Slowing down the angel share on a small barrel
BFBourbonBuddy
Re: Slowing down the angel share on a small barrel
Post by BFBourbonBuddy »
https://onlinelibrary.wiley.com/doi/pdf ... .tb00154.x
@Geoff and Bill
This article outlines the O2 permeability of a variety of waxes, while it may inhibit complete oxidation, these waxes provide a liquid tight seal with some transfer of Oxygen. Do with this what you will!
Deplorable
Post by Deplorable »
Saltbush Bill wrote: Tue Aug 01, 2023 3:07 am I'm pretty sure your right Geoff, if its not letting anything out , its unlikely to let anything in either.
I played around with waxing a barrel only a week or two ago, but that was to try to fix a leak.
I used shavings of bees wax and melted it onto / into the wood of the barrel using a heat gun/ paint stripper gun.....what ever you want to call it. It was a fail as far as leak fixing , but I'm pretty sure it would slow down any alcoholic angels if you where to wax 3/4 of the barrel.
I personally wouldn't wax the whole thing.
I did get the leak fixed but using another method all together.
I dont want to hijack the OPs thread, but I am very interested in how you fixed said leak. I have a stubborn leak in one of my barrels.
juana_b
Post by juana_b »
Deplorable wrote: Tue Aug 01, 2023 5:47 pm
Has anyone tried warming and waxing the barrel while on a vacuum pump?
― Charles Ives
Post by The Baker »
Perhaps off topic but I would love to know how you fixed the leak...
Newtothis
Post by Newtothis »
Evil_Dark wrote: Sun Jul 23, 2023 8:22 am I wonder if I wrap its circumference with saran wrap, letting its two side uncovered, would it slow down the angel share and won't compromise its content?
The two ends should continue the "breathing effect", reducing he angel share? Sure I'm supposing that it should age a bit (or significantly?) slower...
What do you think? Is it a bad idea?
I’ve wondered the same thing about wrapping, I was thinging of getting some large heat shrink bags and shrinking them on the barrel and leaving a little room at the bung area to breathe.
Evil_Dark
Post by Evil_Dark »
Newtothis wrote: Wed Aug 02, 2023 9:34 pm
Well wrapping the entire barrel may stop too much the air exchange?
I would choose to let the two flat ends uncovered, and wrap only the circumference to reduce significantly the air exchange.
The bung hole would be very small breathing area considering the surface ratio of a real size barrel, no?
Evil_Dark
Goose
Post by Goose »
My barrels came varnished (I know not recommended) but I still lost 40% or more in 6 months. I didn't figure waxing over the varnish would help.
Now I am in glass, but of course glass don't breath so maybe I put a cork in the lid or crack the seal very slightly ?
The Power of Positive Drinking
Evil_Dark
Post by Evil_Dark »
Goose wrote: Tue Aug 08, 2023 7:07 pm My barrels came varnished (I know not recommended) but I still lost 40% or more in 6 months. I didn't figure waxing over the varnish would help.
In mason jars I made a cap out of thin unprinted brown cardboard to replace the original metalic one, so it breathes slowly. Just be careful to not allow the spirit to touch or soak the cardboard as it will give a cardboard taste to the spirit... But for breathing purposes, it works wonderfully.
Evil_Dark
Zacher
Post by Zacher »
Just wondering if anyone actually wrapped a barrel in plastic wrap and the results?
HDNB
Post by HDNB »
Zacher wrote: Fri May 17, 2024 5:44 am Just wondering if anyone actually wrapped a barrel in plastic wrap and the results?
i have. it helps fix leaks (great for swelling a dry barrel). slows angle share. no difference in taste. it's plastic though and even if it's not touching the alcohol is not recommended.
now i drink for evil.
Zacher
Post by Zacher »
HDNB wrote: Fri May 17, 2024 8:36 pm
Thanks and agreed. My barrels are doing just fine in my basement but I was looking for an answer to the original post.....
" Slowing down the angel share on a small barrel"
Transfer the whiskey to glass early.
Zacher
Post by Zacher »
shadylane wrote: Sat May 18, 2024 2:50 pm " Slowing down the angel share on a small barrel"
:thumbup:
