Vm/LM head
NormandieStill
Re: Vm/LM head
Post by NormandieStill »
drmiller100 wrote: ↑Sun Feb 25, 2024 12:14 pm It has zero tails. Azeo. By the nature of a continuous it doesn't separate heads or fores.
OK. So you don't push tails up the column (although you might be since you're not drinking it, so you may not know). My point is that the max achievable rate from a fuel-production point of view, does not equate to the production of palatable booze, because you're not interested in a flavour profile. The simple fact that I can pull 24 jars of 95% and discard half of them as not neutral is proof enough that achieving azeo does not mean achieving neutral. There's a lot of flavour in the 5% that's not ethanol! So your data point of 2gph, while interesting, isn't too relevant to the topic at hand as it doesn't represent the same still type, nor the same end-goal.
My tails jars on a neutral run are at 95%. There's generally only 1 as I shut off the still when I catch a whiff of the stuff.
drmiller100
Re: Vm/LM head
Post by drmiller100 »
NormandieStill wrote: ↑Sun Feb 25, 2024 12:42 pm
If you have flavors you don't have neutral or azeo.
Edit. My still has the heads and fores. It has really nasty flavors.
But it c rtainly doesn't have any tails.
NormandieStill
Re: Vm/LM head
drmiller100 wrote: ↑Sun Feb 25, 2024 3:08 pm If you have flavors you don't have neutral or azeo.
Azeo != neutral.
Neutral is a question of flavour. Azeo is a question of degrees. The molecules that convey flavour are often detectable in the order of parts per million. Even assuming that they are not soluble in ethanol, that still leaves a vast capacity for flavour at azeo. That you still don't seem to understand this explains why you think your numbers are relevant to this conversation.
Re: Vm/LM head
Saltbush Bill wrote: ↑Thu Feb 22, 2024 6:20 pm
shadylane wrote: ↑Thu Feb 22, 2024 3:06 pm Same here.
If your making neutral spirits, chasing after azeo is a waste of time and energy.
I don't particularly agree, the same wash or low wines refluxed to Azeo is always going to be more pure/clean.
Start lowering the bar and soon you will have folk claiming that 88% or 90% is "good enough".
Neutral is possible @ 90%
Strip fast with minimal reflux, dilute to 10% and run it again.
It might take azeo to clean up a one-run and done, but stripping with reflux will keep the tails in the pot.
Therefor the spirit run can be faster.
Re: Vm/LM head
So are we wasting our time telling folk to build reflux stills that are 20 x the column diameter in hight when they ask........If 90 % abv makes great neutral we might as well start making those reflux stills shorter and saving on materials.
Re: Vm/LM head
Not everyone has the ability or head room for a column 20x the dia.
That number is for one run and done, shorter can be used to make a good neutral.
Re: Vm/LM head
Saltbush Bill wrote: ↑Sun Feb 25, 2024 10:38 pm So are we wasting our time telling folk to build reflux stills that are 20 x the column diameter in hight when they ask........If 90 % abv makes great neutral we might as well start making those reflux stills shorter and saving on materials.
No thanks Salty .
I believe if you are going to make a Reflux still , you might as well just do it right from the get go .
Edit:
I get what Shady is saying . If height is a problem then shorter has to be the compromise .Shorter has to be run with more reflux so takeoff goes down .
Maybe it’s time to go down a column size .
If you have to pump 4kw into a short 3” and take off at a dribble just to keep the ABV up , maybe a 2” of the same height using only 2kw might be a smarter approach .
drmiller100
Re: Vm/LM head
You run the site. I mean this respectfully. Are you being sarcastic?
To me neutral has always meant azeo. Or no tails of any kind.
Do I have it wrong?
OtisT
Re: Vm/LM head
Post by OtisT »
drmiller100 wrote: ↑Mon Feb 26, 2024 8:49 am
Do I have it wrong?
Drmiller, I don’t think purity and how neutral a spirit tastes are the same thing. I’ve made bad tasting azeo and I’ve made really good neutral at 92%.
