Cleaning up grains with ozone
- Tōtōchtin
- Member
I was wondering who here is using Ozone to help clean up the grains from mycotoxins and critters. How low of a dose have you used that works?
Generators are cheap enough insurance living here in the tropics, but I thought I should ask about this before pulling the trigger.
Tōtō
Tōtō
Si vis pacem, para bellum
- Salt Must Flow
Re: Cleaning up grains with ozone
I haven't read this yet, but it looks interesting.
- Dancing4dan
Could also try UV C
Marcus Aurelius
Marcus Aurelius
- NZChris
Shine a UV torch on it, if it glows green don't buy it. If it does glow, you will probably have flavor issues. I don't know if ozone could fix that,
viewtopic.php?t=19348
Thanks Chris .NZChris wrote: ↑Sun Jul 14, 2024 11:56 pm Shine a UV torch on it, if it glows green don't buy it. If it does glow, you will probably have flavor issues. I don't know if ozone could fix that,
- Tōtōchtin
- Member
The grain has to be in the line of sight of the UV while I can fill a barrel of grain with ozone.Here is a study on ozone effects on grain.
stillkaren
Ozone treatment does seem promising from what I've read. My only concern would be making sure the grain is thoroughly exposed and the ozone fully dissipates before using. A barrel seems like it would allow for good coverage.
Totally agree stillkaren .stillkaren wrote: ↑Sun Jul 28, 2024 5:48 pmMy only concern would be making sure the grain is thoroughly exposed and the ozone fully dissipates before using.
I’ve avoided posting in this topic as I don’t want to be negative Nancy , but Ozone is nasty stuff . It is a powerful Oxidiser and attacks human tissue .
Years ago I worked as a projectionist and we had a 16mm projector which used a Xenon lamp . ( while the 35mm were being overhauled). It produced Ozone while running and My lungs and throat were often irritated
after a night in the box .
Ozone also attacks synthetics and rubber . Years later , as a TV tech , my mother in law kept bringing me VCRs , Record players , Cassette decks and all manner of stuff to repair . In each case all the belts and idlers were reduced to sticky snot . I’d replace them and 6 Months later , she’d bring them back and they were f$&d again.
Turns out she had an Ozone machine running in her house . She maintained that a smarter man than me had told her that if O2 was good , O3 must be even better .
A few years later and her Husband had a strange and severe Cardiac event . She is now showing signs of dementia . These are now recognised as signs of Ozone exposure .
Schools are now banned from producing Ozone as a demonstration in science .
Be careful .
SW_Shiner
I've also used Ozone before, Used to work at a water bottling plant and we used ozone for sterilisation, (Natural spring water, so no chlorine or chems allowed) Nasty stuff to be around, and many very accurate tests every 30 mins to ensure levels weren't too high, in both the product and the room. Even in a temp controlled, hermetically sealed, positive pressure room. Ozone will get through the smallest gap.
Reefer1
It's potent stuff, i used to keep a large coral reef aquarium, i had a inline O/3 generator on my protein skimmer which had a venturi that sucked air and o/3 in a fine bubble stream that was confined in a reactor it was killing pathogens and some diatom algae, in sea water and yes if i put too much into the reactor some was neutraised the rest was blown in to the air in my room and i would get a sore throat,
There is another option, i would use co2 in the barrel with the grain, being heavier than air it sink to the bottom and fills up, and kill anything in there, i have a bar/pub co2 bottle and a regulator so i can squirt it over mash/wash in the fermenters, keeps it fresh.
- Tammuz
CO2 won't kill the eggs. Interesting articleReefer1 wrote: ↑Mon Jul 29, 2024 2:15 pm It's potent stuff, i used to keep a large coral reef aquarium, i had a inline O/3 generator on my protein skimmer which had a venturi that sucked air and o/3 in a fine bubble stream that was confined in a reactor it was killing pathogens and some diatom algae, in sea water and yes if i put too much into the reactor some was neutraised the rest was blown in to the air in my room and i would get a sore throat,
Warthaug
- Location: Roughly half way between the equator and the north pole.
Why worry about it. Mycotoxins are not volatile and many will thermally decompose during distillation. Unless the grain is of poor enough quality it won't mash or ferment, it'll be fine: https://www.mdpi.com/2304-8158/14/8/1303
Brewer for decades, dabbler in distilling who is trying to get better at the craft.
- Tammuz
Storing grains would be my reason.Warthaug wrote: ↑Thu Sep 11, 2025 8:00 am Why worry about it. Mycotoxins are not volatile and many will thermally decompose during distillation. Unless the grain is of poor enough quality it won't mash or ferment, it'll be fine: https://www.mdpi.com/2304-8158/14/8/1303
There must be some toxin getting through though, if all the big distilleries test the grain before they buy it.
Warthaug
As per FDA regulations, any grain entering the human food chain must be tested for mycotoxins. If a distillery is not purchasing from a company that does that testing, then by law, the distillery needs to do so. Its a blanket regulation, and for distilling, is unnecessary.
If it were a concern, they'd be testing the distilled spirits, not the source materials.
- Corn Cracker
My son used an ozonator to kill a bug infestation in his car, it killed the bugs but left a strange odor in the car, almost like a plastic smell that lasted for a few days
- Tammuz
Non of the alphabets effect me where I live. Most of what I have available to me is from a tropical environment. Almost everything grows and multiplies well here. An oz of prevention...
