OK. So you don't push tails up the column (although you might be since you're not drinking it, so you may not know). My point is that the max achievable rate from a fuel-production point of view, does not equate to the production of palatable booze, because you're not interested in a flavour profile. The simple fact that I can pull 24 jars of 95% and discard half of them as not neutral is proof enough that achieving azeo does not mean achieving neutral. There's a lot of flavour in the 5% that's not ethanol! So your data point of 2gph, while interesting, isn't too relevant to the topic at hand as it doesn't represent the same still type, nor the same end-goal.drmiller100 wrote: ↑Sun Feb 25, 2024 12:14 pm It has zero tails. Azeo. By the nature of a continuous it doesn't separate heads or fores.
My tails jars on a neutral run are at 95%. There's generally only 1 as I shut off the still when I catch a whiff of the stuff.