Getting to a higher purity helps by removing more water, but to get to a good neutral I feel you need to also address what you are starting with in the boiler, how well you are running your column and how you are making cuts. Just getting to 95% is the easy part if that is all a person is trying to do.
I know a lot of folks make neutral out of all feints and many are challenged with making a gentle neutral ferment. I’m sure the higher purity of just a few % would be very helpful for those running feints or a flavorful ferment.
And to Bill’s comment on what to recommend. I don’t think making the best recommendation is a waste of time. Of course we should talk about an optimum design that sets people up for success, however; When folks have limitations like money, height, time, etc. I think it’s OK to help them get the best they can achieve with what they have.
The Booze Pipe
Re: Vm/LM head
Post by The Booze Pipe »
OtisT wrote: ↑Mon Feb 26, 2024 10:10 am
I was gifted a 3”x40” piece of copper so that’s what I’m working with, and a 9’ ceiling height. If I can reach azeo, great. If not, I’m only after a neutral spirit. There are more ways to skin a cat in this hobby.
Drmiller, you are referencing fuel, but this thread is about drinkable spirits, so you’re a little off topic.
13.5g/50L keg
12,000watts of fury
drmiller100
Re: Vm/LM head
The Booze Pipe wrote: ↑Mon Feb 26, 2024 10:24 am
I'm referring to drinkable spirits.
Karstr
Re: Vm/LM head
Post by Karstr »
As the one who started this thread, I will tell you that I have got the help I wanted, good advice to make a spirit as neutral as possible. I want to be able to reach azeo, just as a testament that I'm able to. Then I will start to chase my goals, regarding taste. Have a nice evening folks😊
drmiller100
Re: Vm/LM head
Karstr wrote: ↑Mon Feb 26, 2024 2:22 pm As the one who started this thread, I will tell you that I have got the help I wanted, good advice to make a spirit as neutral as possible. I want to be able to reach azeo, just as a testament that I'm able to. Then I will start to chase my goals, regarding taste. Have a nice evening folks😊
Azeo is easy. Have a good enough column. Run it full reflux and get rid of the heads. Run it full reflux and note the temp above the packing with a digital meat thermometer.
Pull product at a rate as fast as you can maintaining that temperature.
Re: Vm/LM head
drmiller100 wrote: ↑Mon Feb 26, 2024 4:28 pm
Re: Vm/LM head
Sorry for having contributed to the high-jacking of your post. :oops:
But there's some good info here for Ya anyway. :lol:
The Booze Pipe
Re: Vm/LM head
It was all very informative
13.5g/50L keg
12,000watts of fury
Karstr
Re: Vm/LM head
Post by Karstr »
shadylane wrote: ↑Mon Feb 26, 2024 5:40 pm
Nothing to be sorry for😊 Lots of good information
Garouda
Re: Vm/LM head
Post by Garouda »
Karstr wrote: ↑Tue Feb 27, 2024 4:06 pm Nothing to be sorry for😊 Lots of good information
A lot of rubbish, too. Azeotrope has nothing to do with degrees, if your still produces some stuff that shows 95.6%, it's already a good sign, but who tells you what's in there. In our craft, azeotrope refers to a mixture of water and ethanol, that's it (there are other azeotropes), but in your wash there are other alcohols, esters, aldehyde etc, (aka congeners)...
That's the reason why I always divide my output in 500ml bottles and taste each of them to identify the neutral part, except two bottles of 250ml I collected first, sometimes I blend part of the second bottle if there's a pleasant banana flavour like in rum from molasses... I identify the neutral part of my booze, and the remaining, depending upon the recipe (sugar wash-molasses) will be added to the next run or used to make rum.
If it's neutral and shows 95.6%, then you have the azeotrope part of your distillate.
The state of the art is to know your still and to run it properly.
A grain alcohol is another story, anyway this topic is about LM/VM head and I don't use that setting to make a flavoured grain alcohol.
"In wine there is Wisdom, in beer there is Freedom, in water there are bacteria."
Benjamin Franklin
"In moonshine there is Rebeldom"
Garouda
