Just Post a Pick of your Rig
Alzahra888
Re: Just Post a Pick of your Rig
Post by Alzahra888 »
vinegar run with yet used column.
Green, … reading machine
Anything started is already half done.
Training with the best. Sitting at their feet. I hate the word the best and don't use it, but they’re there doing what they do, nobly, to be sure.
Alzahra888
But alas it has a leak so back to solder for the third time
MooseMan
Post by MooseMan »
Definitely leaking from the soldered joint?
Alzahra888
MooseMan wrote: Mon Apr 01, 2024 11:48 am Definitely leaking from the soldered joint?
Almost positive. It was not easy to make a good seal between ss triclamp ferrule and copper pipe. But i’m inspecting possibility that the keg itself leaks instead/too but how often does that happen. EDIT: Ive run it over fifteen times on potstill configuration so unless i damaged it.
Alzahra888
And until i tweak the RC ive had to remove it and cap mid run-like. Its got a finger on the bottom loop i havent managed to pull up through the outer coil enough so it sticks out. Ive tried scrubbies but it still needs adjustment. EDIT: as others will know what i only now learned, vinegar is not alcohol and so in the sacrificial run after touching up the solder and rerunning vinegar, again, the RC fairly easily handles reflux when down and product flow when lifted up so the hassle of capping is gone.
MooseMan
Post by MooseMan »
Alzahra888 wrote: Mon Apr 01, 2024 12:06 pm
If the gap between the two is too big, you could try slipping in some copper pipe thats been split, to fill the gap.
Or beat some copper wire flat with a hammer and slip that in the gap, then solder, there's always a way.
Alzahra888
Finally got the pc going
Salt Must Flow
Post by Salt Must Flow »
Alzahra888 wrote: Wed Apr 10, 2024 9:22 am Finally got the pc going
Nice Liebig condenser :thumbup: I see you have some extra Tri-Clamp spools. If you used some of them to make a taller riser, you could support the Liebig condenser with a nylon strap from the ceiling or from a vertical stand and that would allow you to collect your product on a table or something like that. I use a folding table to collect product on. If you're concerned that a taller riser would make your boiler unstable over the burner, you could support the top of the riser using a strap from the ceiling, then you'll know it's impossible for it to fall over.
Alzahra888
Thats a great idea. Will do.
Yingis
Post by Yingis »
My son and I decided to tag team and start a new hobby. Due to work neither of us have tons of time so we purchased a still from North Georgia Still. We think it should fit with our needs into the future. Did we over kill?
deanodeano
Post by deanodeano »
greggn
Post by greggn »
deanodeano wrote: Wed Jun 05, 2024 10:48 am Image
Collecting in plastic is not advisable.
________________
Steve Broady
Post by Steve Broady »
greggn wrote: Wed Jun 05, 2024 2:19 pm
I’ll give him the benefit of the doubt and assume hope that he’s using the bucket as a safety measure, and that there’s a more suitable collection vessel inside which we just can’t see.
deanodeano
Relax fellas! I appreciate the concern. Context is everything.
This is a picture from when I was doing a cleaning run.
MooseMan
Post by MooseMan »
Haha yeah I remember that picture from a while back on your build thread I think deano.
Not much gets missed here about plastics and bad metals, which is a good thing!
deanodeano
I am doing my first spirit run today on corn barley recipe with good metals and no plastics. ;)
Twisted Brick
Post by Twisted Brick »
Cozy ‘stilling spot.
W1ck3d
Frankinstill
Post by W1ck3d »
Here's my Frankenstein
She's a mixture of a Hooloo 65l rocket Still with a few OakStill Upgrades
"65L" 55-liter pot with two elements 3000w completely separated from the main chamber
Copper dome lid
3-inch Sight glass (Puke window)
3-inch Bubble plates x4
200mm 3inch copper Deflag (from Oakstill)
3" to 1.5" Copper Lynn arm
1.5' to 2" Reducer with Thermomitor
2 Inch Condensor 400mm ( waiting for the OakStill my 500mm copper condenser)
I have a few more items on the way
I can't wait to get things going
Let me know if you guys have any suggestions, recommendations, or comments
Q
Keep Calm and get your shine on
Coonass15
Post by Coonass15 »
Danespirit
Post by Danespirit »
Just a word of caution. Your riser looks small in diameter.
Don't run it too hard or you'll get in trouble.
EricTheRed
Post by EricTheRed »
Coonass15 wrote: Tue Jun 18, 2024 12:34 pm 20240618_114807.jpg
Like Danspirit said - riser very small
what's withe the open T and the hole in the lid on the left of picture?
Life has gotten interesting!
Coonass15
Post by Coonass15 »
EricTheRed wrote: Sun Jun 23, 2024 7:27 am
I left it open to put a tapered cork in it. In case of overpressure hopefully it will pop out
TrailerDan
Post by TrailerDan »
My keg build
Twisted Brick
Coonass15 wrote: Fri Jun 28, 2024 9:25 pm
It would be prudent to re-solder the direction of your cork 'valve' away from you. You might even add a couple of 90*'s and a downspout into a stovetop stainless vessel like a bain marie to catch the cork and ethanol steam.
werkkrew
Post by werkkrew »
Fully modular,can configure it any number of different ways.
Before anyone asks,the PID in my controller is only used as a glorified thermometer when distilling. I only rarely use it as a PID to keep a mash at temperature.
Homebrewer11777
Post by Homebrewer11777 »
New SS TC still head for stripping runs. Original design could not keep up with 4k watts heating and made for some very long stripping run days. Believe this 3" shotgun should be able to do the trick.
Here is original build. Am planning to continue to use in this configuration for spirit runs.
jedneck
Post by jedneck »
:wave:
big help
Dunder
tombombadil
Post by tombombadil »
Yingis wrote: Sun May 05, 2024 2:08 pm My son and I decided to tag team and start a new hobby. Due to work neither of us have tons of time so we purchased a still from North Georgia Still. We think it should fit with our needs into the future. Did we over kill?
That's some nice looking copper!
My setup works fine but it's not very pretty.
Sporacle
Post by Sporacle »
jedneck wrote: Mon Jul 29, 2024 2:54 pm :wave:
Very nice Jedneck, do you have a few more shots of the deflag and PC set up.
It's nice and shiny :thumbup:
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
Now, when was the last time the damn thing got to singing, lol?
Shine on you crazy diamond."
