb 25, 2024 9:08 am Continuous. 3 inch lm reflux with 4 inch rectifying base.
Which answered my first question. The problem is that fuel is (generally) not drinkable, so this is not a fair comparison. Before my take-off drops from azeo (or as near as I get) I start pushing tails up the column if I run too fast. I can pull 1.5l or more of 95% abv (OK, possibly 94%) that stinks of tails from the very first jar. Which wouldn't be a problem if I was only looking for lighter fluid.drmiller100 wrote: ↑Sun Feb 25, 2024 9:36 am My continuous is clearly documented in the fuel section.
4000 watts. 2 gallons per hour from 10 percent beer. 4500 Watts
drmiller100
Re: Vm/LM head
It has zero tails. Azeo. By the nature of a continuous it doesn't separate heads or fores.NormandieStill wrote: ↑Sun Feb 25, 2024 12:03 pmAnd from another thread:drmiller100 wrote: ↑Sun Feb 25, 2024 9:08 am Continuous. 3 inch lm reflux with 4 inch rectifying base.
4000 watts. 2 gallons per hour from 10 percent beer. 4500 Watts![]()
