Presentation
zukram
Presentation
Post by zukram »
Hello.
I started moonshinging back in the 90's, but then had a stop for about 15 years, and took it up again a couple of years ago.
Since 'the last time' I've gained some experience in tig-welding and also electronic construction and programming, which had made the hobby so much more intereriting.
My still is a 60litre barrel made from stainless tubing and a 1500/75mm column (3,5") currently packed with scrubbies. The head is an E-arc condenser and liquid controlled thingy. The output rate is controlled by the condenser, and there's a valve controlled by a microcontroller which does the fine tuning.
I've actually been a member here before, but my account seems to have vanished.
Wildcats
Re: Presentation
Post by Wildcats »
Welcome aboard man. Have fun and stay safe. Cheer's
sadie33
Re: Presentation
Post by sadie33 »
Hello and welcome!!
Bradster68
Re: Presentation
Post by Bradster68 »
Welcome and 🍻. Sounds like you're we'll on your way.
zukram
Re: Presentation
Post by zukram »
Aw. well. yes I joined to share my invention of using pressure to regulate power. I've learned so much from others, so I wanted to give some back.
Scorpster
Re: Presentation
Post by Scorpster »
Welcome back then, and share away because it sounds interesting!
